Old 02-24-2009, 07:27 PM   #1
hampstead38's Avatar
1967 26' Overlander
Upperco , Maryland
Bed frame: Wood or aluminum
We plan to convert our Overlander into a rear bed configuration. This means fabricating a bed frame. The easy choice is wood, but I'm concerned about weight in the rear of the coach. I don't want a bed "bounce" to put undue pressure on the frame while traveling. Has anyone fabricated a bed frame out of something other than wood? If so, how did it go?
hampstead38 is offline   Reply With Quote
Old 02-24-2009, 07:35 PM   #2
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
The Gaucho bed frame in the front of my 72 Tradewind has an Aluminum frame. I guess Airstream used it for everything due to its strength and weight.
RichHog is offline   Reply With Quote
Old 02-24-2009, 09:31 PM   #3
1967 26' Overlander
Upperco , Maryland
I'm thinking the 80/20 stuff may work.
Old 02-25-2009, 02:54 PM   #4
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
I made an aluminum frame from 1x1 tube and L
then used 1/4 cherry ply on the sides, 1/2 fir or birch on top.
I guess the whole queen size bed w/o the mattress is less than 50lbs
I made some access doors for storage
'77 Sovereign Intl 31' CB
Old 02-25-2009, 03:03 PM   #5
vhord's Avatar
Images: 96
Originally Posted by hampstead38 View Post
I don't want a bed "bounce" to put undue pressure on the frame .............
Wow! Are you bragging or what?
vhord is offline   Reply With Quote
Old 02-25-2009, 03:18 PM   #6
INSANITY CENTRAL
doorgunner's Avatar
1986 32' Excella
2014 Interstate Ext. Coach
Citrus Heights , California
Images: 35
I've used the 80-20 product before, It's great stuff. We were making machine tool guards frames out of it then installing polycarb to keep operators from loosing body parts!! They have a great assortment of fasteners for the product also.
I really think it would be overkill strength wise. The bed frame in my excella from the factory is 1/4" ply with aluminum framework. Get a look see at someone elses if you need an idea.
www.popasmoke.com
Proud Appellation American
Vine View Heights is now closed.
YETI ( 65 Quart )
IGLOO (Ice Cube, 50 Quart )
doorgunner is offline   Reply With Quote
Old 02-25-2009, 03:54 PM   #7
1967 26' Overlander
Upperco , Maryland
Well, I was concerned about bouncing when towing rather than bouncing when parked. If I manage to crush the aluminum jack stands under the rear of the coach, then I'm either bragging or need to cut down on dessert.
The 80/20 stuff looks interesting and my welding skills are so lousy that I would doubtlessly destroy a good deal of aluminum in the fabrication. I've also thought about the 80/20 for interior cabinet framing. I just need to get my hands on some samples and see how it would work.
Old 02-25-2009, 04:32 PM   #8
INSANITY CENTRAL
doorgunner's Avatar
1986 32' Excella
Images: 35
You could try calling 80-20 and finding who stocks their stuff in your area. Seems as the distributor where we used to get our stuff had a road salesman that was always carrying some samples.
You could just use some alu angle to fasten all the framework together with wood screws.
If I recall Lipets had a thread on his project, maybe get some idea's.
www.popasmoke.com
YETI ( 65 Quart )
Old 03-26-2013, 09:47 PM   #9
1978 23' Safari
austin , Texas
Can I see a pic please? What are the measurements?
jennylea3382 is offline   Reply With Quote
Old 03-26-2013, 10:26 PM   #10
the544man's Avatar
1956 16' Bubble
Dallas , Oregon
you might get an idea from what I did perhaps. I call it my no brainer bed design. using the kreg drill I put in some slotted 2/4s (to let wiring run through) around the edges, built a cubby for interior access and functional support and topped with plywood. really not all that heavy and I still get good exterior access. the hardest part was getting the plywood cut perfect enough to slide down the sloping walls for install. cheers. ted
the544man is offline   Reply With Quote
New water heater-- Need wood frame? gparker Water Heaters, Filters & Pumps 0 05-30-2007 08:34 AM
cutting mattress to fit bed frame?? charlie tuna Upholstery, Blinds, Walls & Interior Finishes 6 09-01-2006 08:22 AM
Interior Skin Aluminum or Wood?? BornToRock General Interior Topics 5 08-31-2005 08:33 AM
Rear bed frame upgrade ViewRVs Airstream Motorhome Forums 3 05-10-2003 10:53 PM
Twin Bed Frame pepper48 General Interior Topics 2 01-14-2003 08:27 PM
