Old 07-30-2011, 01:22 PM   #1
1972 25' Tradewind
San Diego , California
72 Trade Wind screen door is smarter than me
Question about our screen door. I don't have the slider that covers the exterior door handle but it's on order... In case that's related
The question has to do with latching the door. Ours has a white catch in the door frame and one of the airstream black latches on the screen door. The PO put a screw into the black latch to disable it. If used it would make the door unopenable if both the exterior door and screen door were closed.
So, how's it *supposed* to work? I assume we have an incorrect setup.
Thanks, I can post a photo if needed. Currently I'm the passenger as we pull home on the final leg of a 2 week, 3,000 mile journey.
James
icebox500 is offline   Reply With Quote
Old 07-30-2011, 01:48 PM   #2
cameront120's Avatar
1972 25' Tradewind
There should be a latch that, when not in use, the screen door is held fast against the regular door. This way, you're not fumbling with two doors at once every time you want to enter/exit the Airstream when the screen door isn't needed or wanted. I'll try to run out back this afternoon and photograph mine for you.
North Vancouver, BC
Old 07-30-2011, 03:40 PM   #3
1972 25' Tradewind
Here's a couple of images for you. Hopefully it explains how it all works. Feel free to ask any questions!
North Vancouver, BC
Old 07-30-2011, 03:43 PM   #4
1972 25' Tradewind
That image is a little small. I've attached a PDF as well that will give you a larger image size, I think.
North Vancouver, BC
Old 07-31-2011, 08:13 AM   #5
1972 25' Tradewind
Thanks that's very helpful! It is the exact setup that I have. I'll have to retry. It seems to me that the inner screen door is going to latch when the main door is closed and will prevent me from opening the door at that point. I'll have to retry with someone in the trailer!
I went to college at Western and spent a lot of my "pre 21" time in Vancouver. Terrific city.
Old 07-31-2011, 08:19 AM   #6
You can readjust the screen door location, to make that old style black latch work, by making the screen door set a tad closer to the hinge. Just a good "shove" of the screen door towards the hinges, does the job.
Or, replace the screen door latch, with the newer style, white colored, roller latch.
Old 07-31-2011, 09:34 AM   #7
1972 25' Tradewind
For some reason, this doesn't happen. I'm not sure why - engineering isn't one of my strengths!
Funny, I was at WSU and spent a lot of time in Seattle.
North Vancouver, BC
Old 07-31-2011, 09:44 AM   #8
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
I've had the screen door latch while attached to the outer door, and yes I've had to crawl in through the utility hatch - about seven times so far.
Someone did weaken the screen door sliding latch internal spring, that helps keep it from happening but it seems slamming the door(s) lets the striker slide out. Using a solvent to remove any oils or lubrication from the nylon helped too.
The days are short and the night is long and the stars go tumbling by.. . ~Airstream~
Old 07-31-2011, 10:19 PM   #9
1972 25' Tradewind
Utility hatch? About the closest thing I'm aware of is my roof vent!
Thanks for the screen door adjustment tip as well Andy.
1968 Trade Wind 24 Double Project TeamD 1959-69 Tradewind 17 03-08-2012 06:45 AM
Suburban furnace replacement for '66 Trade Wind Ben in MT Furnaces, Heaters, Fireplaces & Air Conditioning 0 05-17-2011 08:12 PM
1962 24' Trade Wind Double Beanyard Buyer Guidelines 14 05-07-2011 08:36 PM
1977 Trade Wind hubcap? Dastardly Wheels, Hubs & Bearings 3 04-04-2011 05:42 AM
1972 Trade Wind.. interior aluminum window sceen frames Janie Q General Interior Topics 3 03-25-2011 05:20 PM
