Old 12-02-2008, 09:29 AM   #1
Toasty's Dad's Avatar
2004 16' International CCD
Cincinnati , Ohio
Building Acrylic Shelf - Glue? Screws?
Hi,
About to build a shelf out of black acrylic, which will be mounted above the bed on a 16' CCD. It will be about 9" across, about 3-1/2" deep, with a lip just high enough to hold two coffee cups.
I've rehearsed this with scrap sheet, and found that yes Virginia, I can bend the stuff acceptably well with a heat gun, to make a groovy curving front matching the wall's corner.
Design is a back plate attached to the wall, the curving lip of the shelf, and a bottom, these 3 pieces assembled with ???
My rehearsal with superglue went ok, considering my sloppy cuts. I'm planning on doing the real thing with Weld-On #16 or clear PVC cement.
Is the extra cost of the Weld-On worth it? Will a glue-only piece survive the jarring of a trailer being towed, or do I need to add screws? And if so, how to safely screw this 1/4" thick material?
Plastics experts, please help!
jon
Toasty's Dad is offline   Reply With Quote
Old 12-02-2008, 10:06 AM   #2
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
Google acrylic glue. Do not use PVC glue. It is incompatible. I have not used Weld-0n 16. Usual adhesive is some (10%) acrylic resin dissolved in Ethyl Acetate or MEK. You can buy glue through a plastic fabrication warehouse. You could also make your own with a rock tumbler and a paint can.
Help on ACRYLIC WINDOW REPLACEMENT, '79 Argosy campman All Argosy Trailers 23 03-06-2015 08:05 AM
Acrylic vs. Vinyl Replacement Fabric Kevin245 Awnings 10 11-01-2008 07:11 AM
TV Shelf suggestions ellenwall Audio, Video & TV 9 02-05-2007 05:15 PM
Acrylic window care Janet H All Argosy Trailers 4 06-29-2004 12:54 PM
TV shelf? Raptorrider2001 1999 Safari 26 03-08-2003 02:49 PM
