Old 05-17-2011, 08:57 AM   #1
1978 Argosy Minuet 6.0 Metre
Cottonwood , Utah
78 argosy interior rivets
I need some help with interior pop rivets on my 78 argosy 20.
I bought some 1/8" rivets but they seem to small, they do not draw up tight. is the answer to go up one size? also what length do I need for interior work?
Any help on drill bit sizes would help also. My problem most likely is that the rivet holes are now larger than original.
It would be nice to find them in white also.
Thanks Argosyman
argosyman is offline   Reply With Quote
Old 05-17-2011, 11:14 AM   #2
Ottawa , ON
The Wally Byam shop at the JC Service Center sells the thinner ones in two colours (cream and brown). You might have to order them through your local AS dealer.
Old 05-17-2011, 11:49 AM   #3
altnbndr's Avatar
1967 17' Caravel
1968 22' Safari
Sacramento , California
Images: 11
interior rivets
For 1/8'' rivets use a #30 bit, if you use an 1/8" the hole will be too big. You can get the white alum. rivets from most hardware stores that sell materials to install "t-bar" ceilings (they are the same rivets). Also I have found if you wiggle the riveter a little as you squeeze that you can draw the rivet tighter.
altnbndr is offline   Reply With Quote
Argosy maiden voyage. shortcake All Argosy Trailers 18 09-29-2011 10:33 AM
newby w/ 77 28' Argosy Jimjim Member Introductions 2 04-27-2011 06:01 AM
Argosy Manual dlb56hdt All Argosy Trailers 4 04-02-2011 02:20 PM
1973 Argosy / Airstream Camper - $4100 (Newark) 61Ambassador Airstreams on eBay 4 02-13-2011 11:11 AM
Argosy Door TG Twinkie Doors & Locks 7 01-29-2011 06:11 PM
