Old 12-30-2014, 05:02 PM   #15
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
Try a yoga mat or one of those closed cell foam mats used in the gym for floor work. They are fairly thin but have some insulation value. I would use Velcro to attach to the wall so you could remove for cleaning and/or aesthetics. Either can be cut down to size.
Bob Martel
WBCCI# 5766
Old 12-30-2014, 05:09 PM   #16
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
Eastern , Washington
Images: 90
I had stock wall pads on a 70s model and took them apart to reupholster. They were corrugated cardboard wrapped in batting and then covered with fabric. No sewing - this is a glue gun project. They were riveted onto the walls. I reused the cardboard and they were surprisingly effective.
AirForums Custom Search
Janet H is offline   Reply With Quote
Old 12-30-2014, 05:32 PM   #17
Rollster's Avatar
Saint Augustine , Florida
My husband uses one of those body pillows along the wall in winter. It takes up less room than me and doesn't snore or steal the blankets!
Carol, Aboard "Aggie the DreamStream"
WBCCI# 5248
Rollster is offline   Reply With Quote
Old 12-30-2014, 06:10 PM   #18
2002 19' Bambi
Lafayette , California
We made a cozy pad with fleece on both sides and polyester batting inside. It is about 10 inches high and attaches all around the aluminum walls of the bed. The attachment is snaps to allow removal for washing. We camp each year where it is very cold at night and the pad was our reaction to the first year there! Our walls have the mouse fur, but the cold wall was bad anyway. I hate to think about what the bare aluminum is like.
Tim
Tim A. is offline   Reply With Quote
Old 12-30-2014, 06:32 PM   #19
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Fwiw, last winter in Lubbock, I was able to keep the Airstream toasty warm in low teen weather with a single space heater....
1/2 Ton 4WD Truck, 72 Sovereign Hensley Arrow
Old 12-31-2014, 10:37 AM   #20
1988 32.5' Airstream 325
Rio Rancho , New Mexico
Camping in the cold
We have a AS 325 MH. We woke up one winter morning outside of Albuquerque NM in late January 2011 and it was -6 degrees! That's 6 degrees below zero! Yes, the walls by the beds in back were cold and they are covered with a velour material. This was our answer, we had electric mattress covers and oversized feather bed quilts on each bed. The beds were VERY warm and toasty. Our problem was the water lines froze!
GTOChucky is offline   Reply With Quote
Old 12-31-2014, 11:20 AM   #21
2014 28' International
San Jose , California
this is really interesting ... I have been considering velcro for lots of stuff but, ...... what keeps stopping me is this. If I decide that I want to move/remove the velcro strip attached to the aluminum wall, will I have a remaining mark on the aluminum wall?
Makaira is offline   Reply With Quote
Old 12-31-2014, 11:31 AM   #22
silver.villa
silver.villa's Avatar
2011 20' Flying Cloud
Albuquerque , New Mexico
We finally came up with a solution that works great for us. These sleeping pads from Walmart provide just enough of a barrier to keep those cold walls away from us. We originally used them "as is" without any sort of cover but found that condensation would build up between the pad and the walls. I sewed some pad covers out of inexpensive heavy weight upholstery fabric and that took care of the moisture prob as well as adding a bit of insulation. We just tuck them in between between the mattress and the trailer wall of the front bed using extra pillows to help keep them upright. We also use them on the dining table bed tucking them between the mattress and outside wall AND using clothespins and elastic to keep them from flopping over. One of our dogs sleeps in the doorway space so we cut a pad to fit to insulate that area for him. The pads are easy to roll up and store in the off season or leave them flat and store under the mattress full time. Walmart: Stansport Pack-Lite Camping Pad
silver.villa is offline   Reply With Quote
Old 12-31-2014, 01:04 PM   #23
Regular Guy
NavyCorpsman's Avatar
1978 31' Sovereign
Hot Springs , Arkansas
I'm not sure what your bed arrangement is, but in my Sovereign there are upholstered panels mounted on the wall side of the twin bed, and behind the sofa. It's constructed of 1/8 inch Masonite , thin foam under fabric which is secured with glue and screwed into the walls. My 11y/o nephew and I, camp at least 2-3 times a month. Last night it was around 25F. The strip heater kept it very tolerable.
