Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > General Interior Topics
Old 07-31-2007, 05:56 PM   #1
2007 25' Safari FB SE
Lake Forest , Illinois
Airstream Smell or is it an Odor?
Our AS is new this year and at first there was a smell of new materials. That has given way to what I can best describe as an unpleasant unfresh odor. Our holding tank has been cleaned and recycled and we use a small packet of chemicals (supposedly safe) that is flushed down the toilet. Even with the windows open there is a hint of the odor. I would be interested in what other AS owners use to freshen the air quality, especialy when the trailer is closed.
woodedareas is offline   Reply With Quote
Old 07-31-2007, 06:11 PM   #2
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
odor
Check for leaks. There should not be an odor. How about the fridge? Other food?
Old 07-31-2007, 06:22 PM   #3
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
There shouldn't be an odor, unless you use the facilities and have the Fantastic vents running or vent in the bathroom when you flush. It can draw air through the vent pipe, into the tank and into the trailer via the head, chemicals added or not and that smell can linger a bit after it happens....ask me how I know....
Old 07-31-2007, 06:55 PM   #4
ScottW's Avatar
Hernando , Mississippi
If it has been really hot and the trailer has been closed up, it could be formaldahyde (spelling?) fumes...or fumes from the upholstery, etc. Just air it out...should be OK.
Rgds,
Scott
Air 16426
Fully retired now!
Remember:
Never start anything before noon and always plan on being finished by 5.
I will never HAVE to be anywhere ever again!
ScottW is offline   Reply With Quote
Old 07-31-2007, 06:57 PM   #5
Retired.
. , At Large
Ours had "that smell", it turns out that the toilet gasket was not seated properly (wadded up on one side), and the cap for the plumbing inside the coach was not tight. Both allowed fumes from the black tank to seep into the bathroom.
Old 07-31-2007, 07:01 PM   #6
Halimer
2006 25' Classic
New Hyde Park , New York
The smell maybe of the coils heating up on the frig. Mine gave off an odor for about a week.
halimer is offline   Reply With Quote
Old 07-31-2007, 08:51 PM   #7
More than one rivet loose
thecatsandi's Avatar
Los Alamos , New Mexico
Vent stack leak?
Michelle TAC MT-0
Sarah, Snowball
Old 07-31-2007, 08:59 PM   #8
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
You've been given good advice so far. Also make sure you have a little water in the toilet, enough to cover the seal. Odors can seep through there, too.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
https://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 07-31-2007, 09:31 PM   #9
Harry W's Avatar
1978 31' Sovereign
Scottsdale , Arizona
Unusual Odor Source
If the odor persists after you have tried the above suggestions, we had an odor problem with our 78 Sovreign. We replaced the toilet, carpet, mattress, gaucho mattress, and scrubbed the entire interior. Still, the odor persisted.
After the unit was in storage for about 3 months, the odor finally disappeared. I plugged the unit in to charge the battery, and the smell came back. The Univolt was the source all along and a new one cured the problem.
Your unit is new, so this is a long shot. But, stranger things have happened.
HarryW
Harry W is offline   Reply With Quote
Old 07-31-2007, 10:33 PM   #10
dscluchfc's Avatar
1984 31' Excella
Abernathy , Texas
could be the tube from the toilet to the black tank needs a scrubbing....hold the flapper open and brush it good with some soapy cleanser such as Lysol.
then turn on the water and rinse it while brushing all the way up and down the tube.
David
TAC # TX-18
AIR # 410
https://www.flickr.com/photos/dsphotoscapes
dscluchfc is offline   Reply With Quote
Old 08-02-2007, 05:37 AM   #11
Silver Lamb
EweMama's Avatar
1969 27' Overlander
1961 16' Bambi
Bonner Springs , Kansas
Red face
Putting new bar(s) of Zest in our Airstreams retards that stale smell of a closed up AS. If all those other solutions have been checked, try this.
p.s. Remember to put those Bounce sheets in many places to retard unwanted "visitors" during storage.
EweMama is offline   Reply With Quote
Old 08-02-2007, 06:16 AM   #12
yukionna's Avatar
Massachusetts
Images: 18
Send a message via Yahoo to yukionna
Zest soap is a great idea! I've tried the bounce sheets myself and found they didn't work -- the mice actually used them as bedding material!
