Old 07-08-2012, 09:57 PM   #57
Alice&Billis's Avatar
2006 25' Safari
Tyler , Texas
sheets that fit the odd twin mattress
We've been at this sheet and fit the mattress game about 5 years and we started out with the standard sheets, using the garters and the suspenders to hold the sheets in place. The factory mattresses are horrible and we've recently replaced them with custom foam because it was cheaper than pain killers and chiropractors. We did the mattress toppers, and covered those with protectors and mattress pads all of which helped with the comfort. Finally after wrestling with the sheets for a couple of years, we bought regular deep pocket sheets at Wallyworld and I hit the fabric store and bought a long roll of half inch elastic. I set up the sewing machine to zigzag and stretched the elastic all the way around the entire fitted sheet. The tension of the elastic makes it hang on tight and that is how I solved that problem for us. For the flat sheet, I sewed a simple rod pocket at the bottom of the sheet, cut a piece of 3/4 inch PVC and slid it in and it helps make the bed and you can avoid having to retuck. I think this is the most reasonably priced solution to the sheets fitting the odd shaped twin mattress.
Alice&Billis is offline   Reply With Quote
Old 07-08-2012, 10:27 PM   #58
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
I purchased some regular twin size sheets from Sams Club "Christie England". They are super nice sheets in a set for $29 for each twin bed and those "hold on" straps that someone mentioned on this thread. They work just fine on the twin radial beds.
Sheets SETSAIL General Interior Topics 10 03-18-2007 02:53 PM
Shaped sheets for funky beds? SafeHarbor 1978- 1979 Excella 500 6 10-26-2005 01:09 PM
Got Sheets????? iowaroots Commercial Listings 2 06-06-2004 02:05 AM
sheets for rear twin beds moisheh General Motorhome Topics 8 04-07-2004 06:13 PM
Dumb Question regarding the bed & sheets kamadeca 2003 Safari 8 06-23-2003 02:24 PM
