Old 03-11-2012, 03:32 PM   #1
moparjohn's Avatar
1973 25' Tradewind
Ringoes , New Jersey
'73 tradewind gaucho slides question, help!
Ok, I'm getting my front gaucho redone, new foam and material. I am changing out the old wood base for new. When I removed the bottom wood base I could see two plastic slides, dettached from the pull out stringers. I can't seem to figure out what way they go? On the edge of the base there is four of these slides screwed to the bottom (top of the under bed storage) facing up. like a "u" . The outside stringers have the other two sliders in the track, they seem to be mounted on the stringers, I see a hole for the screw. When you attach them like an "n" they slide in, you can screw back the front slides. But the bed seems to be held up, just by the two slides on the stringer? If you put the two slides on like a "u" I don't see how you can attach the front two slides. To see what I mean, you would have to have had your's apart. Anyone help without me posting pics? MPJ
moparjohn is offline   Reply With Quote
Old 03-12-2012, 05:40 AM   #2
noreen&sal's Avatar
1981 27' Excella II
mays landing , South Jersey
I believe they screw into the bottom of the seat frame and act as a stop against the front frame, to keep the seat portion from sliding. Maybe someone can explain this more clearly. Sal.
Sal & Nora
Let us live so that when we die even the undertaker will be sorry. Mark Twain
AIR 42483
TAC N.J. 17
WBCCI 24740
noreen&sal is offline   Reply With Quote
Old 03-12-2012, 07:18 AM   #3
moparjohn's Avatar
1973 25' Tradewind
figured it out
The slides go in like a "u". I then had to remove the front face of the gaucho to get the slides in and screwed down.
Towing Question- 2012 Touareg TDI- Airstreams in general or 2011 Flying Cloud 23fb Roger L Towing, Tow Vehicles & Hitches 21 05-17-2014 07:32 AM
Question on 2nd /AC or generator input mefly2 Electrical - Systems, Generators, Batteries & Solar 9 06-18-2012 08:04 AM
help! final questions before we pull the trigger on a 25' Eddie Bauer bc_seattle Member Introductions 31 05-10-2012 09:08 PM
Need help immediately on brake hose part mumbers dadstoy Classic Motorhomes 3 03-23-2012 05:09 PM
1973 Vintage Airstream Tradewind 25' needs love, but is campable now eBay Watch Airstreams on eBay 0 03-22-2012 11:00 AM
