Old 07-26-2012, 10:23 AM   #1
1972 25' Tradewind
fort lauderdale , Florida
'72 Tradewind proposed floorplan
This is a layout I am considering for my 72 Tradewind remodel. The trailer is gutted and I'm in the process of floor removal/replacement and frame painting.
Besides the obvious of stove vent relocation and restroom vent relocation, Does anyone see any weight distribution issues? Any input or alternate layout suggestions are greatly appreciated.
p.s. There is not currently a black tank installed. I plan on adding that as well as a grey tank addition.
ehodg66 is offline   Reply With Quote
Old 07-26-2012, 01:45 PM   #2
1993 29' Excella
Southport , North Carolina
Looks pretty good to me. Are you placing the fridge and furnace where there is an existing panel on the outside? One thing I think might make a difference is the fridge and the pantry on the other side of the sink and countertop. It would feel more open in the front and more secluded in the bedroom. What did you use to draw the floor plan? I have looked at different layouts for mine using AutoCAD.
TikiDaddy is offline   Reply With Quote
Old 07-26-2012, 02:01 PM   #3
1981 31' Excella II
New Market , Alabama
I am assuming that the tanks were originally in the back along with the bathroom? You are going to put the tanks closer to the axel? That should be an improvement over the rear bathroom design. Your weight distrubution should be better although the nose will be heavier. It is better in the sense you won't be putting as much load on the rear end.
Perry
Old 07-26-2012, 02:54 PM   #4
1972 25' Tradewind
@Tikidaddy: I agree with you about moving the fridge but the existing fridge vents are where the fridge is drawn. I won't be reinstalling the furnace b/c I live in south Florida. I'll use a portable heater if I ever need to. I use Autocad.
@perry: there was only a small, corner black tank underneath the toilet. I would like to get the new tanks as close to the axels as possible.
Thanks for the input!
Old 07-26-2012, 03:42 PM   #5
Ottawa , ON
Does your diagram show the existing window placements, or do you plan on moving them?
Does the refer move? If so, that's another blank wall required, and some venting.
Old 07-26-2012, 03:45 PM   #6
1972 25' Tradewind
The windows are shown in the drawing as existing and will not move. He refrigerator stays in original position.
Old 07-26-2012, 03:47 PM   #7
1972 25' Tradewind
The Not he
Old 07-26-2012, 03:50 PM   #8
Ottawa , ON
That's wise.
IIRC, the furnace is below the sink or cooktop. That's another item that requires special treatment. Were you able to leave it in its original place?
Old 07-26-2012, 03:57 PM   #9
1972 25' Tradewind
Refer to post 4.... No furnace
Old 07-26-2012, 04:13 PM   #10
Tom Nugler's Avatar
1972 25' Tradewind
McHenry County , Illinois
Are you putting in the original stove or have you found a cooktop?
The original layout with the full stove and furnace on the streetside and the fridge and pantry on the curbside seemed a good side to side weight distribution setup.
Ditching the 40 pound furnace and putting the stove, fridge and pantry all on the same side would seem to put a lot of dead weight on the curbside.
If you have a better half that packs like mine, the kitchen side will crammed with every conceivable pot, pan and small appliance along with couple weeks of food. This might only add to the imbalance.
I'd weigh weight all the stuff and see what the actual weight is before setting anything in stone.
Overall the rear bedroom and front dinette are a better use of space than the front couch and rear bath in the original layout.
Good Luck,
Tom.
AirForums # 2806
WBCCI / VAC # 6411
Not All Who Wander Are Lost.
Avid supporter of trailing edge technology.
Tom Nugler is offline   Reply With Quote
Old 07-26-2012, 04:19 PM   #11
1972 25' Tradewind
Thanks Tom, I was thinking of going with a new cooktop and a convection but you're right, the weight will still be curbside. I thought about switching the frig with the closet next to the bath for more weight roadside but then I'm cutting more holes, and I'm really trying to avoid that. I'm a long way from a finished product but trying to get my layout nailed down.
Old 07-26-2012, 04:52 PM   #12
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
I'm a believer in having the range-of-motion about the countertop 'range' commanding an unobstructed trajectory out the entrance door...
Old 07-26-2012, 05:21 PM   #13
1972 25' Tradewind
You're going to have to decipher that one for me Wabbiteer
Old 07-26-2012, 05:51 PM   #14
Wabbiteer's Avatar
1972 29' Ambassador
Think flaming frying pan pretending to be a rocket. (or ignited kitchen towels, cutting board, winter jacket, or anything that has gotten too close to the range burners)
