Old 08-17-2015, 10:06 AM   #43
1985 31' Excella
Jasper , Texas
If the trailer isn't already scrap metal that leaks like a sieve (which I suspect it is), if I try to repair it myself I am sure I will manage to make it that way
After I managed to destroy my last camper I am now of the mind that mission critical repairs must be done by people who know what they are doing
If the trailer is to far gone for reasonable repairing it is going away, and I will chalk it up as an expensive learning experience (except I don't learn . . . . oops)
alexj is offline   Reply With Quote
Old 08-17-2015, 11:57 AM   #44
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Excella
Alexj, Checking the leaking is fairly easy. Use a water hose to run water over sections of the trailer a small section at a time. You can even use a friend to run the water while you spend time inside looking for leaks. Or if you prefer you can be proactive and clean off all the old sealant and treat all the panel seams and rivet heads with Captain Tolleys Creeping Crack Cure (available at good marine stores)! This will absorb/wick into any cracks or gaps until full and seal them, Then after you are sure leaks are fixed you can overlay Acryl-R or other Airstream caulk sealant to prevent future leaks! Once your shell is waterproofed you can deal with window leaks or glass replacements as needed. Once trailer is dry then you can deal with floor rot or other issues. Turn it into a aluminum tent for a while if you need time to afford repairs but get the leak issues stopped first! Ed
1967 Safari Twin "Landshark" w/International trim package
1999 GMC Sierra 1500 SLT
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
BIGED52 is offline   Reply With Quote
Old 08-18-2015, 08:23 AM   #45
Floatingair's Avatar
1994 30' Excella
Kiefer , Oklahoma
Alexj: Please, sell your AS ASAP or trade it in on a SOB. This AS isn't for your currant lifestyle. Maybe a newer AS with little to no problems for your future lifestyle. I heard Breckenridge makes a very good residential RV.
Floatingair is offline   Reply With Quote
Old 08-25-2015, 10:12 AM   #46
1985 31' Excella
Jasper , Texas
Mechanic has checked it over and his initial impression is positive. AC and microwave both work. It needs some work so it is going to be towed to the shop. Mechanic thinks floor and shell are solid. May need new hot water heater, which I already budgeted for. Other systems not yet tested.
Old 09-09-2015, 02:58 PM   #47
1985 31' Excella
Jasper , Texas
Has a new water heater, getting AC replaced, going to move in this weekend may be the plan
Old 09-09-2015, 05:15 PM   #48
1985 31' Excella
Jasper , Texas
Or not. My buddy who has the big truck has his truck laid up so I can't do musical trailers to get my old SOB out and my Airstream in! ACK!
My poor Volvo has been towed to the shop to be worked on and to clear the approach route for the Airstream to move in
Old 09-19-2015, 11:53 AM   #49
1985 31' Excella
Jasper , Texas
Electrician just came by and now I have new shiny outlets installed for my Airstream to plug into when it is deployed
Moving closer
Also pondering naming it Yellow Submarine since the interior is very yellow, and hopefully much like a Submarine the water will stay on the outside
Old 09-24-2015, 11:45 AM   #50
BigButtUgly's Avatar
1958 22' Caravanner
not shared , Nebraska
alexj; How about "Moby (silver) Pickle" Sounds better with (silver) left out unless....
Shinny Moby Pickle
BigButtUgly is offline   Reply With Quote
Living permanently in a stationary Airstream LindsayStove Full-Timing 66 11-12-2016 09:04 PM
Full Time Streamer versus other full time RVs rodsterinfl Full-Timing 31 01-18-2016 05:31 PM
FULL time Trailer or FULL time Motel? Ray Eklund Full-Timing, Winter Living & Workamping 40 07-06-2015 06:11 AM
Fulltiming: stationary or mobile? (Poll) clecogirl Full-Timing 11 02-24-2007 03:31 PM
If Airstreams were stationary... at_wanderer Off Topic Forum 15 11-14-2006 11:09 AM
