We are just starting the process of trying to bring life back to our airstream.
Our entry door is bent, po repaired by gluing some small cracks on inside frame, and replacing interior skin? with thin wood. Also there are 2 peices of wood that are about mid way up in the frame where the cracks are. About the level of the lock. Does anyone know if they are supposed to be there? it seems like they shouldnt be, they sort of interfere with the curve of the door.
We have the screen, it is not attached.
Would replacing the screen help the seal and curve of the door?
Can you re-curve a door if it is bent?
What should we use to replace the inside skin of the door?
Right now it is leaking and I just dont know where to start.
Any help would be great thank you all so much!
