Old 03-18-2011, 07:42 PM   #1
tinbender's Avatar
2001 16' Bambi
2013 23' International
Piedmont Region , North Carolina
.040 for new interior skin??
I want to replace some interior panels on my trailer and have found a good deal on 4' X 10' aluminum sheets at a local metal fab shop who will also cut the new panels from my templates. The only drawback is that this stuff is .040 thick instead of the usual .032. It is bound to be harder to work with in the top end sections since the hardest curves are there.
Anybody out there use .040 for replacement and would you recommend it?
TB
tinbender is offline   Reply With Quote
Old 03-18-2011, 07:50 PM   #2
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
I would be inclined to make the copies myself and make sure to drill every rivet hole too. It will save you tons of time if every hole lines up as well. I would imagine it would be harder to bend, granted most bends aren't that tight, you might be ok.
Scott & Megan
VAC LIBRARIAN
Restoring Wally Byam's 1955 26' European Caravan Trailer!
WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is offline   Reply With Quote
Old 03-18-2011, 08:11 PM   #3
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
I plan to. I already have it in my interior kit. .040 is no harder to work with then .032.
Old 03-18-2011, 08:29 PM   #4
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
Aren't most interior panels greater widths than 48-inches?
Also - planning overlaps or doubler-plates at seams will require some forethought, I know lengths go to 14+ feet on my 27'...
Old 03-18-2011, 08:49 PM   #5
Colin H's Avatar
1957 30' Sovereign of the Road
1959 28' Ambassador
1949 24' Limited
Peru , New York
TB
It will depend on the temper of the new material. As the bends are large, I suspect it won't be a problem.
Colin
Colin H is offline   Reply With Quote
Old 03-18-2011, 09:57 PM   #6
tinbender's Avatar
2001 16' Bambi
Good info and fast !!
Thanks to one and all!!
From the comments seems it won't be too much of a concern after all so I'm gonna go forward with it while I have the opportunity. I need to give an answer to the shop on Monday to order or not.
Wabbiteer -- I haven't removed them yet but initial measurements of the interior panels show that all of them can be made these size sheets, it's a shortie, 16'. The center one of the 3 in front is the largest and it's 48" at it's widest point so I'm good there. Also no really long ones like in your "regular sized" trailer.
Goransons -- I plan to do all the rivet holes myself. The new sheets will be overlayed with the old, marked and cut to the same size. I'll bring it all back home and drill 'em up overlayed the same way.
Thanks again.
TB
Old 03-19-2011, 06:58 AM   #7
Wabbiteer's Avatar
1972 29' Ambassador
Including the seam overlaps? The lowest inner panels on my two older trailers have four or even six or more inch-wide lap areas extending behind the sidewall-to-ceiling-curve sheets joints...
Just concerned - not suggesting its not do-able, its just the 60" widths required in my case is out of my league financially, and there are hidden rivets on the touches-floor panel behind the wall-curve section that might be considered structural for stiffness/integrity of the inner shell.
Laying it out and allowing a goodly overlap (whatever that may be) it can be done with three or four strips versus the two original, just prior proper planning to pre-drill and have everything squared in relation with each other
Old 03-19-2011, 07:17 AM   #8
tinbender's Avatar
2001 16' Bambi
48" at widest point --
Valid point but....
The center front panel is on top of the 2 side pieces, so the overlap comes into play from them. The end that joins at the ceiling light is 48" and it tapers down to the top of the window at 39".
Old 03-19-2011, 09:39 AM   #9
goransons's Avatar
1963 22' Safari
That really stinks if the early 70's units used some wider stock. Everything I've run into so far in the 60's are 48" tall or less, generally with a filler strip between the top and bottom of the windows, with 4'ers at the floor level and 4'ers from the top of the windows to the ceiling center line.
Scott & Megan
VAC LIBRARIAN
WBCCI 8671
aluminum
