Old 11-16-2006, 11:47 AM   #1
guy99's Avatar
1984 31' Airstream310
Dunsmuir , California
Images: 16
Attaching cabinet to the inner skin
We had a contractor remodel the rear of our 1984 310 Limited Motorhome. He replaced the North-South twin beds with an East-West king (72x74). To do this, one of the rear closets was removed. Also opened up the bathroom by removing the wall separating it from the hallway and moving the sink/vanity/medicine cabinet against the outer wall. Well, the fellow we hired to do this job did some nice cabinet work but never finished the job, I ended up just taking the motorhome back and have been trying to finish the work myself (The whole things is actually quite a story). Here is an issue I need help:
1. The medicine cabinet sits on top of the vanity and is attached to the outside wall. It was attached to the wall with a couple of screws. On our last trip, the screws let loose and the cabinet went flying, breaking one of the mirror doors and damaging the medicine cabinet. I have replaced the door and can repair the damage to the cabinet. But I need a secure, permanent means to attach the cabinet to the wall. The weight of the cabinet actually rests on the vanity so the attachment is need just to keep it in place. It was attached with two screws running through back of the cabinets and into the inner skin of the motorhome. Two problems with this, first the screws back out with travel, and, second when the road is real bad and there is allot of flexing they tend to pull out eventually requiring that I go to a large diameter screw. I can not see anyway to use a rivet through the cabinet and into the skin.
I tried to install rivet nuts in the skin so that I could run machine screws through the cabinet and into the rivet nuts. I've had no luck getting the rivet nuts to attach solidly to the skin. I think the skin is too soft to allow the rivet nuts to be securely mounted. Current ideas are:
1) I have some fairly large t-nuts with a flange that I think is large enough to allow me to drill 1/8 holes in the flange. I could then rivet the t-nut to the skin and then run machine screws through the cabinets and into to the t-nuts.
2) I could attach t-nuts or rivet nuts to a steel or hard aluminum plate, then rivet the plate to the skin, then run the machine screws through the cabinet and into the t-nuts.
I have attached some pictures which show the wall I need to attach to and with the cabinet in place
Any suggestions for a better approach or opinions about which of these would be better?
ID:	28693Click image for larger version
guy99 is offline   Reply With Quote
Old 11-16-2006, 12:29 PM   #2
2003 25' Safari
Eden Prairie , Minnesota
Perhaps the inner skin is too thin to structurally mount anything. Are the rivnuts aluminum or steel? Perhaps using aluminum rivnuts at ribs will work? Unfortunately, this may not match up with where you need the screws to go.
Dan
dmac is offline   Reply With Quote
Old 11-16-2006, 12:40 PM   #3
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
that is nice woodworking
'77 Sovereign Intl 31' CB
Old 11-16-2006, 12:48 PM   #4
RivetAddict
swebster's Avatar
1986 34.5' Airstream 345
Louisville , Kentucky
Overhead cabinets in the motorhome (and trailers I assume) are usually attached using a piece of angle aluminum (1 x 1 stock or heavy guage sheet stock which has been cut and bent up by the factory to fit the angle). This "bracket" is then rivited to the skin with large head rivets then the cabeint is screwed into the bracket. Many times this can be done on the inside of the cabinet so it is blind and unseen when looking at the cabinet. It is a good idea to get a couple of rivet on the rivet lines so you can pick up a structural rib, but most of my overhead lockers are simply riveted to the skin itself).
FYI - in addition to the overhead lockers, the top of the kitchen counter and the sofa and the bed are all attached to the walls this way.
You can get angle aluminum (and sheet stock) at Lowes and the rivets from Gainger. I have a box of 250 of these rivets (I needed about 50 but Grainger only sells "BIG" boxes) so PM me if you need a few.
Your pictures show a back panel to the cabinet and a top "header" which makes it look like you can't get up in there with a rivet gun or even a screw driver. Is it possible to get a picture of the back of the cabinet?
BTW - it looks terrific.
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
swebster is offline   Reply With Quote
Old 11-16-2006, 12:51 PM   #5
guy99's Avatar
Images: 16
The relative lack of strength of the inner skin is one reason I thought of using the plate since that would allow me to spread the load over a wider area.
I was using aluminum rivet nuts.
Based on the way the screw holes look, I'd say that it not a matter of the skin being too weak to take the load, rather there is too much stress for the soft aluminum at the fastener.
Old 11-16-2006, 01:13 PM   #6
guy99's Avatar
Images: 16
Originally Posted by swebster
...This "bracket" is then rivited to the skin with large head rivets then the cabeint is screwed into the bracket. ...
