'76 25' LandYacht Toilet Removal
Need to remove toilet (AquaMagic Model 6L) shown in attached photo installed in a '76 25' LandYacht. I have the Maintenance manual which provides instructions which don't seem to apply to this situation. Removing the front attaching nut from the bolt projecting up from the floor was not problem, however, accessing the rear nut is the issue. The instructions state to "Lift toilet seat ring and remove plastic plug to gain access to rear flange bolt". There is no liftable toilet ring. It seems that it might be necessary to come in from underneath. Any insights into this problem would be appreciated.
