Old 12-14-2011, 01:43 PM   #15
Crusty's Avatar
1992 34' Excella
Images: 8
Don't leave the city water hose connected to the trailer water inlet turned on all the time. Only use the city water to refill your freshwater tank because high pressure from the city water system can cause plumbing to start leaking in places that you may not notice until your floor is ruined.
Use about 1mL/gallon of bleach to keep your freshwater tank free of living things.
Let your black tank fill up, empty it and then close the dump valve. Leaving the dump valve open will result in the dreaded Black Hills problem in your tank. A reed fragrance diffuser in the bathroom makes life more pleasant.
As was said before use electric space heaters instead of burning propane for heat.
Try to arrange some shade in the summertime because it makes the trailer tolerable instead of a sweatbox.
Memory foam beds are terrible IMHO. Get sleep number type beds and latex pillows.
Buy a small clip on fan to blow on the fridge coils. Otherwise your fridge will be just barely cool in the summer time.
Be nice to each other.
Crusty
"If you come to a fork in the road, take it."
Austin, TX "Rancho Deluxe"
Crusty is online now   Reply With Quote
Old 12-14-2011, 04:19 PM   #16
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
You can leave the city water hose connected if you use a pressure regulator. There are several sources to purchase a regulator which attaches to the hose connection. The recommended pressure is 40#.
Old 12-14-2011, 04:56 PM   #17
Bk Yd Safari's Avatar
2008 20' Safari
Tunnel Hill , Georgia
Everything that's been said, and be sure to keep your "sense of humor" close at hand!
Bk Yd Safari is offline   Reply With Quote
Old 12-14-2011, 05:35 PM   #18
gainesville , Florida
I think all newer ASs have built in pressure regs,,No? jim
WBCCI 3106, AIR 8784, TAC FL 14, 05 Safari 25ft LS FB, 06 Dodge Cummins 3500
zigzagguzzi is offline   Reply With Quote
Old 12-14-2011, 06:19 PM   #19
norbert's Avatar
1993 30' Excella
chicagoland , state of confusion+north of cheddar curtain
Images: 24
Talking
Originally Posted by bean2005 View Post
I am new to not only the forum, but also to Airstreams! My husband and I met at work 2 years ago (he is a firefighter and I am a paramedic - both in Austin), got married at the beginning of October 2011, and we decided to dive right in to our first major adventure as husband and wife...we rented out our downtown condo, bought a 2012 27' International FB and moved into an RV park in downtown Austin as fulltimers.
We are so excited, and learning so much - but I have heard over and over again that the best advice and wisdom comes from the forums. I just thought that I would introduce myself and ask:
If you were limited to the top 3 things you wish you knew when you were a beginner, what would they be?
Thanks a ton!
hiya...
1.have as much fun as you can.
2.if you have problems, the info is here...
3. i wont say any thing bad to you...some day you may have to pound my chest...
Illegitimous noncarborundum(dont let the bastards wear you down)
The only true nobility is found through giving good food to your friends- Anton Careme
beauty is in the eye of the beerholder-cosmo fishhawk
if something is too good to be true, its usually gone before i get there-mister boffo
norbert is offline   Reply With Quote
Old 01-01-2012, 08:31 AM   #20
Noxon , Montana
question about the ceramic disc heater
Originally Posted by ASwifey View Post
Get a good mattress! We have a 12" memory foam mattress from Costco. Easy to cut to size and is wonderfully comfortable!
We also use a ceramic disc heater for cold nights. Why use our propane when we can use the campgrounds electricity right?
Have fun! Sounds like you're off to a great start.
Which model works best for you?
