Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > General Interior Topics
Old 04-08-2010, 02:50 PM   #1
tcrum's Avatar
1978 31' Sovereign
Cookeville , Tennessee
Bunk Bed Advice needed..
I have a 1978 31' Sovereign with rear twins. I need to add a bunk above each twin. I have looked for hardward in all of the usual places but nobody seems to have any. I have a fabricator that can make them for me. My questions is where can I attached them. Is it only to where there are already rivets? They can don't need to stow away or fold up.
Any other advice would be appreciated.
tcrum is offline   Reply With Quote
Old 04-08-2010, 04:34 PM   #2
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
I made my own bunks you can see pictures here.. http://www.airforums.com/forums/f44/...r-44644-2.html
The front is cut out of a piece of 3/4 inch ply. I screwed some 1x2 to the walls through the aluminum then added cross braces to the front and to the floor like legs. Also ran legs up to the upper bunk so the wall braces don't take to much weight. the upper bunk will hold me no problem and I'm 200 lbs.
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 04-08-2010, 06:07 PM   #3
mouth012006's Avatar
1974 Argosy 24
Science Hill , Kentucky
Images: 51
That is a picture of the bracket for the twin bunks that came in our unit. Ours folded up to make the back turn into a sofa then folded out and had a cable that hung from the the brackets that are attached to the ceiling
Hope this helps a bit....also the bed was made from plywood that was covered in foam then material. it folded down in half with a large piano hinge.
Kevin & Monique
New to A/S---Not to Honey Do's
Sweetie (lab) Snickers (lab) Blackie(lab)
Dotz(daschund) CB (daschund) Oh and 3 kids!!!
TAC# KY-3
mouth012006 is offline   Reply With Quote
Bunk Bed pmacdavid All Argosy Trailers 8 01-28-2011 07:41 PM
bunk bed KIMILI General Interior Topics 10 08-02-2010 09:27 AM
Folding bunk bed azfiredog300 Cabinets, Counter Tops & Furnishings 12 12-24-2007 12:27 PM
bunk bed tandemfish General Motorhome Topics 3 10-11-2004 07:29 AM
Bunk bed aviontt Cabinets, Counter Tops & Furnishings 6 09-02-2003 02:41 PM
