Old 01-22-2010, 03:10 PM   #1
2010 27' FB Classic
N/A , Texas
Antifreeze stain in fiber glass shower
I'm trying to find info for a friend who has an older trailer. Is there a cleaner to remove an antifreeze stain in the fiberglass shower/tub area? The stain looks to be several years old. Probably dripped from the spigot and not noticed for a long time.
Old 01-23-2010, 06:06 AM   #2
Lily&Me's Avatar
Normal , Illinois
Try a little Softscrub, the kind with a little bleach in it.
Old 01-23-2010, 07:04 AM   #3
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Tougher...SS with magic eraser/scotchbrite
toughest...wet sandpaper, repeat above.
PFC
but I’m the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 01-23-2010, 07:40 AM   #4
1994 30' Excella
Mississauga , Ontario
Are you sure it isn't an iron stain from water drip? I have not heard of antifreeze making a stain. In fact when I winterize I don't worry about spills in the shower or sinks. They rinse right out when I do my spring cleaning.
If iron stains try CLR or naval jelly. Yacht outfitters usually have good rust removers.
Al
Old 01-23-2010, 11:31 AM   #5
gloran's Avatar
1993 33' Land Yacht
Midland , Michigan
I've had good results with Zuds non-abrasive cleanser.
gloran - 1993 LY MH 33' - Banks System, Steer Safe, IPD front stabilizer, Super Steer - Bell Cranks, Motion Control, Coil
http://s1290.photobucket.com/user/gl...58808196506793
gloran is offline   Reply With Quote
Old 01-23-2010, 03:11 PM   #6
2010 27' FB Classic
N/A , Texas
I looked at it and it's not an iron stain. It's pink and looks just like the antifreeze we all use. Thanks for the help, we'll have to try some of the suggestions, I am just affraid to ruin tub for them, so I'll have them try out the mild stuff then on to the more heavy duty scrubbers, etc. We tried a fiberglass cleaner and it did nothing, Fantastic did nothing, Lysol, nothing.
Old 01-23-2010, 03:16 PM   #7
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
I've used Clorox Clean-up on antifreeze stains in my shower. Just let it sit on there for a little while & it should take the pink off.
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 01-23-2010, 05:14 PM   #8
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
We usually have a slight stain if some antifreeze drips out. I use Soft Scrub when I dewinterize to take it out. Not really a big issue. Not sure how good it would work if it's sat for years.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 01-28-2010, 11:59 AM   #9
2010 27' FB Classic
N/A , Texas
Bought some and will try it soon. Used some around the house for other stuff and it works really well. Thanks!
Fiber Glass Roof leaks LY 350 Motor Home myfirstrv Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 21 02-15-2016 04:24 AM
Stripping the stain bevman Cabinets, Counter Tops & Furnishings 10 06-18-2007 09:54 AM
Shower Glass/ Curtain tmeagle1 Sinks, Showers & Toilets 10 01-04-2007 04:12 PM
Stain Removal arodriguez60 Cabinets, Counter Tops & Furnishings 5 03-30-2005 12:46 PM
Color of Stain???? srgntpepper Cabinets, Counter Tops & Furnishings 4 10-26-2003 09:20 PM