WBCCI Region One
Attitude is the only difference between ordeal and adventure
yukionna is offline   Reply With Quote
Old 08-02-2007, 06:49 AM   #13
Retired.
. , At Large
You can also get a couple of boxes of baking soda, open the tops, and leave them until you are ready to move the trailer. They will absorb odor as well, and are pretty cheap.
Old 08-02-2007, 07:23 AM   #14
2017 27' Flying Cloud
Altoona , Florida
Go for the source - something is causing it - check with your dealer! A new Airstream should not stink. A vent pipe could be plugged or have come apart.
Poprivet is offline   Reply With Quote
Old 08-02-2007, 09:59 AM   #15
Wabbiteer's Avatar
Jupiter , Florida
Air pressure changes from wind and vibrations of occupants moving around can cause the water in the traps to migrate from the elbows allowing small burps to constant drafts of air to infiltrate from the pipes, if not the tanks.
Keep the water refreshed in all drains with a cup or so as needed, and use the stabilizers to reduce any rocking motion that can coax water to siphon away from the trap elbows. Gasketed stoppers are in use on mine whenever I am not running water.
My vintage PVC piping above the floor line was much worse than the tanks since they never had been flushed, very annoying to examine as I pulled them out for other repairs. I also found a roof vent pipe had settled and vented into the interior more than vent through the roof. I wonder if the new style foaming drain cleaner would help sanitize the lines.
The days are short and the night is long and the stars go tumbling by.. . ~Airstream~
Old 08-02-2007, 04:50 PM   #16
I decided to open all windows for the past severaldays as we were not expecting any rain and I keep the AS at my home. Today I entered the AS and noticed no significant odor. I think the smell may be a poor quality "fragrance" that eminates from the chemical that we toss down the toilet. I am going to flush the entire system again and see if I can find a product that has a neutral odor. Thanks for all of the suggestions. If this doesn't workI will head to the dealer as I have several warranty issues.
Old 08-02-2007, 06:35 PM   #17
Altoona , Florida
Of course, there are positive things about the smell like keeping company out under the awing
Old 08-02-2007, 07:39 PM   #18
bilby05
bilby05's Avatar
1962 24' Tradewind
1962 24' Tradewind
Canyon , Texas
Formaldahyde?
I left a bottle of the green formaldahyde type toilet additive in the shower cabinet and apparantly the lid was loose. After a long drive and quite awhile parked in the sun, when I opened the door the fumes would bring tears to my eyes. I had to scrub the green stuff out of the cabinet and shower/tub and months later we still can smell that smell. I no longer use the green stuff, got some nice orange(non formaldahyde) additive. Smells better, but also try to remember to keep the bottle in a bucket under the kitchen sink so if it leaks, out it goes.
cheers, bill b.
1962 Airstream Tradewind
2001 Ford 7.3 Diesel
bilby05 is offline   Reply With Quote
Old 08-03-2007, 09:42 AM   #19
1963 19' Globetrotter
Ingram , Texas
We have had four ASs'. One 63 Trotter twice, 77-27 and a 69-31. They all have had a very distinctive yet non-offensive Airstream fragance(sp). Not a waste smell, not a mildew or mold, nor a smoke smell (wouldn't have bought them if they did). We look at a lot of older ASs, the vast majority of them have the fragrance. We have smelled them from Alaska, where we lived in the 31' for three years, to Texas, and maybe it's just our noses. But it reminds of 'home'
ChicknKathy is offline   Reply With Quote
Old 08-03-2007, 01:42 PM   #20
Aluminut
2004 25' Safari
. , Illinois
An all too familiar sound for an Airstreamer.....
Cost to restore a gutted Airstream Draco General Interior Topics 28 02-18-2013 11:17 PM
Airstream vs. Avion? 68 Suburban Vintage Kin 29 11-21-2008 07:35 AM
future airstream motorhome betteleal Airstream Motorhome Forums 11 02-12-2005 01:39 PM
Airstream Related List Servers Andy R Link Archive 0 02-22-2002 02:05 PM
AirstreamTrailers.com - Airstream Link Library Andy R Link Archive 0 02-22-2002 01:31 PM