Happy New Year!
NavyCorpsman is offline   Reply With Quote
Old 12-31-2014, 01:21 PM   #24
Forrest's Avatar
1986 32' Excella
Aurora , Colorado
Images: 21
I attached indoor/outdoor carpet on the walls adjacent to the bed. It's inexpensive, light weight, easy to trim to size and comes in complimentary colors. The top of the carpet is easily held in place by sandwiching it between the lower curtain railing and wall.
Forrest
Out for coffee!
Forrest is offline   Reply With Quote
Old 12-31-2014, 01:23 PM   #25
Janet H's Avatar
1964 26' Overlander
Images: 90
Lots of great ideas here... taking notes for the next project
Old 12-31-2014, 01:24 PM   #26
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
My 86 Safari has mouse fur walls. Much better insulation than bare metel.
MICHAEL
Old 12-31-2014, 01:47 PM   #27
2010 20' Flying Cloud
Cypress , Texas
Originally Posted by TMT View Post
We just camped for the first time in our new to us 2005 Airstream Interstate.
It was in the low 40's at night, and we did have the heater on appropriately.
But boy, those walls beside the bed are really cold! COLD!
I would love to hear what some of you have done to combat those cold walls. You just can't help but touch them somethings during the night.
Thanks!
I made an adult-sized "crib bumper" for our 2010 Flying Cloud 20'. I cut a 7' length of 1 inch thick white urathane foam, seven inches wide. This strip reaches from the head-end hamper to the one at the foot of the bed. I wrapped this with quilt batting, and sewed a long, skinny "envelope" made from part of a fleece blanket in a color that coordinates with the color scheme of our trailer. I turned the fabric after sewing right sides together, inserted the foam core, then whip-stitched the opening by hand. Inserted it between the mattress and the wall. Works like a charm! Some trailers come equipped with built-in fasteners for commercially made bumpers, but not our 2010 FC20. You can purchase ready-made "core" material at Hobby Lobby, but it's more expensive. It's a fiber-filled batting material about an inch thick.
Hope I've provided you with understandable directions.
RoadCessna is offline   Reply With Quote
Old 12-31-2014, 04:14 PM   #28
2005 28' International CCD
San Jose via Winnepeg, Toronto, Orlando, Saratoga and Groton , California
Send a message via AIM to tyggeln Send a message via MSN to tyggeln Send a message via Yahoo to tyggeln
Conduction Paths
Originally Posted by Ted S. View Post
I totally agree. Aluminum is a fantastic conductor. My company performs energy models for new buildings, if we tried to model an aluminum house it would fail so bad.
Even knowing this, I just had to have an Airstream. Because they're cool. No pun intended.
The exterior skin is cold, due to radiation to the night sky (3.7 deg K cosmic background) and also convection with the cold air. The radiation component will make the skin even colder than ambient on a clear night.
Though the warm zone is insulated with pink in the airspaces between the skins, the insulation is defeated by excellent conduction paths from the cold exterior skin via the structural rubs leading to cold interior aluminum skin. You can see the effect in where condensation forms inside on the bare Al.
Aluminum home windows can be warm if the conduction paths are interrupted. In the airstream trailer what us needed would be a thermal barrier between the exterior skin and the ribs. Much easier would seem to be a nonconducting barrier between the interior skin an the structure ribs either during initial construction, or during interior refurbishment/remodel.
2005 28' CCD International
2x120W Solar Panels/22A GoPower Controller
1200# Equalizer Hitch
2007 GMC Yukon XL SLT
"Where are my keys?"
tyggeln is offline   Reply With Quote
Heat Pump - How cold its too cold? VeggieBullet Furnaces, Heaters, Fireplaces & Air Conditioning 7 01-09-2014 06:03 PM
Cold Aluminum! Headboard ideas? jasperkins Eddie Bauer - All Models 22 12-01-2013 06:18 PM
Interior walls sweating in cold LI Pets General Interior Topics 68 08-20-2012 02:19 PM
Brrrrr... cold aluminum wall! longdog 2007 Safari SE 5 05-07-2009 05:56 AM
Aluminum Walls Buzzy4 2006 Safari SE 2 09-29-2005 09:05 AM
