Old 11-01-2004, 10:59 AM   #1
BURNZEE's Avatar
Are these original?
I'm restoring a 66 Safari and have a question. Under both of the front side windows are thin aluminum "tracks". They don't appear to be original as it looks like the snaps for the curtains have been relocated to below them. I would like to remove if not original. Anyone know what they would have been used for? Thanks. I love this forum. Has already helped me enormously.
ID:	9312   Click image for larger version
BURNZEE is offline   Reply With Quote
Old 11-01-2004, 12:17 PM   #2
Ken J's Avatar
1956 22' Flying Cloud
Durango , Colorado
Images: 14
Those tracks are original - can't tell how many snaps you have, but if they are at the ends of the tracks, they are to keep the curtains in place - so you would use both the tracks and snaps
Ken
1956 Flying Cloud
Founder :
Four Corners Unit
Albuquerque National Balloon Fiesta
Rally
Vintage Trailer Academy - Formerly the original
restoration rally
Ken J is offline   Reply With Quote
Old 11-01-2004, 12:29 PM   #3
BURNZEE's Avatar
Thanks Ken. The buttons are below the tracks as shown in the second photo. There is a hole behind the track that is in the same location as the snaps on the other windows. Also, the tracks are wider than the curtain track at the top so I don't understand how they would work.
Old 11-01-2004, 12:55 PM   #4
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
I'm not an expert, but...
I don't think they are original. I looked at other '66s in the Vintage Photo Archives and didn't see anything like them. Given, that's just a small sampling...
Any '66 owners out there?
Shari
Old 11-01-2004, 01:07 PM   #5
Ken J's Avatar
Durango , Colorado
Images: 14
Those tracks are very similar to what I have in my 75 - that rear track makes the curtain go all the way across the wall over the bed. Perhaps they are original to that year, but they appear to be Airstream issue. Maybe someone upgraded in the 70's ?
Ken
1956 Flying Cloud
Founder :
Four Corners Unit
Rally
restoration rally
Old 11-01-2004, 01:11 PM   #6
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
Hi, I dont have the tracks on my 67 Safari. Hopes this helps. Lee
silverleeper is offline   Reply With Quote
Old 11-01-2004, 01:15 PM   #7
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
I've looked at your pictures several times, and I do not think the lower pieces of aluminum are original. I am under the impression that the '66-'69 model years had many similarities, and my '67 Overlander does not have a lower rail. Elastic strings hold the lower portion of the curtains.
Look at the size of the rivets holding the rail in place - There are no rivets that big on the inside of my Airstream.
If your upper curtain rail looks mine (in the picture below), I would say there is a strong possibility that your original curtains were supported at the bottom like mine are. You might want to contact Jim Ambruse (sp?) Inc. His only business is Airstream curtains.
Tom
Old 11-01-2004, 01:15 PM   #8
Ken J's Avatar
Durango , Colorado
Images: 14
Welp - sounds like I am wrong - they do look just like the one's in my 75 though.
Ken
1956 Flying Cloud
Founder :
Four Corners Unit
Rally
restoration rally
Old 11-01-2004, 01:34 PM   #9
InsideOut's Avatar
1956 22' Safari
Images: 108
I could see where they might be original if you have a front gaucho & side attached tables like in this '66 TradeWind. It could be a bracket to support the wood ledge or the table...
But, that wouldn't explain the snaps below it for the curtains...and your strip looks higher than this ledge would be. Also, it doesn't look like it's on both sides in the archive photos like in your trailer...
Shari
Old 11-01-2004, 02:23 PM   #10
BURNZEE's Avatar
Thanks for all the replies.
Tom, I just checked and the rivits appear to be the same size. One thing that's hard to see from the pictures is that they are straight pieces and have popped the rivits loose where they have to bend with the curve of the wall.
Shari, I also have the same tracl over the table on the other side by the door. (photo attached). My guess now is that they are not original and were added later. I'll most likely take them out and attach the curtain bottoms with the snaps/elastic/plastic rings. I'd really like to know that they were used for?? Curiosity is killing me. I've also posted a fuzzy photo of a small clamp that can adjust along the track. Thanks again for the info.
ID:	9319   Click image for larger version
Old 11-01-2004, 02:36 PM   #11
InsideOut's Avatar
1956 22' Safari
Images: 108
Me too!
If only our vintage trailers could talk...the stories they would tell!
Shari
Old 11-02-2004, 07:46 AM   #12
eljay's Avatar
1968 24' Tradewind
Rural, blink and you'll miss it , Missouri
These are not on my 66 Tradewind which seems to be about as original as they get. LJ
eljay is offline   Reply With Quote
Original Floor??? blrpix Repairing/Replacing Floor &/or Frame 17 08-12-2004 05:47 PM
Original LOOKING interior lights for vintage trailers flamingo-kid1 General Interior Topics 0 04-18-2004 08:04 PM
What were the original window covers or shades?? IPM Airstream Motorhome Forums 3 04-07-2004 07:25 PM
Is A/C original? whistler Furnaces, Heaters, Fireplaces & Air Conditioning 2 01-19-2004 04:32 AM
