Old 01-27-2005, 07:21 PM   #1
border patrol
My wife and I are restoring a '76 Argosy 24' and need some info.
The previous owners used cheesy borders to decorate the walls and we're trying to get the glue off. Any ideas?
Rick
r myer is offline   Reply With Quote
Old 01-27-2005, 07:32 PM   #2
RichardT's Avatar
Hot water and a spong should do it., if it is still not coming off use a wallpaper gluE remover available at any home store in paint department., (test first in hidden area) that will take it off and should not hurt original wall surface.
RichardT is offline   Reply With Quote
Old 01-27-2005, 08:06 PM   #3
border patrol
Hi Richard,
Tried hot water, nail polish remover, wallpaper glue remover, scouring powder...
The stuff's pretty bullet proof.
Rick
Old 01-27-2005, 08:18 PM   #4
dscluchfc's Avatar
1984 31' Excella
Abernathy , Texas
Steam clean?
David
TAC # TX-18
AIR # 410
http://www.flickr.com/photos/dsphotoscapes
dscluchfc is offline   Reply With Quote
Old 01-27-2005, 08:28 PM   #5
Originally Posted by dscluchfc
Steam clean?
Heat may be the answer.
Sounds like it might be non-absorbant vinyl, which makes it tough to use wallpaper remover. Maybe try a heat gun?
Mark
Old 01-27-2005, 09:24 PM   #6
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
border patrol
Greetings Rick!
Welcome to the Forums and the world of Vintage Argosy ownership!
Rick
My suggestion would be to try one of the following methods that have proven successful for me when trying to remove wall paper adhesive from various wall surfaces in my rental properties. As strange as it may sound, I have had excellent results using the least expensive rubbing alcohol - - empty the bottle into a small pail and have a sponge and scotch brite scrubber available - - wipe the adhesive with the alcohol soaked spong and lightly scrub with scotch brite pad then follow-up alcohol soaked sponge - - I am not certain that this will work with the vinyl-clad wall surfaces, but I do know that this method removes the "sticky-wall" build-up that can be a problem on the vinyl-clad wall surfaces.
When stripping the wall paper and/or borders, I have had good luck with Silver Euro-Pro Ultra Steam Shark™ II Hard Surface Cleaner - - the kit comes with a large, wide concentrator that I have found effective in removing wall paper and most if not all of the adhesive - - it is too small for large areas, but works nicely for removing borders, etc where the surface area isn't so large. I was quite skeptical when I purchased this steam cleaner given the info-mercials' reputation for exaggeration, but the cleaner has actually far surpassed my expectations on every cleaning project that I have assigned to the Shark.
Kevin
Kevin D. Allen
AIR #827
Old 01-27-2005, 09:35 PM   #7
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Downy Fabric Softener
Believe it or not Downy Fabric Softener loosens wallpaper from almost any wall. You can speed up the process by using a scoring tool - pokes little holes through the wallpaper - or just use it around the loose edges and work your way in. Dilute regular strength about 4 parts water to 1 part Downy and mix in a spray bottle. Spray on lavishly, wait about five minutes, then get the scraper started.
Paula Ford, new owner of "tin lizzie" sitting under 38" of snow in NH
Old 01-28-2005, 04:10 AM   #8
Hi David,
I'll give steam a try. Right now, it's -26 celsius outside, so I'll have to hold off on
that method.
Rick
Old 01-28-2005, 04:12 AM   #9
Hi,
I'll try the heat gun.
Rick
Old 01-30-2005, 07:34 AM   #10
To All,
Thanks for the hints and tips. I think, I'll try the heat gun, vinyl glue remover and
steam in that order.
Rick
Can-Am RV Experience?? Craig Commercial Listings 20 10-05-2004 07:30 PM
Crossing Canadian Border trumpwer On The Road... 20 07-29-2004 08:34 PM
Pet Trauma Kit MaShep The Pet Forum 16 05-10-2004 04:00 PM
They finally noticed... Safari Tim Our Community 42 09-10-2003 06:49 AM