I assume you use sheet metal screws? No problems with them loosening with time? This is how I mounted our TV, I used two lengths of square stock which I attached to the side wall with sheet metal screws into ribs. Then I attached the mounting brackets to the square stock. It seems solid but I resolved to never remove the screws holding the square stock for fear that they would loosen up.
I tried something similar on the medicine cabinet, I riveted a hardwood 'nailer' to the skin, then drove wood screws through the cabinet into the hardwood nailer. This is how we got home from New Brunswick. The problem with this approach was that the hardwood was thick enough to prevent a flush fit of the cabinet to the wall. The same problem would rule out using angle or square stock. I could use flat stock as long as it isn't too thick. How thick does it need to be to hold the screws permanently?
This is the reason I was thinking of using a 'plate' with t-nuts and machine screws. I could mount the t-nuts so their flanges were flush to the plate, with the body of the t-nut projecting into a hole in the skin and I could use lock-tite on the machine screws.
Thanks, I'll get some more pictures.
Guy
Old 11-16-2006, 02:03 PM   #7
RivetAddict
swebster's Avatar
Actually you should use large head blind rivets. They sell em with a .65" head on them....it's the same type used by the factory.
You are right in that the angle speads the load out but since the rivets use such a wide head and require a small hole (1/4") they don't "tear out".
Here is a rough image of what I mean...
Steven Webster
AIR 1760
Old 11-16-2006, 02:26 PM   #8
guy99's Avatar
Images: 16
Steve,
Your picture is very clear. In my case I will need to drive whatever fastener I use through the cabinet into whatever I mount to. Since I would be going through the cabinet and into the bar stock, I was thinking about using the sheet metal screws.
In any case I don't see how I could exactly follow your example since the cabinet follows the contour of the motorhome exactly.
Here are some pictures of the back of the cabinet and the mounting holes:
Notice how the back is pretty much flush with the contour of the sides, this leaves very little space betwen the skin and the back of the cabinet.
Old 11-16-2006, 04:54 PM   #9
RivetAddict
swebster's Avatar
Guy,
Wow...the back panel makes mounting it through those holes pretty hard. Since it's a flush fit there is no relief at all for even the flat stock without standing the cabinet off the wall a little.
Is that trim piece at the top easily removed? I noticed the cavity in the top of the cabinet would be perfet for mounting a bracket, but you would need to screw through the face. If you counter sunk the screws into a bracket on the back of the top then you could cover them with than trim again.
Steven Webster
AIR 1760
Old 11-16-2006, 04:56 PM   #10
RivetAddict
swebster's Avatar
One other idea....what about a couple of screws coming into the side of the cabinet through that bulked it sits up against? (Of course this is where you tell me the shower is on the other side of the bulkhead). Then the other screws would simply quiet the rattles instead of support all of the weight.
There are a number of cabinets in my 345 mounted like that (screws through the adjacent bulkhead)
Steven Webster
AIR 1760
Old 11-16-2006, 05:12 PM   #11
guy99's Avatar
Images: 16
Guy,
Good idea, I'll examine what I'd have to do to R&R that trim piece. I need to replace the back panel of the cabinet to repair the damage that occured when it came loose. Also will need to touch up the finish in several spots .
Old 11-16-2006, 05:22 PM   #12
guy99's Avatar
Images: 16
Well, no that isn't the shower wall but it is a wall put in by my contractor. I have a problem with this wall in that it won't stay attached to the ceiling and flexes for and aft at the top edge. This is another problem I need to sort out. I'll be posting on this when I figure out how to mount the medicine cabinet.
As far as holding the weight, the cabinet actually sits on the vanity counter so the mounting doesn't need to carry much weight. The problem is that as things flex and shake the screws loosen, when they come all the way out the cabinet swings away from the wall at the top and smashes itself and other things. It almost seems like I'd be better off with an attachment system that had some 'give' in it so things could flex without breaking.
Old 11-17-2006, 11:51 AM   #13
guy99's Avatar
Images: 16
Do you think fasteners like this would work? I could put the cabinet in place and then set them from the outside.
Has anyone ever used molly or other anchors? Does they work on the inside skin?
Old 11-17-2006, 12:09 PM   #14
Attachment 28722
Those fasteners, in time, come loose because of vibration during normal towing.
Alum. Skin Repair 74Tradewind Ribs, Skins & Rivets 12 10-31-2009 01:30 AM
Belly skin alternatives? Sneakinup Belly Pans & Banana Wraps 27 04-23-2004 06:33 PM
Attaching Awning Brackets Mike Rhodes Awnings 7 10-30-2002 07:35 PM
Door and cabinet knobs jcanavera 2001 Safari 0 07-07-2002 10:19 PM
Cabinet roll up doors niftypkg Cabinets, Counter Tops & Furnishings 2 05-10-2002 07:22 PM
