Old 08-05-2015, 03:52 AM   #1
Roadrunner's Avatar
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Indiana , Pennsylvania
Bathroom Walls? Shower Out...
So I have the bathroom out of the kid's "74" Tradewind and ready for paint. Are the end caps plastic and the sink/shower fiberglass? I used Krylon Fusion on the front end cap and it looks great. Has anyone used Fusion on fiberglass? With the sink/shower out of the trailer, what is the best way to refinish? Fusion? Two part epoxy? Thanks!
Bob Leopold "Roadrunner"
Indiana, PA
TAC PA-5
WBCCI 4871
Roadrunner is offline   Reply With Quote
Old 08-05-2015, 04:17 AM   #2
Roadrunner's Avatar
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Bathroom Pics
Just thought I'd post a few pictures of the tear out...
Bob "Roadrunner"
ID:	244638   Click image for larger version
Old 08-05-2015, 04:48 AM   #3
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
sink and shower are ABS; end-cap is fiberglass.
looks exactly like mine...I'm planning on using por-15 white coat on the abs; probably Krylon on the end-cap.
How's the floor?
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 08-05-2015, 06:52 AM   #4
Mission , Texas
You might enjoy this ...
nrgtrakr is offline   Reply With Quote
Old 08-05-2015, 08:36 PM   #5
Roadrunner's Avatar
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Floor
Chuck...the floor seems to be ok but I'll have to take out the shower pan to be sure. It appears there could have been leaks in the past but nothing recent...at least since I sealed the roof. Now the cleanup and then repaint.
Bob "Roadrunner"
Indiana, PA
TAC PA-5
WBCCI 4871
Name:	Bathroom Floor.jpg
Old 08-05-2015, 10:50 PM   #6
1979 23' Safari
Wayland , New York
"sink and shower are ABS; end-cap is fiberglass."
All are ABS. I used krylon fusion on my end cap, outside of the trailer in a garage. Overspray would be an understatement, the way it sprays it seems to want to go everywhere except where you want it to. Just about everything in the garage ended up with a white 'dust' coating, so mask and cover anything you don't want getting paint on it. Cleaned and Prepped the heck out of it not to happy with how well it's stuck or wears. Others have been happy on the forums. Used much other spray in the garage with no overspray like the fusion. Watch the dry/recoat times. I'd recoat well under 24 hours if you do. I did mine at about 20 hrs and got alligatoring. Then you have to wait. 7 days to recoat. Thought I'd use it as a primer and paint over it with something else, krylon said only krylon fusion would stick on the krylon fusion, though others have reported success covering it with other paint. Wished I'd just used a plastic primer paint that rustoleum makes and then could paint with whatever I wanted.
"looks exactly like mine...I'm planning on using por-15 white coat on the ABS".
About at this point, planning on using the white coat on my bath surfaces as well after I get them spray primed with an automotive plastic primer.
To Rip Off Walls Or Not To Rip Off Walls... belikethefox Upholstery, Blinds, Walls & Interior Finishes 3 03-20-2015 01:31 PM
Cracks in bathroom walls Jeremy9107 Upholstery, Blinds, Walls & Interior Finishes 3 11-17-2012 09:21 PM
Bathroom walls have some damage to the bottoms, can't think of good repair. mikeandnora General Interior Topics 5 04-10-2012 06:36 AM
bathroom walls mrauch Upholstery, Blinds, Walls & Interior Finishes 1 11-19-2008 03:56 AM
Painting plastic walls and bathroom sink jwaldin Upholstery, Blinds, Walls & Interior Finishes 4 11-14-2003 08:37 AM
