Old 11-30-2002, 09:18 AM   #15
LOST , Hawaii
Lowes, Home Depot, etc. It is used in showers, bathrooms. I have only seen one thickness, a little more than 1/16" and only white. It has a pebble surface, about $28 for a 4x8 sheet around here. I have seen it online at different plastics outfits but didn't really check it out as shipping on big sheets is really steep. There may be other colors, surfaces, etc. If there is a local plastic outfit you might check that out.
John
74Argosy24MH is offline   Reply With Quote
Old 11-30-2002, 11:34 AM   #16
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
FRP (fiberglass reinforced panels) made by Masonite comes in several different textures & colors although they are all neutral-tones of grey, beige & white. In addition to bathrooms, it's also used in commercial kitchens, hospitals & industrial applications, usually as a more cost effective solution to ceramic tile in sanitary situations.
Here's a link to the Masonite website. There should be a local distributor in your area (other than the "box" stores mentioned) that can order the panels in colors/textures other than white-pebble.
Shari
Old 06-14-2013, 01:42 PM   #17
crabbey1's Avatar
1976 Argosy 22
Pasadena , California
Images: 33
Send a message via AIM to crabbey1 Send a message via Skype™ to crabbey1
I just recentlu removed all my interior panels to clean and to paint. A couple of them were dinged or dented slightly while removing (oops!) I wanted to know if the Fiberglass Reinforced Plastic (FRP) is strong enough to support the original shelving and walls? I would not be using this for the end caps....
crabbey1 is offline   Reply With Quote
Seeking repair tips on a '78 Argosy Minuet Van All Argosy Trailers 9 09-11-2003 10:14 PM
Seeking repair tips on a '78 Argosy Minuet Van All Argosy Trailers 0 08-22-2003 05:05 PM
Tambour Alternatives for '78 Argosy Minuet overlander64 Cabinets, Counter Tops & Furnishings 8 03-31-2003 07:51 PM
Generator for '78 Argosy 28 ebob Generators & Solar Power 1 03-11-2003 08:24 AM
