Old 04-25-2007, 11:24 PM   #1
1976 31' Sovereign
1977 21' Globetrotter
Sierra Vista , Arizona
Bed Preferences
I'm in the process of upgrading my 31' 76 Sovereign rear bedroom model. I've removed the full-size bed and have been thinking in terms of installing a queen size bed. I've reviewed the posts by panabax & Bob Thompson and they give pretty detailed information on their conversions. Hovever when reading closely I noticed that they've used RV sized beds. I really need a full size queen 60"x80". I did a layout on the floor and things will fit, but they're really tight. This led me to reconsider using rear twins. has anyone installed a full size queen and are you glad you did?? What are the cons of twins other than snuggle related issues?? Where can I purchase new rear (curved end) twin matresses?? I'm anxious to get going but would like a bit of feedback to help me decide queen or twins.
I'm 6'-3" 260 lbs .
Caboose is offline   Reply With Quote
Old 04-25-2007, 11:30 PM   #2
1997 25' Safari
Arvada , Colorado
I have just converted my twins to a queen that lays across the back. Things are tight but I think I will love it. I also made it so I have alot of storage room underneath accessible from the hallway. I can try to upload my pictures if you are interested. I also have two new twin mattresses for sale .
Mtngirl
Mtngirl is offline   Reply With Quote
Old 04-25-2007, 11:32 PM   #3
soldiermedic's Avatar
Florissant , USA
Mine has a full 60x80 queen. It takes alot of space, but it is nice if you want the comfort it offers.
You could also install twins that convert to a king size bed.
Here is my rear queen.
Streaming Soldiers Blog
soldiermedic is offline   Reply With Quote
Old 04-25-2007, 11:50 PM   #4
1997 25' Safari
Arvada , Colorado
Caboose:
I will try to upload pictures by Saturday. I am going to be out of town until then. I have more room than shown by Solidermedic's picture since I have a 25' and I see your trailer is even bigger. I have about the same amount of room between my bed and the rear wall as Solidermedic's and then I have a 15" space between the bed and the wall towards the front of the trailer.
I left the structure in place for the right (looking towards the rear) twin since it holds the water heater and electrical. I took the left twin support and turned it around to there was more storage space for my outside storage access. I took the two doors to the former storage spaces under the twins and made them into supports under the middle part of the bed. So I now have a three chamber storage compartment underneath that is accessible from the hallway and can slide all the way to the back storage compartment wall. Hope that helps.
You have first dibs on the twin mattresses. How far is Sierra Vista from Pheonix? I may be going down in the very near future.
Mtngirl
Old 04-26-2007, 05:26 AM   #5
rickastream's Avatar
1976 31' Sovereign
Elm Springs , Arkansas
Caboose, just a quick note, if you go with twins, I have the front frames with slide up doors if you can use them.
Life is an attitude!
rickastream is offline   Reply With Quote
Old 04-26-2007, 08:45 AM   #6
Auretrvr's Avatar
Iowa City , Iowa
Twins for us...
Making the twin beds is a snap. We hug and cuddle plenty on our outings without the larger sleeping area. Sure would be an aerobic challenge to make a bed that filled the space. I like the access to storage below and the pup likes the nook at the end of the "hall." We set up the "big screen" computer on the fold up table and watch movies some evenings.
Airstream OCD...there is no cure!
1983 Classic 310 Motorhome.
AIR 15765
Auretrvr is offline   Reply With Quote
Old 04-26-2007, 10:01 AM   #7
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
What arrangement you choose, I highly recommend the Sleep Number bed. You can get RV repalcement sizes from them, you might look at the sizes available an make your frame to fit. I have them at home and in the trailer, and would not trade, no matter the amount of money!
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 04-26-2007, 10:51 AM   #8
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
Eastern , Washington
Images: 90
We have taken a different approach in our Argosy. It has front twin beds that are also used as seating space. We have discovered that (provided the bed frames are sturdy) you can use clear fir 1" x 6" placed across the gap between the beds to make a giant king sized bed platform. If you have or make large bolsters (like the back cushion on a gaucho or couch) for each twin, these pieces can be used to fill in the gap. We actually slide the twin mattresses together and use the bolster pieces to fill the edges...
