Old 03-20-2008, 02:09 PM   #1
1976 31' Sovereign
1963 16' Bambi
1971 21' Globetrotter
Marbletown , New York
Bathroom finishes
I have some information followed by a question. I hope that it helps and I hope that someone can help me.
I am researching finishes to use to restore my Sovereign. I have read many threads in the Forum talking about the question of materials and sort of settled on Tough as Tile. Below is an exchange between Gleem Paint and me the Manufacturer? Distributor of Tough as Tile. In reality I probably shouldnít care if the stuff lasts more than a few years, but Iíd like to do it the best possible way.
The other product that looked promising was Tubby a two-part epoxy. It comes in a few acceptable colors and states that it is good for, among other things, fiberglass and acrylic. I e-mailed them with a few of the same questions and didnít get a response. I re-sent a few days later and didnít get a response. I believe that Tubby is manufactured in England but e-mail doesnít go by boat -unless Iíve been lied to. I figured that if they didnít respond they couldnít care less for my business. I am now stuck.
Does anyone have any input to this? Some of the threads did a great job documenting the first phases of the re-finishing but never followed through with the immediate, or long-term results.
Can someone help?
Sent: Wednesday, March 19, 2008 10:09 PM
To: info@gleempaint.com
Subject: Question
I'm refinishing a tub/shower in an Airstream trailer.
1. Does Tough as Tile remain somewhat flexible?
2. Can the TAT be color tinted? If so, how can I get the color I want?
3. Is there a temperature range it should be applied at?
4. Can it be rolled on and if so will it flow out or will it have orange
peels? Or is the flowing and leveling process temperature related?
Thanks for your help,
1. Yes at first, but in time ( years) will become more and more brittle.
I would not recommend it for this reason, I would look for true 2 part
epoxy verse a one part. You should be able to find one at a local paint
store. (we current do no have a shippable 2 part epoxy)
With best regards,
www.GleemPaint.com (ND)
228.863.3942 v M-F 8am to 4pm CTZ
228.863.3409 Fax
P.S. For easy reference and to avoid delay in handling your inquiry, please
include the contents of all previous/relevant emails when you send us
further email on the same issue.
Stone Ridge is offline   Reply With Quote
Old 03-20-2008, 04:53 PM   #2
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
we used tile doc by sherwin williams after reading threads on here, and its held up during the rest of the restoration to tools and feet with shoes, dirt, metal shavings etc. Its been on almost a year and looks as good as the day it went on.
goransons is offline   Reply With Quote
Old 03-25-2008, 05:03 PM   #3
1976 31' Sovereign
1963 16' Bambi
Thank you very much. I really do appreciate the information. It gets quite confusing dealing with all the different materials to be refinished. I'll post the results when I'm done. Thanks again.
Old 04-07-2008, 10:54 AM   #4
papademojo's Avatar
1991 34' Limited
1968 22' Safari
Clarksville , Indiana
Bathroom paint on '68 Safari
I to was worried about what to paint my BAth with, so I decided to go with a marine paint. Por-15 has a paint that I used and it has held up in my unit for
two seasons without any failure. Here's a link to the sight that shows mine.
http://www.airforums.com/forums/f192...i-27354-3.html
papademojo is offline   Reply With Quote
Old 04-07-2008, 01:29 PM   #5
1969 31' Sovereign
atlanta , Georgia
Todd coleman did the paint work on my AS, so he is a better resource, but we did 3 coats of auto primer and then did the end caps with a automotive white. Durable so far and looks amazing. http://www.klendesign.com/steamboat/int04.jpg
http://www.klendesign.com/steamboat/int05.jpg
It is tough to choose b/c you put so much work into preparing the surface that you want it to be right. Todd used to be is partially still is in the professional paint biz - so he's done quite a bit of this and has all of the equipment - that said I don't know if he used a hardener afterwards.
Atlanta, GA + Steamboat, CO
1969 31' Sovereign
nunya001 is offline   Reply With Quote
Bathroom vanity and Bathroom vent lights... sovereignrwe Electrical - Systems, Generators, Batteries & Solar 10 01-05-2010 06:30 AM
New Bathroom srfotog Sinks, Showers & Toilets 3 06-10-2007 11:51 AM
Need Bathroom.... PhilMateo 1965 Overlander 3 12-31-2005 08:25 PM
Bathroom Removal Keyholeren Cabinets, Counter Tops & Furnishings 6 11-06-2004 07:12 AM
Mirror Finishes Walker's Wanderer Cleaning, Stripping & Polishing 3 10-26-2003 01:44 AM
