Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > General Interior Topics
Old 10-19-2004, 11:52 PM   #1
ClassicRides
Profile:
Bath Molded Plastic Refinish
For my 3rd post (newbie!): I've seen several suggestions for refinishing/painting the molded bathroom units (tub, sink, counter): Tough As Tile (I've used that on regular bathroom fixtures and it works well), FiberGlas gel (don't know anything about that), and marine paint. I also think that automotive vinyl dye might work (we've done that on car seats and dashboards and you can't scratch it off).
Any thoughts on what would be best? Does anyone know what the professional refinishers use?
We'd also like to paint the walls... seems to also be molded plastic (ABS?).
Has anyone had any luck with a bathroom make-over like this? Do any of these last?
Thanks in advance!
ClassicRides is offline   Reply With Quote
Old 10-20-2004, 04:28 AM   #2
Sneakinup
Master Riveter
Sneakinup's Avatar
Profile:  1972 27' Overlander
. , Mobile-- as in transient
Images: 72
I used the Klenk 2 part epoxy plastic and fiberglass paint that you can get at the home centers. Their "kit" comes with a roller to apply it with, but if your bathtub and counter are anything like mine, you cannot roll it on. Too many curves and surfaces that are not flat. I followed their instructions to the letter, and used an HVLP gun to apply it in 3 coats, making sure I had the proper thinning percentages. It was truly a nightmare to apply. I also did it without having removed the fixtures. It sure would have been easier with them out, but if I was going to do that, I would have built a new counter and changed everything out but the tub.
I think my bathroom looks pretty good, but upon close inspection I have some runs and uneven areas. It is certainly an improvement. The prep work took days to complete. Maybe there are some other products out there that flow more evenly with less work. I wouldn't try this again!
ID:	9177  Click image for larger version
1972 27' Overlander 72 Overlander
Jack Pad--- A notebook used by Jack Nicholson in the Shining to keep track of how much work he had done on his Airstream. "All work and no polishing makes Jack's Airstream a dull trailer"
Sneakinup is offline   Reply With Quote
Old 10-20-2004, 06:53 AM   #3
Don Pace
Profile:
Bath Refinishing
Do you think the epoxy paints would work? We have used them on counter tops successfully.
Don Pace
69 Overlander
WBCCI 7287
Don Pace is offline   Reply With Quote
Old 10-20-2004, 07:56 AM   #4
overlander64
overlander64's Avatar
Profile:  1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 104
Greetings ClassicRides!
Welcome to the Forums and the world of Vintage Overlander ownership!
Thanks in advance!
I am not a do-it-yourselfer, but did have my Overlander's bathroom refinished while in-place by a local professional who was recommended by my regular plumbing contractor. The gentlemen who refinished my bath indicated that the product he used was an epoxy from the same line that he utilized for home bathroom projects - - the only difference being that there were at least three different varieties of plastic/fiberglass (gelcoat fiberglass, ABS plastic, molded vinyl and "indeterminate acrylic/plastics") in my Overlander's bath that required the use of three different primer/topcoat products (from the same manufacturer) to achieve the desired results.
The refinishing of the bath in my coach included a change in color from the original Avacado Green in the before photo below:
to the Antique Pewter shown in the after photo, below:
This was the third season since the project was completed, and the finish still appears like new. I am very careful when cleaning and utilize Murphy's Oil soap when cleaning the fixtures.
Good luck with your project!
Kevin
Kevin D. Allen
AIR #827
Old 10-20-2004, 08:00 AM   #5
Snadi
Snadi's Avatar
Profile:  St. Matthews , South Carolina
Wow Overlander64, that looks fantastic! Would you mind sharing how much something like this costs?
Sandi Marshall
1982 Turbo Diesel 280 Motorhome!
WBCCI # 9316
Member SC Coastal Unit 150 and Friend of Chuck
Snadi is offline   Reply With Quote
Old 10-20-2004, 08:25 AM   #6
overlander64
Anna , Illinois
Images: 104
Greetings Snadi!
I don't have ready access to my records, but the cost was between $475 and $575 if my memory is correct.
Kevin
P.S.: Did a forums search for one of my earlier posts - - the cost that I remembered was for one of the higher estimates - - the firm that actually did the work charged only $395 - - the thread where this subject was discussed can be found at:
Sink and Shower restoration
Kevin D. Allen
AIR #827
Last edited by overlander64; 10-20-2004 at 08:44 AM. Reason: Clarification of cost.
Old 10-20-2004, 08:45 AM   #7
Snadi
Snadi's Avatar
Thanks for sharing!!!
Sandi Marshall
WBCCI # 9316
Old 10-20-2004, 10:24 AM   #8
ClassicRides
Profile:
Smile Metal Trim?
Thanks Sneakinup and Overlander64!
Both bathrooms look great! I'd love to use your photos on our TV series, "Classic Rides", which will chronicle our restoration (to air on the DIY Network in fall 2005). You can e-mail me directly.
Sneakin, what is the metal trim? Just flat trim - rivet in place? Glue?
No matter what, I think this process will be difficult and time-consuming - but well woth it for the new look. Yes, we'll remove the fixtures first! Thanks!
Old 10-20-2004, 11:56 AM   #9
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills , California
Images: 40
Thanks in advance!
My wet bath in the 1971 was re-done last year, and has held up exemplary!
It has held up to fallen opjects, sandy feet at beaches, shoe traffic, and many cleanings with mild soap. ( dish soap works fine, no abrasives recommendet or needed)
The tub/pan doubles as the bathroom floor in this set-up, and shows absolutely no signs of wear.
I used a mobile refinishing service, but I did have all the bath parts removed from the trailer for a rear floor replacement.
The material they used was a 4 component epoxy paint, of a brand that I had never heard of and have since forgotten.
I believe that 3 of the components were paint, reducer, and hardener, and teh 4th one was a coloring agent. The price seemed reasonable at the time, less than $ 300.00. I chose to use the service instead of a diy system, due to the toxic nature of the chemicals, and the lack of experience in prepping plastic for paint. I am very pleased with the outcome.
Uwe
The history of the Plastic Pink Flamingo thenewkid64 Off Topic Forum 6 06-29-2008 02:02 PM
Alternate exterior plastic parts repair IPM Bumpers & Bumper Storage 2 01-24-2008 10:46 AM
Rotary 12V Bath Vent Switch Condoluminum Electrical - Systems, Generators, Batteries & Solar 4 05-04-2004 08:02 AM
selling useful parts/30amp cord, pex crimper, bath paint Lexxy Parts Archive 2 05-03-2004 12:48 PM
Painting plastic walls and bathroom sink jwaldin Upholstery, Blinds, Walls & Interior Finishes 4 11-14-2003 08:37 AM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Yoga Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - U2 Forum