When not in use they can be stored. This give the flexibility to retaining the twins but having the option for one larger bed.
The stack of boards actually doesn't take up much space and can be stowed in a closet.
AirForums Custom Search
Janet H is offline   Reply With Quote
Old 04-26-2007, 12:22 PM   #9
skyvalley's Avatar
2006 25' Safari
Desert Hot Springs , California
Twins for us also.
We bought our 25 foot 2006 Safari with a queen. It was uncomfortable to make, crawl over the other person, get to the upper storage, utelize the reading lights, utelize storage etc. etc...It took up to much room too...
We took out the queen and made twins the same size as the factory ones. Improved the sound and heat insulation on the water heater, added insulated around the sides and ends of the beds, extended the heat duct to the rear of the trailer, made new storage areas under the beds with easy access, had mattress foam cut for the curves at the heads and the foot on the left side bed, on and on...
In a nut shell; we have much more living space now, and the view from the trailer front looks like we added 5 feet to the rear of the unit!
If you have a snuggle problem build a plywood sheet under your bed with two legs to slide out over to the other bed and slip the mattresses together.
IMHO these units are to small to sacrafice the limited space for a queen bed.
John & Joan
skyvalley is offline   Reply With Quote
Old 04-26-2007, 06:23 PM   #10
markparker22's Avatar
1984 31' Excella
Santa Barbara , California
Speaking of a tight fit....
I have a 31' Excella rear bed. I replaced the original twin beds with a California King size bed. Now that was a tight fit! It fits crosswise and the room is wall to wall mattress. The matress sits on a Eropean wooden slat/metall frame purchased at IKEA and is hinged at the back of the bedroom. Lots of storage underneath but I try to keep the load weight down at that end due to the weight of the the new bed.
Mark
1984 31' Excella, mid bath, king size bed
1998 Chevrolet Suburban K2500, 7.4L/454 c.i., 4WD, Pullrite Hitch
AIR No. 2375
"You know... life is just the way it is...."
markparker22 is offline   Reply With Quote
Old 04-26-2007, 08:31 PM   #11
2000 34' Limited S/O
Jamestown , North Carolina
Beds
We have twins and like the extra room and storage accessibility!
2000 34' Limited with Sofa Slide
06 Dodge 3500 Cummins Turbodiesel 4X4 Quad Cab Hensley Hitch Pressure Pro Centramatics
WBCCI #4358
tslanier is offline   Reply With Quote
Old 04-26-2007, 10:04 PM   #12
flamingo-kid1's Avatar
1967 28' Ambassador
Rockford , Illinois
Send a message via ICQ to flamingo-kid1 Send a message via AIM to flamingo-kid1
Kewl
Are those Halliburton suitcases??
I'm just a pink flamingo on the great lawn of life :-)
flamingo-kid1 is offline   Reply With Quote
Old 04-26-2007, 10:08 PM   #13
1967 28' Ambassador
Rockford , Illinois
our situation
Our unit has twin mid-bunks, and the PO had built a frame under them for a pull-together king..
we have not pulled it together YET;-)
If the king was in place, we'd have to crawl over to get to the bathroom or the kitchen.. so we like our bunks.. and we each use a small dog as a foot warmer :-)
Old 04-26-2007, 11:56 PM   #14
Florissant , USA
Yes they are...have no idea what to do with them...will not be using them at all.
Steve
Bed Glide Repair Tamara General Interior Topics 16 08-31-2006 09:28 PM
1966 Overlander International Twin Bed Action 1965 - 1969 Overlander 6 10-04-2004 07:12 PM
Really a full-size bed mareinmn General Interior Topics 1 09-26-2002 07:47 AM
Center folding bed attachment uwe Cabinets, Counter Tops & Furnishings 6 06-30-2002 09:01 PM
UN-comfortable bed!! (Custom Rounded Matress) 99 bambi Our Community 3 04-16-2002 12:28 AM
