Old 07-03-2016, 11:25 AM   #1
2014 23' Flying Cloud
2015 28' Flying Cloud
Kalamazoo , Michigan
Afraid to ask!!!
So have taken a few trips with my new 2015 28ft FC. Noticed something that causes me pause and am afraid to hear the answer. Oh well here it goes... Every once in awhile - actually very seldom while camping my water pump will cycle very briefly. Only a couple of seconds, if even that. My fear is there is a leak somewhere. Or is it just sensitive enough that when in standby mode the slightest change in pressure trips the bump?
mwilliamsmd is offline   Reply With Quote
Old 07-03-2016, 11:45 AM   #2
2000 30' Excella
Toledo , Ohio
sounds like a slight leak
woodfox45 is offline   Reply With Quote
Old 07-03-2016, 11:50 AM   #3
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
I think they all do that occasionally. I know mine do (in both of my trailers) and my daughter's does, as well as my daughter-in-law's. We had this discussion while camping last week & we all have a random pump turn on. If you see no water anywhere, I wouldn't worry about it. IMHO :-)
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 07-03-2016, 12:14 PM   #4
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
The bad news is that it probably does indicate a leak.
The good news is that is can be the pump check valves leaking internally.
Old 07-03-2016, 01:52 PM   #5
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
The check valve seems to do this.
You may also notice when hooked up to city water, your fresh wster tank will overflow and leak out of the fill port... this too is an indication of a weak/ faulty/ dirty check valve. This can be inspected and clesned by the user.
Old 07-03-2016, 02:42 PM   #6
2016 30' Classic
Hilliard , Ohio
Mine does this too - just for a split second every half-hour, now more frequent. However, I've gotten to all areas near fixtures and the hot water tank and can find no signs of moisture. I'm inclined to think it's the pump's internal pressure switch acting up and/or some check valve leak. Under full pressure with a tap open my pump is starting to lope instead of constant pressure. I think my pump may be failing. Maybe some additional symptoms to look out for.
2016 Classic
2010 Ford F-150 Lariat
jeff4506 is offline   Reply With Quote
Old 07-03-2016, 02:48 PM   #7
Gainesville , Florida
Afraid to answer!
Old 07-03-2016, 03:21 PM   #8
Hiho Silver's Avatar
2016 27' Flying Cloud
Overland Park , Kansas
We have had 3 Airstreams and several pumps replaced over the years. They all would occasionally cycle, and no apparent leaks. A couple of years ago a tech at JC put a pressure gauge on my city water connection, outside the trailer, and set it at 60 psi.(I think it was 60). After a couple of hours it was holding pressure, and he said that meant there was not a leak in the system. The other tech working on my trailer said his trailer pump does the same thing, occasionally. I still don't like it when my pump cycles for no apparent reason, and I still check for leaks periodically.
Hiho Silver is offline   Reply With Quote
Old 07-03-2016, 08:22 PM   #9
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
We turn the pump OFF when not in use. You should always turn the pump off when on the road and even when you are not in the coach.
I'm afraid this is going to be expensive... Stefrobrts 1966-68 Caravel 236 03-06-2018 08:35 PM
Be Very Afraid codybear Off Topic Forum 114 01-30-2015 06:23 PM
Everything You Always Wanted to Know About The Land Yacht* (*But Were Afraid to Ask) Colonial Airstream Commercial Listings 14 11-16-2013 08:27 AM
Southwest Afraid to Boondock! rambn Boondocking 34 03-01-2009 02:40 PM
I'm Afraid to Ask juel Electrical - Systems, Generators, Batteries & Solar 10 07-11-2005 06:12 PM
