Old 08-21-2008, 11:07 AM   #1
1977 Argosy 24
12 Volt and T.V. Apparattis................
Howdy........
Iam looking for that little "fixture" that houses the 12 volt power and T.V jack....straight across from the door, and next to the upper bins..on the wall.......on a "79" "Argosy" 22ft
any body have any idea's...where a man might procure one??
Thanks,Big Mike..................
BigMike is offline   Reply With Quote
Old 08-21-2008, 11:17 AM   #2
DEITZ645's Avatar
2006 30' Classic S/O
Mohrsville , Pennsylvania
Originally Posted by BigMike View Post
Howdy........
Big Mike,
Do you mean the Winegard RV-7012...
Look Here...
http://www.winegard.com/mobile/wallplates.htm
Carl, Elaine & Finn The Beagle
2006 30' Classic W Slide & Limited Package Katarina
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
DEITZ645 is offline   Reply With Quote
Old 08-21-2008, 11:26 AM   #3
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings BigMike!
The receptacle is readily available. The main difference is that the new receptacle will have a coaxial connector rather than the 300 ohm twin flat wire that would have been original equipment. An adapter can be purchased to convert between the two, or new coaxial can be run to the antenna. I had new coaxial cable run in both of my coaches to avoid potential problems down the road. The receptacles that I have in my coaches came from Winegard see:
Winegard 12-Vot TV Antenna Recetacles.
Kevin
Kevin D. Allen
AIR #827
12 volt
12 volt TV? john hd On The Road... 52 07-02-2008 02:16 PM
6 volt vs 12 volt brakes? lwebb Brakes & Brake Controllers 17 07-14-2005 08:32 AM
12 volt confusion?? COArgosy78 Electrical - Systems, Generators, Batteries & Solar 7 09-21-2004 03:51 PM
Wiring Sequence to hook up 2 x 6 volt battery pack to your 12 volt trailer battery TobyJH Batteries, Univolts, Converters & Inverters 0 05-21-2004 12:04 AM
1961 - 12 volt or 6 volt? Marlboro Mafia Electrical - Systems, Generators, Batteries & Solar 4 04-19-2004 09:03 AM
