Old 03-09-2010, 03:30 PM   #1
hampstead38's Avatar
1967 26' Overlander
Upperco , Maryland
80/20 aluminum extrusion
I am trying to order some 80/20 extrusion. I thought using the aluminum to do some interior framing might be lighter and stronger than wood... but I haven't found the distributer very helpful. The stuff is also pretty spendy, once you start ordering fastners in bulk. Anyone have any hands-on experience with 80/20, and if so, do you have a good distributor? I really hate begging people to take my money.
hampstead38 is offline   Reply With Quote
Old 03-09-2010, 03:45 PM   #2
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
For some things it works well
Originally Posted by hampstead38 View Post
.. Anyone have any hands-on experience with 80/20, ... I really hate begging people to take my money.
Some of my co-workers have used the stuff to build [science] test beds which require the ability to constantly re-position hardware. It works very well for that.
I won't buy it for my test beds because it is somewhat bulky. And it is expensive.
Personally, I think it is too heavy to consider as an Airstream component. The simpler extruded aluminum "T", "C" & "H" shapes available are much lighter.
Tom
Old 03-09-2010, 04:03 PM   #3
Images: 59
I think, as usual, that Tom is 100% spot on.
I can't see a use for it. Would you use it as framing for a partition and then fill it in with panels of aluminum? Use it for bed or gaucho frames?
It's a lot heavier than regular aluminum shapes beacuse it's normally used for heavy duty fixtures with lots attachments.
I've used it to make process enclosures and its expensive and hard to keep clean.
Old 03-09-2010, 04:34 PM   #4
1967 26' Overlander
Upperco , Maryland
I was thinking load-bearing frames like the bed and counter. I haven't actually worked with the stuff but I checked. The 15/15 is a pound/foot... which isn't exactly light. I could do everything in wood (which would be less expensive), but wood isn't light either. One of my thoughts was to try to make some of the components break down rather easily. I had enough "moments" gutting the Overlander where I thought, "Hey, it would have been nice if someone had thought about accessing some of this junk." I could look for some local provide of aluminum extrusion, but I'm a little nervous because of my previous experience working with aluminum. I suppose the "c" channel could be fabricated to work alright.
Old 03-10-2010, 05:20 AM   #5
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
The Quick-Frame pieces look spot on for a modular look... humidity and hard use will not cause them to sag but the nylon corner pieces may not age so gracefully.
I would fear the minimum order and pricing though... (EDIT: I see they have an ebay storefront '8020 Inc Garage Sale" maintained by "8020 Inc" --- I might have to try a piece or two to supplement standard aluminum extrusions)
Old 03-10-2010, 05:28 AM   #6
Here's a thread where the owner used aluminum framing for furniture (not the 80/20 system). The pictures begin around page three I believe:
http://www.airforums.com/forums/f420...1-a-31328.html
Old 03-10-2010, 05:32 AM   #7
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
For a source, check with Aircraft Spruce and specialty. They provide parts, and material to the homebuilt aircraft market and sell a lot of aluminum.
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Old 03-11-2010, 02:19 PM   #8
1967 26' Overlander
Upperco , Maryland
The quick frame is about $24 for a 124" stick. While I like the concept, I'm not sold on the fasteners. Given the vibration in the coach, I'm not sure the soft-mallet tap-ins are the way to go. Again, one of my concerns is breaking things down to get access to stuff. If I went with wood, I'd probably "glue-and-screw" everything. Not as expensive as aluminum, but heavier and far more "permanent." Well, I have a few days before I start throwing myself at the bed frame. Thanks for the leads.
cabinet extrusion bcass Cabinets, Counter Tops & Furnishings 2 04-01-2008 11:35 AM
Exterior replacement parts sought -door handle/ext rail extrusion! RetroWade! Clearcoat, Exterior Paint & Trim 1 07-22-2007 06:08 PM
Advice - cleaning aluminum extrusion CampbellMcCa Clearcoat, Exterior Paint & Trim 3 05-18-2007 02:19 PM
Roof locker extrusion needed mcneon Cabinets, Counter Tops & Furnishings 1 09-24-2004 09:00 AM
