Old 12-14-2010, 11:32 AM   #1
1963 22' Safari
Pasadena , California
Question 22' Airstream
New to Airstreams, got a gig as a carpenter replacing floor, insulation and interior walls on a 22' Airstream, unsure of year/model. The walls are bolted through the floor, which needs to be removed/replaced. Probably covered here before, can anyone point me in the right direction?
lovejoyart is offline   Reply With Quote
Old 12-14-2010, 12:29 PM   #2
pbearsailor's Avatar
Port Hadlock , Washington
Welcome to the forums.
Many many many threads, but these are some good ones: Links to the Major Renovations
Forum Thread: First She Had to Take a Ride on a Boat
Blog: My 57 Caravanner
pbearsailor is offline   Reply With Quote
Old 12-14-2010, 03:05 PM   #3
tphan's Avatar
1972 27' Overlander
Longmont , Colorado
You'll find that it is quite involved to replace the entire sub-floor; it usually involves taking off at least all the lower interior skin, and the belly pan. Most here do a "shell-off" when replacing the whole floor, something quite laborious but not particularly technically difficult from what I read. You asked for it.... Good luck and have fun! -tim
tphan is offline   Reply With Quote
Old 01-12-2011, 12:51 PM   #4
1963 22' Safari
quick insulation question
Hi all. When re-installing the fiberglass endcaps, is it better to attach the insulation to the back of the cap or to the interior of the metal?
Old 01-12-2011, 01:05 PM   #5
Interior of the metal, which will keep more heat or cold, as the case may be, out.
Old 01-12-2011, 02:34 PM   #6
ddstech's Avatar
1958 22' Flying Cloud
Folsom , California
fiberglass
I just did this, I found it easier to put it on the backside of the endcap and push it up into place. Use gravity to your advantage.
ddstech is offline   Reply With Quote
Old 01-12-2011, 03:20 PM   #7
jaclaws toys
1960 22' Safari
1962 22' Safari
terrell , Texas
Images: 107
it is a job to replace the whole floor. the alum. track that the studs go into is bolted to the floor all around the outside and across the floor at all the metal joices. you have to remove the under skin and the inside wall from the windows down. the bolts will be rusted and the frame might be. the only one that i changed the complete floor on, we ended up taking the body off the frame and building a new frame. also the alum. trim at the bottom on the front and back screws into the flooring. good luck
jaclaw is offline   Reply With Quote
1966 Airstream 22' Safari eBay Watch Airstreams on eBay 0 10-22-2010 01:30 PM
1957 Airstream trailer 22' NR eBay Watch Airstreams on eBay 0 10-18-2010 07:30 AM
1964 Airstream Safari, 22'. 1960's Airstream, 22', HOT! eBay Watch Airstreams on eBay 1 04-25-2010 06:58 AM
Airstream Safari 22' LIKE NEW eBay Watch Airstreams on eBay 0 11-20-2009 07:20 AM
Airstream Safari 22' LIKE NEW eBay Watch Airstreams on eBay 0 11-03-2009 02:30 PM
