Old 01-08-2013, 05:38 PM   #99
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Believe it or not, but painters tape is a huge help for all of the small places that leak air. The advantage, of course is that it peels off without leaving a gummy residue. It does look pretty ugly, but success is not always pretty.
Try a roll of "gaffers tape" (used in film productions). PERMACEL 672
No residue problem and far more useful as toolbox supply.
Old 01-08-2013, 10:31 PM   #100
SuperTrouper's Avatar
2008 27' International CCD FB
Petaluma , California
Originally Posted by REDNAX"
Try a roll of "gaffers tape" (used in film productions). [URL="http://www.bhphotovideo.com/c/product/354371-REG/Permacel_Shurtape_Gaffer_Tape_Professional.html
PERMACEL 672[/URL]
AND you can get it in Silver (well Grey anyway) plus other colors. Once you've used Gaffers tape at work, you really miss having it at home.
SuperTrouper is offline   Reply With Quote
Old 01-12-2013, 03:46 PM   #101
2005 19' Safari
GLENDALE , AZ
Phoenix television news said Grand Canyon temperature dropped to -14F last night. -- How are you guys doing up there?
By the way, "Oops", "Goo Gone" and similar products will take off about any residue, and your finger tips. However, be careful using this stuff, as it contains hazardous chemicals, including naptha, xylene, toluene and some other nasty stuff. Besides not getting it on your skin, also be careful of inhaling fumes. I'm guessing it probably causes cancer, too.
Old 01-12-2013, 08:16 PM   #102
deauxrite's Avatar
2007 27' Safari FB SE
Full Timers just passing through , Arizona for a couple of weeks and then on to Utah!
Pretty chilly for the last couple of nights. I think around -2 or so here in the camp. We are holding out pretty well..condensation is better controlled, though still an issue. Sun during the day helps to heat the trailer and the furnace runs a lot at night. Last night I supplemented with electric to keep it toasty. (60f).
I am having hot water problems that are not associated with the cold. We are discussing whether we will be using the campground bath house or face moving the trailer to Flagstaff to have the hot water tank replaced. (Remove skirting and replacing). I can't do anything until it warms up a bit, so for now it looks like $2 showers at the Mather campground.
It could be worse. If I had not been watching pretty close I would have had lots of hot water in the house..on a night when the temperature is supposed to be the coldest in 30 years..not a good outlook. So, I bypassed the hot water tank and drained it. "Better safe than sorry" some wise man said!
Living life on the Road
deauxrite is offline   Reply With Quote
Old 01-13-2013, 06:37 AM   #103
Amen to masking tape. I used duct tape around my jalosie windows a year ago and the mess is still visible.
I am interested in your propane consumption. How long do you get on a seven gallon bottle? Here in San Carlos Sonora, the furnace is going on a couple of times a night. It is set at 68. Last year it went on once. t is very cold all across the SW.
We are going to Tucson tomorrow. Will stay at the Windmill and leave the AS in storage. Am I a whimp or what?
handn is offline   Reply With Quote
Old 01-13-2013, 07:17 AM   #104
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
Thanks for nice thread on living in the cold.
Lots of good information here.
Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 01-13-2013, 08:51 AM   #105
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
It is supposed to be -7 here tonight (Mon. morning) and -8 Tuesday morning. It hasn't been above 32˚ except for short times on 2 or 3 days in the past 4 weeks. I've seen cold snaps like this before with colder temps (-20's and -30's), but not in many years. It is supposed to get up to 25˚ later in the week.
Sorry to be hear about the sick water heater. I guess you could boil water for sponge baths, but then you increase condensation.
Gene
Old 01-13-2013, 10:55 AM   #106
dekew's Avatar
2010 27' FB International
Culver City , California
Another tip for battling condensation...
Hi Deauxrite - Excellent Thread!
We're in Seattle where temps dipped to a balmy-for-you 18 degrees last night. About the only prep we've done is to heat tape our fresh water hose as have you. Given the low temp drop last night, I learned a lesson that some of you may already know. Anything with water in it will freeze, including y-splitters Luckily, we didnt have any damage, but the y-splitter is shot.
