Old 12-05-2009, 08:20 PM   #1
KySourMash
1958 26' Overlander
madisonville , Kentucky
58 26' overlander
Recently purchased a "fixer-upper" 1958 Overlander 26' and would like to restore it. Fridge gone, bathroom gone, ac gone- looking for wiring diagrams and floor plans. Needs rewiring but do not want to take off interior shell to do it- any suggestions?
mashburn is offline   Reply With Quote
Old 12-05-2009, 11:29 PM   #2
MarkR's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
Folsom , California
Images: 12
This site has lots of photos of '58 Overlanders - they should help as far as deciphering the original floor plan:
58Overlander
You might be able to get away w/ removing a "select" number of interior panels to access the wiring that needs to be replaced, however, once you remove a panel and see 50+ year old insulation that most likely was used at some point by rodents of one kind or another (might be why you're having wiring issues), you'll probably slip on the "slippery slope" and decide to remove it all . . .
If you're starting from scratch on the Wiring then you should be able to find lots of good examples to follow by searching here. If you're trying to find something specific then you'll probably get the most help by describing exactly what you're trying to find out.
Good Luck and Post Some Photos.
MarkR
Aluminumbskull with Led Balloon in Drag
Birch Plywood and Aluminum go together like
Peanut Butter and Chocolate
MarkR is offline   Reply With Quote
Old 12-05-2009, 11:30 PM   #3
Probably, the best help you can get is to purchase a "service manual" for a 73 or 74 trailer.
Unless you wish to have the wires exposed, you will have to remove some of the interior panels.
In 58 not much was 12 volts.
Today, everything is 12 volts except the AC and Microwave.
The wiring systems today are many steps ahead of the 58's.
Old 12-06-2009, 05:07 AM   #4
Service manuals are available starting in the 70's, that contain the answers to your questions.
Old 12-06-2009, 05:55 AM   #5
Baltimore , Maryland
Recently purchased a "fixer-upper" 1958 Overlander 26' and would like to restore it. Needs rewiring but do not want to take off interior shell to do it- any suggestions?
Yep find a different trailer. The wires need to go in the wall.
Old 12-06-2009, 07:29 AM   #6
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
What exactly is wrong with the existing wiring that you feel the need to replace it? If your trailer is in decent shape structurally, it is probably worth the effort but that's your call.
Post some pictures if you get the opportunity.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 12-06-2009, 07:53 AM   #7
Ken J's Avatar
1956 22' Flying Cloud
Durango , Colorado
Images: 14
You may find my experience helpful.... http://www.airforums.com/forums/f109...ion-12320.html
Ken J.
1956 Flying Cloud
Founder :
Four Corners Unit
Albuquerque National Balloon Fiesta
Rally
Vintage Trailer Academy - Formerly the original
restoration rally
Ken J is offline   Reply With Quote
Old 12-06-2009, 09:26 AM   #8
1950 Flying Cloud 7039
FC7039's Avatar
1950 21' Flying Cloud
Allen , Texas
Looking in a trailer, most of the interior skin is not visible.
Why does the wire need to be in the wall?
What would be the issues around building a race through the cabinets?
To me, only the air conditioner's need for 110 and its placement may require its wiring inside the skin. The placement of a closet may help in avoiding even this. The microwave more than likely will be in or on a cabinet.
The 12 volt wiring can mostly be hidden inside cabinetry and the few places its needed where exposed, so maybe decorative trim can be used to conceal the wires.
Are there issues with these thoughts? Before I do some of this type wiring?
I have some wire inside the skins. But not having a firm idea of the final build out of the interior, I did not run wires everywhere, but to strategic locations.
FC7039 is offline   Reply With Quote
1957Vintage Airstream 26' Overlander eBay Watch Airstreams on eBay 0 05-14-2009 01:10 PM
1967 Overlander 26' Twin Bob J. Mariano 1967 Overlander 10 06-14-2008 02:34 PM
Newbie - 26' Overlander GreatPumpkin Member Introductions 7 04-13-2006 06:44 AM
Any other's 26' other than 60's Overlander? 59toaster Our Community 4 03-21-2003 10:00 AM
