Old 01-22-2015, 12:19 PM   #1
webster , Minnesota
Adding sleeping space to 31'
I am in the process of negotiation a deal on a 31' airstream. it has the two twin bed arrangement in the rear plus the goucho up front. I'm looking for ideas to add some sleeping space.
thanks in advance!
clerick44 is offline   Reply With Quote
Old 01-22-2015, 01:29 PM   #2
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
Does it not also have a dinette that will convert to extra sleeping space?
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 01-22-2015, 01:41 PM   #3
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
What kind of sleeping space? I saw one where the twin beds were converted to triple bunks for the 6 kids...
Aaron
WBCCI #XXXX AIR #2495
Old 01-22-2015, 02:43 PM   #4
Kevin245's Avatar
My suggestion would be to touch base with Airstream Forums - View Profile: PizzaChop
At last count Ron and his DW were up to nine children, and he is the guru of bunk building in an Airstream.
Eleanor Roosevelt
Old 01-22-2015, 04:18 PM   #5
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
As noted earlier the dinette can be converted to a small bed, albeit I would consider it for kids rather than an adult.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 01-22-2015, 04:43 PM   #6
terryV's Avatar
2002 31' Classic
Monroe , Iowa
Jack
Some floorplans don't have dinettes. My '02 31' Classic does not have a dinette. It has swing up tables in front of the couch. That's the way I like it.
terryV is offline   Reply With Quote
Old 01-22-2015, 04:58 PM   #7
jcanavera's Avatar
Fenton , Missouri
Images: 143
Yep that's right. Our first Airstream had the two swing up tables. We've always had a dinette on our previous SOB's and really missed having one. That was one of several reasons why we traded that trailer in on one which had a dinette. Never have used the dinette as a bed even though you can.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 01-22-2015, 07:51 PM   #8
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
How about a board to span the distance between the twin beds...
Peace and Blessings..
Channing
WBCCI# 30676
Old 01-23-2015, 09:01 AM   #9
webster , Minnesota
this one has the couch and swing up tables. I have four kids of my own so that's five but I like having a contingency for friends or family.
I'm thinking that the trailer will stay stock for the time being but it will need to be gutted at some point to properly address some body damage due to a storm. I figure at that point I'll make some modifications. Maybe adding some bunks to the back and sacrificing some of the storage across from the bathroom to serve as another bunk maybe.
I appreciate all the input so far!
Old 01-23-2015, 09:21 AM   #10
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
Way back in the dark ages (early 70's) Airstream used to offer a hanging bunk option in lieu of the upper cabinets, I believe the hardware may still be available. Have to search around and see if you can find pictures of it. I will see what is in my 1975 manual when I get a chance.
Aaron
Old 01-23-2015, 09:32 AM   #11
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Aaron
There is some info and pics on this site.
Old 01-23-2015, 10:48 AM   #12
webster , Minnesota
Aaron
I just found some pictures of this. I'm trying to figure out how much weight that system could hold.
Old 01-23-2015, 05:33 PM   #13
2015 27' FB International
Rancho Palos Verdes , California
Thinking outside of the box - How about camping hammocks like the Hennessy? Stow during the day and hook up at night. No need to alter the interior except to set up lash points. Can do double duty outside when appropriate.
RPVEd is offline   Reply With Quote
Old 01-23-2015, 05:38 PM   #14
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Possible good idea... but, inside the AS, the 'lash point' would have to be a 'rib'...and you would have to use a screw because you couldn't access the back in order to use a bolt/nut.
Perhaps other's have better advice.. ?
Channing
WBCCI# 30676
Thinking about adding 4' of space djfrantic 2005 and newer - Bambi all models 12 10-01-2010 12:25 PM
Need more Sleeping Space! Need bunk starting point... By the Bay Cabinets, Counter Tops & Furnishings 13 11-12-2009 06:21 PM
Sleeping space gab Interior Restoration Forum 1 05-09-2006 06:58 PM
International AS sleeping capacity billwhelan 2002 - 2005 International 3 03-08-2003 08:03 AM
Interior help desired - We need more sleeping space Curtis-79MH General Interior Topics 3 03-19-2002 06:08 PM
