Old 05-13-2019, 09:15 AM   #81
tonydead's Avatar
1976 25' Caravanner
Kent , Washington
Glued my remaining walnut together for the dinette table. I ran short so I had to use some scrape pieces perpendicular to the others to fill in the gap. This was my biggest mistake; had I put them together in reverse order the entire perpendicular pieces would have ended up in the drop leaf, as it is I cut them and now they're offset. Chalk it up to it giving it some character I guess. I measured all the cuts dozens of times before I made them, I couldn't afford to make any other mistakes.
ID:	340629   Click image for larger version
tonydead is offline   Reply With Quote
Old 05-13-2019, 09:41 AM   #82
tonydead's Avatar
1976 25' Caravanner
Kent , Washington
Made the cuts for a rule joint for the drop leaf.
ID:	340636   Click image for larger version
Old 05-13-2019, 09:44 AM   #83
tonydead's Avatar
1976 25' Caravanner
Kent , Washington
Rounded the corners. Used the same round over bit to go around the perimeter of the table and match into the rule joint. Sanded down to 220 grit and applied 50% pure tung oil and 50% mineral spirits. Going to let the old lady apply the high gloss polyurethane so I don't screw it up like last time.
ID:	340638   Click image for larger version
Old 05-24-2019, 06:37 PM   #84
tonydead's Avatar
1976 25' Caravanner
Kent , Washington
Out in the table pole leg.
ID:	341530   Click image for larger version
Old 05-24-2019, 06:39 PM   #85
tonydead's Avatar
1976 25' Caravanner
Kent , Washington
Stepped away and let the wife do the hard part.
ID:	341532   Click image for larger version
Old 05-24-2019, 06:40 PM   #86
tonydead's Avatar
1976 25' Caravanner
Kent , Washington
Put up the stock mirror. Found the stock mirror brackets.
Old 05-24-2019, 06:43 PM   #87
tonydead's Avatar
1976 25' Caravanner
Kent , Washington
Table in place. Finally!!
ID:	341535   Click image for larger version
ID:	341537   Click image for larger version
Old 05-24-2019, 06:45 PM   #88
tonydead's Avatar
1976 25' Caravanner
Kent , Washington
Wife finished making the cushions.
ID:	341539   Click image for larger version
Old 05-25-2019, 06:53 PM   #89
tonydead's Avatar
1976 25' Caravanner
Kent , Washington
Cushions on the benches without the table.
ID:	341614   Click image for larger version
Old 05-27-2019, 06:36 AM   #90
Bourbonshot's Avatar
1961 24' Tradewind
1975 31' Sovereign
Louisville , Kentucky
Looking good!
Bourbonshot is offline   Reply With Quote
Old 06-19-2019, 07:34 PM   #91
1966 17' Caravel
2018 23' Flying Cloud
Colleyville , Texas
7kk!!~o!mk
KenDavis is offline   Reply With Quote
Old 06-19-2019, 07:39 PM   #92
1966 17' Caravel
Colleyville , Texas
Kkm
Old 06-24-2019, 11:34 AM   #93
tonydead's Avatar
1976 25' Caravanner
Kent , Washington
Originally Posted by KenDavis View Post
7kk!!~o!mk
wat?
Old 06-24-2019, 11:36 AM   #94
tonydead's Avatar
1976 25' Caravanner
Kent , Washington
Finished stereo cabinet and used up the very last of the walnut.
ID:	344315   Click image for larger version
Old 06-24-2019, 11:38 AM   #95
tonydead's Avatar
1976 25' Caravanner
Kent , Washington
Re used the original vent hood that I took out of the old plastic/particle board cabinet.
ID:	344318   Click image for larger version
Old 06-24-2019, 11:42 AM   #96
tonydead's Avatar
1976 25' Caravanner
Kent , Washington
Hung a shelf with recessed lighting above the counter top. I was going to close it off with doors to make a storage cubby, but, the wife wanted it left open. I found the wood shelf as-is (minus paint) at Goodwill for $5.
ID:	344320   Click image for larger version
ID:	344322   Click image for larger version
Old 06-24-2019, 11:48 AM   #97
tonydead's Avatar
1976 25' Caravanner
Kent , Washington
Finished off the electrical with a control box for lights, fan and the water pump. There is plenty of extra power lines for adding stuff in the future.
***Does anyone know about these old tank level sensors?****
I had put off on buying a new gauge ($60) for them because I read on here somewhere that the old sensors will not work with new level gauges. If someone could point me in the right direction for some information that would be great. Whether I need to replace the senors and/or can find a gauge for them.
ID:	344325   Click image for larger version
Fixin' to restore/renovate in Texas - 1963 Trotter63 1960 - 1964 Globetrotter 11 06-06-2014 08:07 PM
To restore or renovate.... Noco Airstream Lifestyle 14 05-14-2013 08:12 PM
1976 Airstream Caravaner eBay Watch Airstreams on eBay 0 04-23-2013 03:40 AM
1976 Airstream Caravaner eBay Watch Airstreams on eBay 0 04-16-2013 09:40 AM
1976 Airstream Caravaner Paul49 Airstream Registry Discussions 0 03-17-2012 08:59 PM
