Old 11-17-2006, 12:18 PM   #15
guy99's Avatar
1984 31' Airstream310
Dunsmuir , California
Images: 16
Those fasteners, in time, come loose because of vibration during normal towing.
Andy,
How about molly's , they seem very similar to olymic rivets in the way they function?
Got any other suggestions to solve this problem?
1984 310 Limited Motorhome
guy99 is offline   Reply With Quote
Old 11-17-2006, 12:32 PM   #16
Originally Posted by guy99
Andy,
Use screws, pop rivets or olympic rivets.
Molly's come loose. Same with drive rivets.
Old 11-17-2006, 12:47 PM   #17
guy99's Avatar
Images: 16
Where can i find rivets with a 1" grip range ?
Old 11-17-2006, 01:37 PM   #18
RivetAddict
swebster's Avatar
1986 34.5' Airstream 345
Louisville , Kentucky
The .65" rivets I sent match those used by the factory to secure the couch to the wall. I'd say maybe eight (8) rivets in total.
the trick is to use bar or angle stock as a "nailer" (or screwer in your case)...attach it to the wall using these mondo rivets and then secure the cabinet to the bar or angle.
The best way is through the bar stock or angle and into the wood (not the other way around) but in your case you might have to consider sheet metal screws through the wood and into the metal. Perhaps even really thick metal and a tapped thread to access a machine screw with some lock tite and lock washers on it.
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
swebster is offline   Reply With Quote
Old 11-17-2006, 01:53 PM   #19
Depending on the diameter you need, McMaster-Carr has them.
Old 11-17-2006, 02:50 PM   #20
guy99's Avatar
Images: 16
If I understand it the purpose of the 'nailer' is to distribute the load over several rivets - am I correct?
If so, I should be able to put at least four rivets through the cabinet into the inner skin - if i can get rivets with an adequate grip range.
Woud 4 rivets be enough if I can get them in?
Old 11-17-2006, 04:11 PM   #21
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
You can use mollys, just use Loctite on the threads, if they come loose I would be very suprised
They are very much like the rivet.
'77 Sovereign Intl 31' CB
Old 12-16-2006, 01:34 PM   #22
guy99's Avatar
Images: 16
Well, it's installed
I attached some bar stock to the wall using several large head rivets provided by member swebster, then used a couple of long rivets obtained from the source mentioned by Inland Andy to go through the cleat in the cabinet, into the bar stock and wall. I am confident that its going to stay put.
Old 12-16-2006, 02:46 PM   #23
RivetAddict
swebster's Avatar
nice job...nice interior too!
Steven Webster
AIR 1760
Alum. Skin Repair 74Tradewind Ribs, Skins & Rivets 12 10-31-2009 01:30 AM
Belly skin alternatives? Sneakinup Belly Pans & Banana Wraps 27 04-23-2004 06:33 PM
Attaching Awning Brackets Mike Rhodes Awnings 7 10-30-2002 07:35 PM
Door and cabinet knobs jcanavera 2001 Safari 0 07-07-2002 10:19 PM
Cabinet roll up doors niftypkg Cabinets, Counter Tops & Furnishings 2 05-10-2002 07:22 PM
