Old 08-26-2015, 09:42 AM   #1
Sly
SlyDogs
Sly's Avatar
1956 22' Safari
1965 17' Caravel
Albuquerque , New Mexico
'65 Caravel - ceiling skin support bracket
I'm restoring a 1965 Caravel and the internal skin support bracket that runs longitudinally down the ceiling, from end cap to end cap has been cut. The purpose of this bracket is to support the internal side skins to the ceiling (the skins slid into this bracket) whereby you rivet down from the support bracket to secure the side skins to the internal frame. On the caravel, this support bracket is 6 ft long. I would like to replace it if possible. Does anyone know if this support bracket is available new or used? Many Thanks for your help!
Name:	ceiling support bracket.jpg
Sly is offline   Reply With Quote
Old 08-26-2015, 09:54 AM   #2
You can make those brackets, called "horizontal stringers", by using sheet aluminum that's no more than .032, (thirty two thousands) of an inch thick.
Old 08-26-2015, 11:44 AM   #3
Sly
SlyDogs
Sly's Avatar
1956 22' Safari
1965 17' Caravel
Thanks Andy but I'm not sure how to do that at home being its a fairly complex piece. I've attached a cross section photo of the bracket (stringer).
Name:	cross section support.jpg
Old 08-26-2015, 12:07 PM   #4
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Clear Lake Shores , Texas
Take the exisiting one to a good aluminum fabricator and ask them to duplicate it.
BambiTex is offline   Reply With Quote
caravel
1966 Caravel Table slide out bracket needed! powayproduct Interior Restoration Forum 2 09-10-2014 11:24 PM
Interior ceiling skin. I think I might have big problems.... janetuck Interior Restoration Forum 2 05-08-2013 08:37 PM
How to remove ceiling skin? adwriter73 General Interior Topics 1 06-12-2010 06:29 PM
Duotherm A/C support bracket? rphdiego Furnaces, Heaters, Fireplaces & Air Conditioning 2 03-21-2008 05:32 AM
Zip Dee Support Bracket LTD93 Awnings 2 12-12-2003 07:51 AM
