Originally Posted by dbtolman
OK. I'm over the shock now. Wow... oh my... Just TOO beautiful.
I'd like to know a couple things...
Is that an oven or a dishwasher next to the reefer?
Where's the gorgeous stove-top from?
I assume you built the overheads? If so, do you have patterns for the ends?
wow... just... wow...
1. Thats the original oven with a "hammered texture" dark gray paint job (was brown). Rustoleum sells the paint and it works great for covering up old crappy finishes.
2. Would you believe J.C. Whitney for about $100? The cooktop is nice, and it has real RV-style "stay in place" grates on it.
3. The overheads are stock, with custom end caps. I built them by making cardboard templates (which I unfortunately tossed out) and using pieces of the original end walls (which were in bad shape) Same goes to the half-wall at the front of the street side counter and between the bed and the kitchen counter, except that I used 1/4" plywood and painted it with the same zolotone look-alike pattern that came from rolling on some off-white interior latex and then lightly fogging it with automotive "splatter" trunk paint. Sounds half-assed (and I suppose it is), but the finished product looks like the big "z", except it's off-white with light/dark gray texture. In other words, a lot brighter than the original and easy to touch up.
