Old 12-30-2014, 01:34 PM   #1
TMT
TMT's Avatar
1974 23' Safari
2005 22' Interstate
Jacksonville , Florida
Aluminum walls are cold!
We just camped for the first time in our new to us 2005 Airstream Interstate.
It was in the low 40's at night, and we did have the heater on appropriately.
But boy, those walls beside the bed are really cold! COLD!
I would love to hear what some of you have done to combat those cold walls. You just can't help but touch them somethings during the night.
Thanks!
Melaine Taylor
Life Is A Journey - Enjoy the Ride!
TMT is offline   Reply With Quote
Old 12-30-2014, 02:08 PM   #2
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Name:	ImageUploadedByAirstream Forums1419973649.629159.jpg
Yea probably a bit extreme for most folks, but it really does help...
1/2 Ton 4WD Truck, 72 Sovereign Hensley Arrow
Old 12-30-2014, 02:13 PM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
That is the nature of aluminum. The walls next to my bed, up to the windows, are covered with velvet cover batting. Above that there are curtains in a tract. We still radiate to the cold walls but if we touch the covering it is not cold to the touch.
Aluminum is probably the worst material one could pick to make trailer of if maintaining a comfortable temperature was a consideration.
2004 Excursion 4x4
Old 12-30-2014, 02:33 PM   #4
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
The 70's trailers have an upholstered pad that is mounted to the wall just above the bed. If you roll over at night you will hit it rather than the cold aluminum.
Aaron
WBCCI #XXXX AIR #2495
Old 12-30-2014, 02:51 PM   #5
1978 Argosy 24
MooreHaven , Florida
What Wahoonc said! Must have been a good idea,since they seem to have abandoned it on the newer trailers. Ours was a material that matched the Gaucho upholstery,we are going to recover it over what is there to add to the insulating quality,but with some materiel matching the colors we have now.
This is only temporary unless it works! Red Green
oldiesel is offline   Reply With Quote
Old 12-30-2014, 02:57 PM   #6
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Later-model Interstates replace the bare aluminum with aluminum covered in the infamous "imitation mouse fur" (actually a velour material notoriously easy to get dirty and hard to clean). That could be your answer; cut velour fabric to fit, and glue it in place, like a cloth version of wallpaper.
On Edit— Forget gluing it in place. Stick it up with Velcro, or snaps, or grommets, so that you can remove it to throw the covering into the wash…
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 12-30-2014, 03:00 PM   #7
Ray Eklund's Avatar
2014 25' International
Boulder City , Nevada
Our 2006 Safari had an insulated textured material covering the interior. It was like having cellophane windows to keep out the cold.
When it was 18 degrees on a July camping trip in Wyoming one morning... my tongue stuck to the fabric. That is how cold it was.
Have you tried this test when it is 18 degrees with an aluminum interior? I am looking for a volunteer to try this on our latest aluminum interior finish model. I might have been dehydrated when I did the test in the 2006 on fabric.
The only long term WINTER CAMPING within an Airstream worth considering... would be in Miami, Florida.
Ray Eklund is offline   Reply With Quote
Old 12-30-2014, 03:04 PM   #8
2015 30' FB FC Bunk
Ayer , Massachusetts
I totally agree. Aluminum is a fantastic conductor. My company performs energy models for new buildings, if we tried to model an aluminum house it would fail so bad.
Even knowing this, I just had to have an Airstream. Because they're cool. No pun intended.
Ted S. is offline   Reply With Quote
Old 12-30-2014, 03:14 PM   #9
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
Just be patient. Summer will come and the aluminium with be hot!
Dave
"LOVE and LOSS, are two of the greatest emotions one can experience. -- I went to school to learn about "WHAT GOES UP MUST COME DOWN" but I had to live my life to learn the lesson of: 'WITH LOVE THERE WILL BE SORROW'."
David Stewart. (after loosing my NAVIGATOR)
Old 12-30-2014, 03:29 PM   #10
Nomad518's Avatar
2001 25' Safari
Vancouver , Washington
Our 2001 Safari (70th Anniversary Model) has the white mouse fur wall coverings. It provides a bit of insulation, but it can still get cold. My wife sleeps on the side of the bed by the wall. I always try to snore really loud to give her something to focus on other than the chilly wall. That's worked pretty well for me so far. Try asking your husband to do that for you. Or, have him sleep by the wall and see how quickly he comes up with a solution.
Nomad518 is offline   Reply With Quote
Old 12-30-2014, 03:39 PM   #11
MarkE's Avatar
1969 18' Caravel
, Iowa
On my '51 FC I installed carpet, matching that on the floor, on the walls directly touching the beds. I used a wood trim strip along the top edge of this carpet (matching the original woodwork). It looks sharp and sure is an improvement over rolling over, in the night, to be shocked awake by that cooooold aluminum wall!
MarkE
WBCCI #4568
MarkE is offline   Reply With Quote
Old 12-30-2014, 04:41 PM   #12
TMT
TMT's Avatar
1974 23' Safari
2005 22' Interstate
The idea of placing a sort of batting or fabric insulation on the walls with velcro may be very workable. That's why I love this group. Always lots of ideas and willing to share! Thanks.
Melaine Taylor
Old 12-30-2014, 04:51 PM   #13
If you do use Velcro, put the hooks on the fabric, and the loops on the walls. That way, when the fabric isn't there, you don't have scratchy strips on the walls, you have fluffy strips on them. Much more comfortable to accidentally rub against.
WBCCI #1105
TAC LA-4
Old 12-30-2014, 04:54 PM   #14
While we're discussing fabric on the walls, if you sew pockets into the fabric, you will also have a new place to tuck your TV remote, the book or Kindle you were reading, your eyeglasses, whatever.
WBCCI #1105
TAC LA-4
Heat Pump - How cold its too cold? VeggieBullet Furnaces, Heaters, Fireplaces & Air Conditioning 7 01-09-2014 06:03 PM
Cold Aluminum! Headboard ideas? jasperkins Eddie Bauer - All Models 22 12-01-2013 06:18 PM
Interior walls sweating in cold LI Pets General Interior Topics 68 08-20-2012 02:19 PM
Brrrrr... cold aluminum wall! longdog 2007 Safari SE 5 05-07-2009 05:56 AM
Aluminum Walls Buzzy4 2006 Safari SE 2 09-29-2005 09:05 AM
