Old 04-29-2011, 10:03 AM   #1
Ag'71's Avatar
1971 27' Overlander
Springfield , Missouri
Smile Bathroom Pocket Door Removal
I've got a 1971 Overlander I've restored, but I would like to take out the pocket door between the bedroom and bathroom to paint and faux finish. I don't want to remove any interior walls, but I can't figure out how to get the door out. Anyone got any ideas? Thanks.
Ag'71 is offline   Reply With Quote
Old 04-29-2011, 10:06 AM   #2
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Been there, done that. If your pocket door assembly is like the one in my '72, you'll need to drill out the rivets holding the laminate wood panel above the door. The piece is a shallow C shape. You don't need to remove the aluminum extrusion that the panel was riveted to, unless you want to.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 04-29-2011, 10:13 AM   #3
Ag'71's Avatar
1971 27' Overlander
Thumbs up
Thanks for the info. I'll give it a try!
Old 04-29-2011, 12:56 PM   #4
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
Umnn... to get to the bath tub base screws and other hidden fasteners the ceiling lockers and beds had to come out... I seem to remember. Maybe someone has a better cheat, errr... idea.
What is this tank in my Cloud bathroom? MontanaAIR Fresh Water Systems 3 05-15-2011 01:18 PM
19' Airstream Bambi bathroom Sactown 2005 and newer - Bambi all models 6 04-06-2011 08:02 PM
Bad Switch On Bathroom Fan jambie Lights - Interior & Exterior 10 03-23-2011 09:41 AM
composite flooring bathroom installation sealing the toilet handn Floor Finishes 1 03-10-2011 06:47 PM
2004 Safari leaking around bathroom vent fan DJW Leaks - Weatherstrips, Gaskets, Caulks & Sealants 4 01-03-2011 04:12 PM
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
