Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > General Interior Topics
Old 06-01-2007, 08:26 AM   #15
JimGolden
JimGolden's Avatar
Profile:  1977 31' Excella 500
Let's Go!!!!!!!
Mountaineers!!!!!!!!!!!!!!
Maybe I'll see ya in the colliseum parking lot some Friday night for the pregame partying
- Jim
JimGolden is offline   Reply With Quote
Old 06-01-2007, 10:15 AM   #16
juel
juel's Avatar
Profile:  1978 Argosy 24
1976 31' Sovereign
Chandler , Oklahoma
Images: 24
A heat gun is better than a hair dryer; however, you need to use caution and not over-do it. Watch what you are doing closely and those flowers should release and peel off. I took the vinyl wall covering off the walls of my Argosy with a heat gun. Please watch how close you get and how long you leave it in one place. Heat guns are of course hot, but they will probably make this job easier.
juel is offline   Reply With Quote
Old 06-03-2007, 07:09 PM   #17
Ganglin
Ganglin's Avatar
Profile:  1971 27' Overlander
Gahanna , Ohio
Flowers Finally Gone
They are gone at last! I was right the PO did use some kind of additional yellow looking glue under them.
Ended up combining your ideas about heat and moisture, along with the goof off and a painters tool. We boiled a coffee pot full of water and poured about a cup on each decal - at the same time scraping with the painters tool and they came off. Then a little goof off to get the remaining adhesive.
Thank you all for the help - I didn't think they would ever come off. Photo below - along with the continuing floor project and the installed screen guards purchased from a fellow A/S Fourum member. Odd note on the floor. The plywood is dated 1-66 - stamped "interior use - exterior glue" - the trailer is a 71.
Thanks again!
ID:	38526  Click image for larger version
OHIO - WE ARE THE MOTHER SHIP
Gary
The good and bad TRAPEZE Airstream Motorhome Forums 1 01-01-2003 06:21 AM
Electric meter dienst1 Airstream Motorhome Forums 4 10-20-2002 09:17 PM
no power Mike Electrical - Systems, Generators, Batteries & Solar 10 08-20-2002 06:38 PM
Generator Paul Daugherty Airstream Motorhome Forums 19 08-09-2002 08:47 AM
Battery drained while on shore power 68International Electrical - Systems, Generators, Batteries & Solar 4 07-15-2002 02:51 PM
