Old 07-13-2009, 08:55 AM   #1
Silverslug75's Avatar
1973 31' Sovereign
Vashon , Washington
Bathroom Plumbing Remodel
We are turning an abused 31' Sovereign into a stationary cabin in the woods. Part of this job is remodelling the bathroom. We knocked out the closet divider wall to make room for a bigger bathtub and have pulled out all the fixtures. One problem we now have is all the black plastic pipe all over. The vent pipe up to the ceiling is a particular obstacle. Unlike the kitchen, the bathroom pipe (formerly in the closet) is now out there in front of God and everybody and right in the way of the new bigger tub.
Is there a way to redo the pipes and hide the vent back behind the wall like in the kitchen? Are there flexible replacement vent tubes these days to make it easier? Has anyone come up with a more simplified drain pipe system for this situation than the original layout? Help me please...I'm SCARED!
Name:	airstream rm1 015.jpg
Silverslug75 is offline   Reply With Quote
Old 07-13-2009, 09:10 AM   #2
tphan's Avatar
1972 27' Overlander
Longmont , Colorado
I eliminated that vent, and now everything vents through the one in the kitchen wall. No problems with that yet. Your idea of taking off all the skin in that area, and re-routing a new, flexible vent in the exterior wall, would work too.
tphan is offline   Reply With Quote
Old 07-14-2009, 10:20 PM   #3
1973 31' Sovereign
Vashon , Washington
If I can eliminate the whole thing, that would make me happy. Did you have to plug the old rear vent opening on top?
Old 07-14-2009, 10:31 PM   #4
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
Consider using one of the vent one-way-check-valves (AAV Vent) they use on island sinks. Plumb Pak at Lowe's: Studor Mini Vent Air Admittance Valve is an example of one. Basically allows air in the line but not let the sewer gas out. Wouldn't be a good idea to eliminate all vents for the system this way obviously, but for part of the system such as a sink or tub when the line is still vented in the kitchen etc you should be fine.
Scott & Megan
VAC LIBRARIAN
Restoring Wally Byam's 1955 26' European Caravan Trailer!
WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is offline   Reply With Quote
Old 07-16-2009, 01:51 AM   #5
Ottawa , ON
The check valve is going to be absolutely necessary if you plan to eliminate the vent (black pipe) that was in the closet opposite the one (that was) in your picture.
Why? That's the one going to the "black tank". Strongly advise just rerouting is and keeping it separate. It's just black PVC, real easy to work with: cut and glue. It has its own chrome cover on the roof of the street side of the trailer.
Old 07-16-2009, 08:04 AM   #6
tphan's Avatar
1972 27' Overlander
Longmont , Colorado
I did put a cap on the exterior vent stack, and a round aluminum patch on the interior. The black tank still vents odors up and out the other vent, which is only about 6' further up the line from where the other one was. I can't say I really understand why there were 2 vents, for such a small plumbing system, in the 1st place. Anyway- worked for me in the Overlander, might for you too.
Old 07-16-2009, 09:20 AM   #7
65CV's Avatar
Western , Massachusetts
flexible hose
This is what was used on the head in my last boat. It was flexible and odor free, but not cheap:
Raritan Engineering | Sanitation Hose
65CV is offline   Reply With Quote
bathtub plumbing
'70s Rear Bathroom Remodel? mello mike Cabinets, Counter Tops & Furnishings 2 02-28-2012 07:40 PM
Access to bathroom plumbing maxi28 Plumbing - Systems & Fixtures 11 06-04-2009 12:05 PM
BR remodel danalee General Interior Topics 1 01-02-2009 07:37 PM
64 Bambi II Bathroom Plumbing Can-O-Pabst Sinks, Showers & Toilets 4 10-19-2007 05:30 PM
Bathroom Reno, tank, plumbing, toilet, etc Herritt Plumbing - Systems & Fixtures 3 05-18-2006 10:19 PM
