Old 02-03-2009, 08:37 AM   #1
adonh's Avatar
1976 31' Sovereign
Missouri City , Texas
Accordion folding doors
In my 1976 Sovereign I have two accordion folding doors between the kitchen and the center bath/closet and rear bedroom. I would like to replace these with new ones. They are only a couple of feet wide. Anyone have a source for something like this.
Don
adonh is offline   Reply With Quote
Old 02-03-2009, 09:01 AM   #2
DEITZ645's Avatar
2006 30' Classic S/O
Mohrsville , Pennsylvania
Don,
Have you tried Out Of Doors Mart, Vintage Trailer Supply, Or Inland RV???
They might have the parts you are looking for.
Carl, Elaine & Finn The Beagle
2006 30' Classic W Slide & Limited Package Katarina
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
DEITZ645 is offline   Reply With Quote
Old 02-03-2009, 09:15 AM   #3
FLYNCLD's Avatar
1962 22' Flying Cloud
Bend , Oregon
I have a used one for sale. Got to:
Airstream Trailer & Airstream Motorhome Classifieds - Folding Bathroom Door - Powered by PhotoPost Classifieds
FLYNCLD is offline   Reply With Quote
Old 02-03-2009, 10:39 AM   #4
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
It depends...
If you want to go vintage and authentic then I'd try Airstream part suppliers or classified ads like on this site. If you want to go cheap and easy, Home Depot and Lowe's sell these in different colors. That's what I did and it looks great.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 02-03-2009, 10:49 AM   #5
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Lynn and I made such a door for our '65 Caravel as the old one was hard and cracking. We just got the material to make a second one for the '83 Excella we just purchased.
You need four yards of fabric. We chose some to go with the interior colors.
The opening is about 30-32 inches, make the door 40-42m inches wide and 72" tall.
Fold the material double. The fold becomes the bottom of the door. Buy replacement slats for vertical blinds at Home Depot. They are 3 1/3 inches wide. Sew 3 3/4' pockets lengthwise in the material. Cut the slats to length. Slide one slat in each pocket. Be sure to cut the slats at the bottom end, leaving the hole at the top. We used 1" split key rings in every other section, put through the material on one dice, then througn the slat, and through the material on the other side. Then attached the split rings to the original hanging hardware.
We sewed pockets in each end of the door for the originad hardware from the old door.
You will also want hems folded inward at the top for finish.
This door folds flatter, will last longer, and looks much nicer than the original vinyl door. If it becomes soiled, simply take it down, remove the slats and hardware from the pockets, and throw it in the washer.
Old 02-03-2009, 11:12 AM   #6
Don
Home Depot has that type door.
However, they are typically taller, so you would have to cut it down.
Old 02-03-2009, 12:37 PM   #7
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
Jim Foster
NOW THAT'S NEAT
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Old 02-03-2009, 12:54 PM   #8
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Originally Posted by Mikethefixit View Post
Jim Foster
NOW THAT'S NEAT
Now.....If you want to get really fancy, get two different materials. One to match the room on one side and the other to match the room on the other side.
Let your imagination run...........
Old 02-03-2009, 04:01 PM   #9
modarch's Avatar
1967 17' Caravel
Thompsons Station , Tennessee
Jim- I will be honest, that gets my vote for the cool and super creative detail of the month! Very awesome idea that I am going to borrow!
Now I am just hoping that I kept the hardware that goes in that top track on my '67 Caravel.
modarch is offline   Reply With Quote
Old 02-03-2009, 05:27 PM   #10
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
If you didn't keep the plastic sliders that go in the track, they can be purchased at any number of RV parts stores. Or...........you can make them from small eye-bolts, with the nut close to the eye and the balance of the bolt cut off using a cutter which will mess up the threads so that the nut doesn't back off. One of my sliders was broken, so that is just what I did. I used it as the first one in line at the handle end. It will never break. That was five years ago.
Old 02-03-2009, 06:38 PM   #11
funkill's Avatar
reno , NV
Images: 27
Very well done!!!
funkill is offline   Reply With Quote
Old 02-03-2009, 06:54 PM   #12
safari62's Avatar
1962 22' Safari
1957 22' Custom
1963 16' Bambi
Vacationland , Maine
Images: 43
screens
I also replaced the old vinyl also with unbrella fabric. There are several different weights and weaves available. Advantages of fabrics are ventilation and material folds closer to wall.
Name:	Airstream Dig 025 [800x600] [800x600].JPG
safari62 is offline   Reply With Quote
Old 02-03-2009, 09:20 PM   #13
1963 19' Globetrotter
Moline , Illinois
I replaced mine with a "pleated folding door" made by United Shade Inc.. Very close to the original door and they are custom sized so you can fit any doorway. Very easy to install. Best price I found was at Camping World but a lot of dealers can order them.
63air is offline   Reply With Quote
Old 02-03-2009, 09:30 PM   #14
Klatawa (to travel)
Klatawa's Avatar
1965 24' Tradewind
Bremerton , Washington
We totaly gutted our 63 safari and using the original layout we used birch for all of the wood work. We originaly left the curtain but I replace the curtain with a three section sliding door. With the door partialy opened it acts as a head board for the gaucho. Click image for larger version
Klatawa
(Dave & Debbie)
1965 24' Tradewind
1965 Chev Carryall
http://s1237.photobucket.com/albums/...ind%20Rebuild/
Klatawa is offline   Reply With Quote
Interior Folding Doors for Bathrooms?? cosmo9404 Doors & Locks 11 04-24-2007 08:13 PM
Pocket Door vs. Accordion (folding) Door A/S Interior pap Cabinets, Counter Tops & Furnishings 12 03-10-2005 04:40 PM
Anyone know a source for replacement naugahyde folding doors? GStephens General Interior Topics 2 05-21-2004 11:25 AM
