Old 12-18-2007, 06:57 PM   #15
1968 26' Overlander
Ann Arbor , Michigan
Images: 11
Originally Posted by overlander63
Stringers are analogous to crossmembers, they extend out to the bow (another term) and support them through the floor. Bows are the vertical crossmembers that start at the floor, and go up to the center. And yes, the insulation is taped in place, otherwise it would fall down the inverted curve to the ceiling.
So the ribs that I am seeing are what is called formers ( forming the basic shape of the AS)...in Semimonocoque terms? and the crossmembers that are horizontal are stringers?
Aluminati is offline   Reply With Quote
Old 12-18-2007, 06:58 PM   #16
a.k.a. Ambassador Tim
Safari Tim's Avatar
1960 28' Ambassador
Northern , California
Images: 35
Shameless plug.
We talked about Airstream construction a long time ago on theVAP.
-Tim
theVAP - Airstream Podcast
Old 12-18-2007, 06:59 PM   #17
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Yes.
Old 12-18-2007, 07:50 PM   #18
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Your floor looks great...what did you treat it with?
I had several partial cans of poly that I mixed all together. semi gloss ,satin, gloss, indoor, outdoor. some tinted maple, you name it , it all went into a large can and I squeegeed it on,three coats worth. After everything is done I will most likely put some epoxy down that I have.
Old 12-18-2007, 07:53 PM   #19
Aerowood's Avatar
Arvada , Colorado
Can water come through a hole where a rivet used to be...on the side of the trailer. I remember seeing some water track marks from a location on the side of the trailer. There is a rivet missing.
Yes
Old 12-18-2007, 08:46 PM   #20
byamcaravanner's Avatar
1967 28' Ambassador
1963 19' Globetrotter
1970 29' Ambassador
Waukesha , Wisconsin
Originally Posted by Aerowood
Attaching the stringers to the frames will not cause the shell to become any stiffer or cause any point loads.
True... but bearing the rib on the "C" channel/floor will. There is a reason they stop the ribs above the floor.
Steve & the crew
'70 Ambassador International Twin
'63 19' Globetrotter TAC WI-1
http://byamcaravanner.blogspot.com/
byamcaravanner is offline   Reply With Quote
Old 06-27-2008, 06:20 AM   #21
1968 26' Overlander
Images: 11
Hello All
I am selling my 68 Overlander. I am asking $800 for it. The Shell and Frame are in great shape. Still has Original clear coat in it. I would be flexible with the price. Need to get rid of this ASAP.
I wanted to give everyone a heads up on this list before I post it on ebay on Monday.
Old 06-27-2008, 08:20 AM   #22
tphan's Avatar
1972 27' Overlander
Longmont , Colorado
Hey- sorry to hear you're giving up on the Overlander. I'd buy it if I were closer to Ann Arbor, and I'll bet you'll sell it here before monday. Good luck! -tim
tphan is offline   Reply With Quote
Old 06-27-2008, 09:22 AM   #23
1968 26' Overlander
Images: 11
Yeah...things didnt work out as planed :?(
Old 07-13-2008, 08:55 PM   #24
till's Avatar
Lisle , Illinois
Images: 108
Aluminati,
Thanks! Trailer made it home safely. Started the clean up and parts to order list already. Best of luck to your sons!!!
Regards,
Tedd Ill
AIR#3788 TAC IL-10
1967/8 Overlander International Twin w/ bunk/s.
Yes, four kids and two adults in the thing.
Happy wife, happy life.
till is offline   Reply With Quote
Old 09-06-2010, 04:14 PM   #25
till's Avatar
Lisle , Illinois
Images: 108
Rivet
Time to revive an old thread......
I pulled the 68 out of storage on Saturday and labored today.....
First order of business was to clean the old girl up. This is the first time I have ever washed an Airstream. Used an "O Cedar" floor polishing tool. WOW did it do wonders! Also started to repaint the trim. Got to keep her looking good for the neighbors.
Then on to cleaning the interior. Found that spic and span with a scrub brush did the trick. You can see the three stages of the cleaning method.
First a rag to wipe down and get the heavy stuff off then to the brush.
I need to replace the floor. First clean, clean, clean.....
ID:	110142   Click image for larger version
ID:	110144   Click image for larger version
Tedd Ill
AIR#3788 TAC IL-10
Old 09-06-2010, 07:26 PM   #26
till's Avatar
Lisle , Illinois
Images: 108
Please disregard this post. Wrong thread....
Tedd Ill
AIR#3788 TAC IL-10
New Restoration Project, '72 Overlander surferstyler 1972 Overlander 160 08-29-2013 06:28 PM
1958 Overlander Restoration Ken J 1954 - 1959 Overlander 150 06-21-2013 11:23 AM
DIY Network Overlander Restoration Series lubbockgolf Airstream "In the News" 18 06-15-2012 06:06 PM
The start of '73 Overlander restoration Lothlorian Repairing/Replacing Floor &/or Frame 134 10-24-2011 08:23 PM
1972 Overlander Shell-off Restoration Derek D Repairing/Replacing Floor &/or Frame 11 10-19-2006 07:51 AM
