Old 04-03-2012, 07:42 PM   #1
1989 29' Excella
Tyrone , Georgia
Bathroom walls have some damage to the bottoms, can't think of good repair.
Sorry I don't have a picture, but it's pretty easy to explain.
I took off the vinyl covered plywood in the bath and in a couple spots (base of toilet area) pulling the vinyl off resulted in the outer layer of wood breaking off. The three spots are in pretty hidden spots (behind toilet mainly) but I would like to at least do something to repair it even though they are not really effecting anything and will be painted over.
Wood epoxy? That would probably end up cracking on that flimsy wall though.
Place a thin sheet of plastic or even wood over the top kind of like a baseboard and adhere/bolt it in place?
Paint over it and don't worry about it?
mikeandnora is offline   Reply With Quote
Old 04-07-2012, 10:14 PM   #2
arden_dean's Avatar
1986 34.5' Airstream 345
topeka , Kansas
Images: 26
Formica
I'd try FORMICA or some other laminate.
arden_dean is offline   Reply With Quote
Old 04-08-2012, 05:46 AM   #3
Bruce B's Avatar
2012 16' International
Jamestown , Rhode Island
Look at West System epoxy. They have very helpful tech support to guide you through repairs like these. If you choose to use West (or any epoxy products) remember that it is very important to use proper safety gear when it is wet. People react badly to epoxy sometimes although it is fine if you are careful.
Bruce
Bruce B is offline   Reply With Quote
Old 04-10-2012, 04:50 AM   #4
Skatiero's Avatar
1986 32' Excella
Canton , Georgia
I like the idea of making a baseboard of sorts.
Skatiero is offline   Reply With Quote
Old 04-10-2012, 06:36 AM   #5
reinergirl's Avatar
Hollis , New Hampshire
Do a search for wood epoxy stick. It's basically a two part stick that you cut a piece off of, knead it to mix it, and use the putty to fill in your missing areas. Can be sanded, drilled... after it cures. For those of you that have damage to unpainted wood it can be colorized with gel stain and marked with a fake grain pattern even.
reinergirl is offline   Reply With Quote
Old 04-10-2012, 06:36 AM   #6
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
If it's wood & you're painting it, you could use some woodfill, sand it, paint it, done! I had the same issue in my former '76 where I pulled the "wallpaper" off & lost some wood with it. I filled it, sanded it & rewallpapered. It was fine!
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
If you won the lottery... Paul Ouellette Off Topic Forum 44 11-04-2012 10:06 PM
Running the furnace in a 2011 23FB FC GettinAway 2009-2015 Flying Cloud 30 08-11-2012 06:50 AM
Southwest Boondocking east of Albuquerque xbr443 Boondocking 14 04-08-2012 10:40 AM
Things that go bump in the night rebelstand Tires 27 04-03-2012 06:29 PM
Please help! Rental to tow with DE to MA etobolski On The Road... 25 04-03-2012 06:21 PM
