Old 12-01-2006, 11:21 AM   #1
guy99's Avatar
1984 31' Airstream310
Dunsmuir , California
Images: 16
Attaching trim
I'm in the process of finishing up a remodel on my 1984 310 Limited MH which was started (but not finished) by a contractor. He covered the bathroom ceiling with a vinyl covered luan. I am in the process of making cherry trim to cover the border of the luan with the original ceiling. See picture.
I plan to put cover the junction with a piece of trim. My question is how to attach it. I know there is a lot of wiring running in the wall and ceiling in this area so I don't want to drill any more than necessary. I'm wondering if exterior grade mounting tape (the gray stuff with the red wrapper) will hold?
Any thoughts, suggestions?
1984 310 Limited Motorhome
guy99 is offline   Reply With Quote
Old 12-01-2006, 11:31 AM   #2
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
You can use fast setting liquid nails just have supports ready to hold in place for 10 minutes.
Or use velcro perhaps
'77 Sovereign Intl 31' CB
Old 12-01-2006, 02:16 PM   #3
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
Guy- You are so right, wires, wires, wires. Double faced tapes have never been one of my favorite and we sell pallets of the stuff! I would be tempted to use a good 2 part epoxy; run a routed channel down the back side of your molding to give you more contact area and expansion room for the glue to dry. Use a good Blue Painters tape to hold things in place till the epoxy cures. Of course in 30 years when you go to redo the ceiling again it might not come off!
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 12-01-2006, 06:10 PM   #4
guy99's Avatar
Images: 16
Well, epoxy sounds scary. I wonder what would happen if I had a 1 x 1 3/4 piece of cherry epoxied to the ceiling and the motorhome twisted the way they some time do on uneven terrain or when raising and lowering the levelers?
Also I have had some failures with epoxy which I don't understand. I measured very carefully and mixed very thoroughly, but the epoxy didn't set in anything like the specified time.
How about if I drill a small number of holes (3 or 4) where the ribs are and on the outboard side of the junction I am covering. Then use a polyurethane adhesive? My thinking is that I'm less likely to hit wires if I'm going into a rib. I can use rivets or screws in these holes for a secure attachment and use the adhesive as backup and to avoid rattling etc.
So what do you think?
Other ideas?
Old 12-01-2006, 07:34 PM   #5
peegreen's Avatar
1998 31' Excella 1000
South Berwick , Maine
I installed a laminate floor (like Pergo) and the trim/transition pieces were glued down using Gorilla glue. A few years later and many miles, looks like the day it was installed.
WBCCI 24291
New England Unit
Metropolitan NY Unit
peegreen is offline   Reply With Quote
Old 12-02-2006, 01:05 PM   #6
guy99's Avatar
Images: 16
Was the trim glued to the laminate or the subfloor?
Would Gorilla glue adhere to the inner skin?
Old 12-02-2006, 02:50 PM   #7
peegreen's Avatar
The trim was glued to the laminate floor.
WBCCI 24291
New England Unit
Old 12-02-2006, 02:58 PM   #8
guy99's Avatar
Images: 16
OK, so they 'float' along with the floor. I have had Gorilla glue joints fail when stressed if mating surfaces didn't fit well enough. So, I'm wondering about gluing wood trim to the curved, textured, inner skin. Seems like an adhesive with some gap filling ability and flexibility might be better?
Suggestions anyone?
Old 12-02-2006, 04:25 PM   #9
peegreen's Avatar
Yes, the trim is attached to the floor so it behaves as one unit. With two boys, Gorilla glue is a staple in our house. Maybe something like Liquid Nails that is more flexible would work. I've seen it used to glue retaining wall blocks together.
WBCCI 24291
New England Unit
Old 12-02-2006, 08:00 PM   #10
Astrodokk's Avatar
1992 30' Airstream 30
Santa Rosa , Northern California wine country
Gorilla glue also expands quite a bit during curing and you may not be satisfied with that application. I've used epoxy before but for this I think it's overkill. I would use liquid nails or some other type of adhesive like the stuff used for vinyl baseboards. I've also used JB Weld but you'll need to mix alot and that will take time and something to support the wood. My girlfriend says to use a glue gun...that fixes everything!
1992 Airstream 300LE, rear queen, Banks Power!
Astrodokk is offline   Reply With Quote
Old 12-02-2006, 08:17 PM   #11
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Agree that Liquid Nails may be the way to go - take a look at a product they make called Quik-Grab. Line up carefully - when you set the trim in place - it's not going anywhere.
Old 12-16-2006, 01:39 PM   #12
guy99's Avatar
Images: 16
Well, the trim is installed
I ended up using exterior grade extra strong mounting tape plus rivets to attach the ceiling trim, I used liquid nails for the door opening trim.
Here's a before and after:
ID:	29820 Click image for larger version
Old 12-16-2006, 03:33 PM   #13
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
That came out good!!!!
Old 12-17-2006, 08:23 AM   #14
peegreen's Avatar
Nice work. Keep us posted to let us know how it's holding up.
WBCCI 24291
New England Unit
Aluminum Trim Source? melprice Cabinets, Counter Tops & Furnishings 6 09-08-2009 06:19 PM
Trim Paint Melissa Hamilton Clearcoat, Exterior Paint & Trim 3 07-17-2004 02:54 PM
blue trim molding larry smith Clearcoat, Exterior Paint & Trim 83 12-07-2003 11:04 AM
seal the bottom edge trim pieces? cindy Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 10-23-2002 09:18 AM
Exterior trim ALANSD Airstream Motorhome Forums 1 04-14-2002 07:53 PM
