Old 03-19-2012, 06:15 AM   #1
1989 34' Excella
Laurens , South Carolina
Back wall curvature
I'm sure I'm not the first to ask -- but my husband and I are doing some renovations on our '89 34' Excella. That dreaded back wall -- what's the easiest way to make a 'template' of the curvature from floor to window? We're attempting to make new bedside tables for the two back corners. Any help appreciated!
TinkersMom is offline   Reply With Quote
Old 03-19-2012, 06:49 AM   #2
1988 25' Excella
Trumbull , Connecticut
Hello TinkersMom. I found the easist way for me was to get a piece of white cardboard long enough to cover tha area you are interested in. Get a pair of draftmans dividers(one end needs a pencil) or a large compass. Place the cardboard on edge towards the wall so the top and bottom of the cardboard are touching the wall. With your dividers or compass place the tip of compass against the wall and the pencil tip on the cardboard. While holding the compass parallel to the floor move the compass up the wall and the pencil will scribe a line on the cardboard to the exact curve of the wall. Works for me.
Cappy camping nm1oqrz
nm1oqrz is offline   Reply With Quote
Old 03-19-2012, 09:29 AM   #3
1989 34' Excella
nm1oqrz
Thanks, nm1oqrz
That did help -- appreciate it !!!
Old 03-19-2012, 11:36 AM   #4
Skatiero's Avatar
1986 32' Excella
Canton , Georgia
That is pretty much how we did it as well. Craft paper helps a lot-- and the two corners are symmetrical, so you can actually do just one side and then make the mirror image for the other. We have an 89 as well, btw!
Skatiero is offline   Reply With Quote
Old 03-19-2012, 12:29 PM   #5
Frank&Mike's Avatar
2016 27' Flying Cloud
Georgetown , Texas
I had asked a similar question last year regarding making a template for the front curve. So I think the replies I received on how to make a template would also apply to the back of the Airstream. Following is the thread which explained how to accomplish this:
http://www.airforums.com/forums/f38/...rve-67325.html
Frank&Mike is offline   Reply With Quote
Old 03-19-2012, 12:43 PM   #6
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
The moustache trimming technique. Cut a little here and there until it's right. I ended up getting rid of the stache.
Old 03-20-2012, 02:39 PM   #7
CanoeStream's Avatar
St. Cloud , Minnesota
Ready for some reading?
Story stick to copy irregular shapes
Canoe cradle for Eddie Bauer
Template - Interior Front Curve
The Joggle Stick
How do you make a bulkhead?
Even between similar models, Airstreams are so handbuilt that each coach's curves are unique.
A story stick can be very accurate but you have to temporarily rig a piece of scrap plywood, particle board or cardboard (if you can keep it flat).
Pictures please as you go about your project!
5 meter Langford Nahanni
Old 03-20-2012, 05:16 PM   #8
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
I used a piece of the corregated plastic that is used for signs. It is stiff enough to stand upright. I used a compass, as described above to pencil a curve on the sheet. Sign shops may have scraps that would be cheap or free.
I found small, but noticeable differences between curb and road side of the trailer. I used braid from a hobby shop to trim where my new cabinets meet the wall.
John W. Irwin
WBCCI #9632
Cabinets not staying fastened to wall adwriter73 Cabinets, Counter Tops & Furnishings 21 09-08-2014 08:54 PM
Shower wall rebuild Joebanjo Sinks, Showers & Toilets 9 03-03-2013 11:09 AM
Wiring running thru wall/skin bbelanger Electrical - Systems, Generators, Batteries & Solar 2 03-16-2012 05:30 PM
Nice looking Ikea low-voltage wall lights chromis Lights - Interior & Exterior 9 03-09-2012 05:21 PM