Pecos
Pecos is offline   Reply With Quote
Old 04-13-2012, 10:28 PM   #21
stowaways's Avatar
2007 27' Safari FB SE
1969 31' Sovereign
Ft. Worth , Texas
1. In winter, fill your fresh tank and disconnect hose! If you accidentally leave it connected, it freezes, you open faucet, forget to close it, line thaws, you flood your trailer. Oops! Lol
2. Do not lose your sense of humor! See no 1.
3. Keep your fridge under tree or in shade if possible. Helps a lot.
4. Cover your tires. Sun kills.
5. When you buy something new, take something out. (donation stations!)
6. When you hit the road, check that sun guards, rock guards AND screen in hot water tank are secure. See no 2!
7. Get ahead of the heat early in the day. If you wait to cool off Airstream after work, you're toast. In 100+ degree days, close off bedroom and the front of Airstream will actually get below 80 degrees. Won't hurt AC. We're on year five in the Texas heat!
8. Bathe your Airstream regularly. It's good for the soul and let's you keep an eye on any spots that need Vulkem!
9. Remember you chose to live on wheels for a reason! They're made to move. Enjoy it at every opportunity!!!
Best of luck. Look forward to reading about your adventures! You guys should consider the Rally in June in San Marcos. We're thinking about heading that way...
Sammie, Krystal, Lucas, Spencer & Jake!
stowaways is offline   Reply With Quote
Old 04-13-2012, 10:30 PM   #22
stowaways's Avatar
1969 31' Sovereign
Ft. Worth , Texas
Wait you said three!!! Oops! Lol
Old 04-13-2012, 10:49 PM   #23
elfirebob's Avatar
2007 25' International CCD FB
1970 23' Safari
Pine Valley , California
Images: 126
Great question, fantastic anwers...all three were "the best advice"...don't forget See More, Do More, Live More!
Welcome the the forums...you two stay safe our there.
Stream Safe,
Bob U-
Pine Valley, CA.
The " TinDen "
2007 25' International FB
1970 Safari 23' Land Yacht
Charter Member 4 Corners Unit
(View all of elfirebob's images)
elfirebob is offline   Reply With Quote
Old 04-13-2012, 10:49 PM   #24
LawChick's Avatar
1992 29' Excella
Morrilton , Arkansas
Images: 33
Might want to put the antennae down and be sure to lock the awning. We know people who have forgotten and lost aforementioned. Remember #2 above! LOL
Carol
2004 Dodge Ram 2500 Cummins Turbo
1992 Excella Classic 29'
"Live the life you've dreamed."
-- David Henry Thoreau
LawChick is offline   Reply With Quote
Old 05-18-2012, 06:02 AM   #25
2008 30' Classic
Anchorage , Alaska
Congrats on your new lifestyle!
My wife and I are on the same track. We decided to change gears in life back in '09. We got rid of a house on the West coast, bought an Airstream, and decided to try full timing. We moved to Austin for two years while we did some exploring to figure out where we wanted to settle. Not sure where you are staying, but we based ourselves at Oak Forest and really liked the folks there. Also became seriously addicted to Salt Lick. We still miss the BBQ.
The three things that I would recommend would be to travel, travel, and then do some more traveling. I am a firm believer that while these trailers look great in the backyard as a guest house, they were really intended to be road homes. We spent some time at the factory and were moved by Wally's obsession of testing his product with caravans all over the globe. Nothing compares with the ability to bring your own personal hotel along with you while you explore some destination for a few weeks or longer if deemed necessary. We spent a summer in the Canadian Maritimes where the Airstream was put to the test in all sorts of crazy experiences. It came through without a hitch (thank god). Even dragged it up the Alcan from Montana.
Anyway now we are in Alaska and still full timing it (winters too). These are great rigs. You and your husband have some good times ahead.
dukester is offline   Reply With Quote
« Newbie Questions... | Top | - »
Abby gets some separation H Top Repairing/Replacing Floor &/or Frame 386 Yesterday 07:50 PM
Excited beyond words ddhburns Member Introductions 10 12-04-2011 12:24 AM
Help for a soon to be Airstreamer Chillpoints Hitches, Couplers & Balls 8 09-08-2011 06:38 PM
Best HD Truck...All Around. THEPILL Tow Vehicles 50 02-04-2011 10:36 AM
