Old 08-25-2009, 06:13 AM   #1
ryan3326's Avatar
1976 31' Sovereign
Columbus , Indiana
best way to deodorize?
We have just bought our first AS, a 1976 31' Sovereign. The previous owner left both tanks (black and grey) partially full - i would assume for a relatively long period of time prior to our purchase.
I have drained both tanks and flushed with LOTS of water. What is the best way to completely clean/deoderized these tanks? There is still an odor in our AS and it is coming from the bathroom.
ryan3326 is offline   Reply With Quote
Old 08-25-2009, 06:35 AM   #2
Well, I guess the good news is that your tanks apparently don't leak...
I'll let the experts chime in, as I am just an RV rookie, but I would think letting some bleach water sit in them for a while might help.
Good luck!
Old 08-25-2009, 06:48 AM   #3
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Greetings from the Florida Panhandle
For starters, I would go to a nearby RV supply store any get some of the commercial RV tank cleaning products. I would put some in per the instructions, add a whole bunch of ice, and immediately take a ride pulling the trailer. This would be the time to yest your braking capabilities. In other words, accelerate and stop quickly to get the ice to clean the inside tank surface. Needless to say, do this erratic driving in a large parking lot or other safe place. A little bleach in there wouldn't hurt either.
If the black tank was left long enough to completely dry with stuff in it, It could be a bigger problem. This is called :the black hills syndrome" and it very difficult to fix. It may take a number of ice runs and soakings to clear this up. In extreme cases, it may even require a tank replacement.
Good luck.
Brian
SuEllyn & Brian McCabe
2018 Silverado 2500 (Lillian)
Old 08-25-2009, 08:00 AM   #4
kennethowens's Avatar
1975 Argosy 24
Malakoff , Texas
Garden hose....Fill and empty 3 to 4 times.
Then fill them and add some smell good and let
it sit awhile.
kennethowens is offline   Reply With Quote
Old 08-25-2009, 08:05 AM   #5
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
it sit awhile.
Look into superchlorination afterwards. Let it sit up for a good while.
The bigger problems (as to smell) is not the tanks but the terminations.
Remove toilet and re-set flange with new is where I would start. Same with dump valve.
Be sure to inspect/clean, etc the plumbing stacks (tank vents).
Mine didn't need this. I wanted this. Zero smell then or later.
New is new. Used smells like it.
Old 08-25-2009, 08:26 AM   #6
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
One bottle of PineSol Lemon - fill tanks with water and ice - add half a bottle of PineSol to each tank and follow instructions above for driving around.
Empty/rinse and then refill with warm water and 2 packets each of OxyKem holding tank treatment. Let is sit a day and drain. If you still have an odor - fill again and add a couple tablets to each of Thetford AquaKem deodorizer and let that soak.
You may also want to buy a tank flush wand to rinse the tank with. I would not use bleach in a black or gray tank.
Old 08-25-2009, 08:46 AM   #7
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
As Brian said the ice trick is a good option, but start with an EMPTY tank (the ice floats) and add more ice as needed, the ice will last a lot longer. I used a combination of block ice cut large enough to fit through the flush valve and cubes in our "63" and it lasted 100mi and did a pretty good job.
A strong bleach mixture sitting for a week finished the job.
Instead of going to ’Starbucks…I make my own Coffee at home, yell out my name rong, then light a five dollar bill on🔥
"The hardest thing about Airstreaming, clearing your head and accepting how others feel it’s supposed to be done"…..
Amanamus
"Tahawus"
Old 08-25-2009, 11:01 AM   #8
funkill's Avatar
reno , NV
Images: 27
I was just starting lunch when I placed my cursor over the thread and saw the, untimely, preview. Gag.
Sorry your having this problem though.
Laura
funkill is offline   Reply With Quote
Old 08-25-2009, 01:17 PM   #9
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Using Bleach in Black/Gray Tanks.....
You may want to see this first:
Old 08-25-2009, 02:30 PM   #10
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Vinegar - good old white distilled vinegar (bathroom vinegar) instead of bleach.
If you've ever had pet stains on a rug, there are all sorts of fancy odor eliminating chemicals - but basically most contain plain old vinegar.
Definitely use the ice cube trick to scrape away solids - use vinegar for the "funk". Works everywhere. Takes gunk off of shower doors and fiberglass too.
Resetting the toilet seal, and cleaning the vent stacks isn't a bad idea either.
Paula
Old 08-25-2009, 06:08 PM   #11
ts8501's Avatar
1990 34' Excella
1964 22' Safari
Savage , Minnesota
It is also possible the smell is not comng from the tanks. I find the mid/late 70's era trailers have a smell from all the plastics that are still off gassing. The bathrooms are full of the stuff (plastics). You would have to search the threads to see what you can do about that, assuming all the black and grey tank treatments do not solve the problem.
"I've got aluminum fever, and the only prescription, is more AIRSTREAM!!!"
'64 Safari Resoration Blog ("May"):
http://ts8501.blogspot.com/
TAC MN-6
WBCCI/VAC 11736
AIR 25979
ts8501 is offline   Reply With Quote
Old 09-15-2009, 08:00 PM   #12
1994 30' Excella
Salem , Connecticut
Images: 8
Holding tanks should only have approved products put in them. I'm a park owner and seem what happens when campers put bleach,pinesol, etc in them. This eat the rubber in gate valves and can cause a deadly chemical reaction.
maintguy62 is offline   Reply With Quote