The other thing i wanted to mention - we also had a lot of trouble in our 27FB with condensation around the front wall as well as cold air coming up from under the mattress through our "garage" storage area. I thought about insulating the storage bin, but we wanted to keep it functional and insulation would possibly interfere with opening the door often. So, we gave this fan from West Marine a try. It's pricey, but since putting it in our storage are almost a year ago, we've had very little condensation or drafty problems from our storage area.
One last point on the mattress - be sure to check for too much moisture around your bed. After finding some mold on our factory mattress, we made a major upgrade to our bed this year, installing risers to allow air to circulate underneath. Just one more thing for you to watch out for and worry about as a full time Airstreamer
Thanks again for logging your experience, and continued good luck to you on your winterstreaming!
Deke, Tiffani, and Lucy the Cattledog
2010 27FB International CCD - "Big Weas"
2012 Ford F-250 6.2L V8 Crew Cab
Follow us on Weaselmouth.com, Connect with us on facebook and twitter!
dekew is offline   Reply With Quote
Old 01-14-2013, 06:22 PM   #107
deauxrite's Avatar
Gene
We woke to -7 here. I knew it was cold because the furnace ran most of the night. Good news was that we still had heat and running water..no hot water, but hey..count blessings when it is this cold.
Went to Flagstaff today and picked up a new hot water heater. I won't be able to install it for several days..it is just too cold to turn off propane to the trailer for the length of time it is going to take to replace the tank and test it. Showers at the campground for another week!
This hot water tank is installed with PEX fittings. I am hoping that the PEX will make the installation easier. We will see. I plan to do a video of the tank replacement..maybe it will help somebody else down the road.
Old 01-14-2013, 06:56 PM   #108
deauxrite's Avatar
Keeping it warm is the issue
Thanks for that. We have also had some issues from the front storage area. In our case, I insulated that compartment with pink fiberglas..lots of it! It makes it unusable, of course, but we are dealing with that in other ways.
The new foam around the entrance door is working well. Right now it is the curved windows that require mopping because of the condensation. It looks like that may just be the way it is for the next couple of months.
Propane is not too big of an issue for us because the local gas company installed a large (50 gallon)? Tank. They come by every two weeks and fill it..all I have to do is pay the bill Our current rate of consumption is around 16 to 22 gallons every two weeks. The rate of consumption varies dramatically depending on the temperatures. This will be a big two week period since it has not been above freezing and night time temperatures are at or below zero.
For others that might need to know..the furnace will keep the trailer at around 56 degrees when the outside temperature is between zero and 10 above. With last night dipping below zero, I added electric heat (1500 watts) and the trailer was still at 55 when I crawled out from under the electric blanket.
Without the skirting...I really do not think that the trailer would be comfortable.
Old 01-14-2013, 08:31 PM   #109
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
I haven't had the propane system pressure-checked on my new-to-me 1990 Silver Streak. So I bought a DYSON hot + cool electric space heater on the advice of a thread around here. Price shock is to be ignored. This thing is, hands-down, like no electric heater you've ever had.
Be careful!!
Old 01-16-2013, 09:04 PM   #110
deauxrite's Avatar
Be careful!!
Thanks for that. I am looking into the Dyson. We need a better solution than an electric supplement. -14 is too cold for the furnace and an electric supplement. We are early in the winter and more cold weather is to come..better heating is necessary here.
Old 01-19-2013, 12:52 PM   #111
Master of Universe
Gene's Avatar
Jerry, it is finally warming up here. Supposed to be 41˚ today and tomorrow, but close to zero at night. Then 30's. You may be able to put the water heater in now.
Gene
Old 01-19-2013, 01:33 PM   #112
Alumaholic's Avatar
1966 24' Tradewind
Albuquerque , New Mexico
Images: 33
Tell Us More About the Dyson, Please
Be careful!!
I am almost embarrassed to mention this on Deauxrite's thread, but we have had some cold weather in Mesa this winter. Okay, okay, so it just got down to 24 degrees. I know that's not -14, but I'm a whimp.
So, I need a better space heater too, REDNAX. Are you recommending the AMO4 model Dyson?
How noisy is it?
Can you sleep with it in operation?
If this is the right model, and it's quiet, I intend to order one today.
Ken L
1966 Tradewind 24
2007Chevy Silverado 2500 HD Duramax/Allison
Four Corners Unit WBCCI #8654
Alumaholic is offline   Reply With Quote
