Old 04-17-2009, 11:50 PM   #1
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
Bronze Edge Metal Trim 72 Tradewind
I had the front wood panel cut down when I put in the new fridge
So we tried to cut the old bronze metal edge trim but it didn't look good.
I've looked at the product from Brunner Enterprises:
C21006; for 1/4 in. 5/8x 3/8x 1/16 - Extruded Aluminum Channel - Aluminum angle, Aluminum tube, Aluminum extrusions, Anodized aluminum, Aluminum pipe, Aluminum channel, Extruded Aluminum angle, brunner enterprises, Aluminum bar, aluminum rod, aluminu
but they don't have the same bronze. Anybody got another solution, or used the Brunner metal trim?
RichHog is offline   Reply With Quote
Old 04-22-2009, 07:23 PM   #2
1971 23' Safari
Valley Grande , Alabama
same problem
RichHog, I can't be any help, but I sympathize with you! We have the same problem in our 72 Safari. There is some previous damage to the ceiling between the upper cabinent and the front sofa. So PO just patched it the "best he/she could" (read: awful looking!!) and screwed a couple of extra screws in the trim to attach it to the ceiling. Looks awful. I will be watching this thread to see if someone has any ideas! Thanks for posting the question....
holder310 is offline   Reply With Quote
Old 04-23-2009, 07:09 AM   #3
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
Bronze Edge trim on 72 Tradewind
There had to be a lot of the metal trim used so hopefully someone has some. I need about 9' of it. The other metal supplier has the right size trim but no bronze
Old 04-23-2009, 03:32 PM   #4
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Couldn't you just spray paint it the correct color using a metal paint?
What are they selling the 12ft lengths for?
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 09-23-2009, 10:28 AM   #5
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
Bronze Metal Trim on 72 TradeWind
I'm still looking for bronze edge trim that goes along the edge of the panels, it's inside diameter is 1/4" and outer lengths is 3/4". I need about 8' of it. Have found other makes from Brunner Enterprises but nobody has a matching Bronze.
Old 09-23-2009, 10:48 AM   #6
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
I may have some of it. Can you post a picture?
www.nesa.org
Air No. 6427
Old 09-23-2009, 02:03 PM   #7
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
Metal Trim
It's the bronze trim on the left panel above the fridge.
Old 09-23-2009, 02:40 PM   #8
rd tighe's Avatar
2007 25' International CCD FB
We are , Relaxed
Images: 12
cap
You might try outwater plastic and get a clear cap spray it in the in side so it can not be rubbed off we have had good luck with the new plastic paint that is out there here is the link to them iI am not sure of the panel size 5/8 or 3/4
Outwater Plastics - 2009 Master Catalog - page 50
Good luck
R D Tighe
rd tighe is offline   Reply With Quote
Old 09-23-2009, 05:35 PM   #9
Power to the People !
Maryw164's Avatar
1972 31' Sovereign
SAN DIMAS , California
Send a message via AIM to Maryw164 Send a message via Skype™ to Maryw164
Have you tried calling Colaws salvage? They seem to have a varied inventory of parts.
COLAW RV PARTS & SALVAGE | RV Rebuilders, Wrecked, Refurbished RVs [Recreational Vehicles]
Mary
Happy Trailering !
Forums member #29232
Check out my new Blogs (work in progress):
http://www.airforums.com/forums/blog...-maryw164.html
http://1972airstreamsovereign.blogspot.com/
Maryw164 is offline   Reply With Quote
Help on plastic edge trim inserts Idaho Ken Upholstery, Blinds, Walls & Interior Finishes 17 06-11-2011 07:21 AM
source for countertop metal edge? cccamper Cabinets, Counter Tops & Furnishings 12 07-23-2007 10:47 PM
Attaching and Bending Edge Trim PhilMateo Cabinets, Counter Tops & Furnishings 1 03-27-2006 07:56 AM
front end vinyl trim, misc trim mlmarch Clearcoat, Exterior Paint & Trim 4 07-07-2003 10:29 AM
seal the bottom edge trim pieces? cindy Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 10-23-2002 09:18 AM
