11-28-2010, 11:21 PM
2009 23' International
Boulder
Winter Camping Screw Up!
So I decided to take our 23ft 2009 international to the ski resorts last weekend for some winter fun. Staying at a RV park is way cheaper than a hotel or condo, but I think I may have paid a price anyway.
I thought I had all the tricks for winter camping down. I ran the furnace at 65 the entire weekend and had a portable oil filled electric going at full blast as well. I put RV antifreeze in the black and grey tanks and used the internal water tank as opposed to using a city hookup. BUT THE TANKS FROZE anyway.
Of course it did get down to -11 one night so maybe I was doomed no matter what. The faucets only seized up for a few hours but once they freed up i kept a slow drip going which seemed to help. When it was time to leave Sunday we opened up the dump valves but nothing came out.
So I figured we try again near home where the temperatures were in the 40's. I guess I didn't put enough antifreeze in the tanks. Because even after a few hours at 40 degrees we could not get the black tank to empty. (the grey did) So I decided to try the sewer flush thinking it might loosen things up, but all that did was raise the level in my black tank to the only a few inches from coming out of the toilet.
So the weather in CO is not looking to get much above freezing for the next few days. I will attempt to thaw things by maybe leaving the trailer inside a dealers garage for a day if possible.
Anyway, I'm freaking out!
How much damage does the occasional accidental freeze cause? Is my black tank ruined? Is having the sewage so close to coming out of the bowl going to mess up things? Are the newer plastic pipes more resistant to cracking than the older metal ones? Is it just to risky to attempt winter camping? i've heard of retrofits done to trailers where heating pads are installed around tanks and pipes. Do these sort of modifications work well?
Anyway I just really wish there was a worry free way to camp with all the conveniences a trailer offers (water and bathroom) in the winter.
Thanks for listening!
11-29-2010, 12:12 AM
2012 25' FB Eddie Bauer
Virginia Beach
, Virginia
If your tanks were full they'd be toast. However if there was room for expansion they should be OK. Your black tank may be thawed, but the drain pipes might still be clogged. Try a space heater on LOW near the back side of the black tank drain.
You could also siphon some HOT water into the black tank by way of the open toilet valve. Fill your sink with HOT, then use a short hose to siphon it into the toilet, do a couple of gallons at a time. You could use a teakettle of boiling water - just make sure it does not contact the valve seals or the toilet if it's not porcelain. Don't fill it all the way if there's any chance it could re-freeze.
For winter camping, in the northern part of the country, you're better off with dry tanks, drained water heater and lines. Carry a porta potty, eat off of paper plates and carry bottled water. Keeping the underside of an Airstream warm is difficult in February in VIRGINIA. At a ski resort?
Good luck thawing out, Paula
11-29-2010, 01:41 AM
1978 28' Ambassador
Morada
Agh! Frozen plumbing can have titanic results...
I like the suggestion of using a small AC heater with a fan that can direct the heated air toward your black tank's outlet, if possible...
You can buy small 'ceramic' type heaters that can fill the bill in this regard....
Even if you can only point the heater toward the tank's metal enclosure, if you point it in the area of the outlet, it should heat the area enough to melt the clog...I'd prop the heater up as close to the tank as you can get it...
If all else fails, perhaps a move to Florida would cure things!
Ray
Ray & Pat; Morada, CA
11-29-2010, 06:20 AM
Wise Elder
2010 30' Classic
South of the river
The best thing to do now is pull in favors as necessary to get the trailer into a heated bay overnight. If you have a friend who works at a repair shop for cars, ask them if you can park overnight. If not talk to an RV dealer or try just going to a local body shop to cut a deal.
Even if you have to pay it's worth it, because by the next morning everything will be thawed and you can dump tanks and winterize.
11-29-2010, 06:57 AM
2000 30' Excella
Sarasota
cold weather camping
spent Dec 09 and Jan 10 in Kansas hunting pheasants in my 98 31' excella. Stayed in a state park that had a heated shower and bath house. temp got down to -20 windchill several times. All tanks, black, gray and h2o heater were emptied and antifreeze installed in interior lines. used the forced air heater and a 2.5 kw space heater to stay nice and toasty.
hung an electric blanket across front windows to offset heat loss during the day. not pretty but functunal. will try bubble wrap this year. used electric blankets at night. put thermarest camper pads under rear mattress to offset unheated storge space underneath.
washed dishes with heated water from stove. drained gray tank frequently on warmer days. don't think it ever froze.
yes it is extreme camping, geese talking on the lake, deer running thru campsite, stars at night, it even warmed up a couple of nights so we could have a campfire outside! made the trip worth while. 2 brothers, 3 excellent hunting dogs PRICELESS.
We became well known in the little town we stayed near, as the Campers from Florida and Oklahoma.
The AS was an upgrade from the Boy Scout camping we used to do in canvas tents in the 60's in Kansas! The motto is Be Prepared. Scouting is 100 years old, congrats.
A 34' with dinette would have been appreciated.
11-29-2010, 07:40 AM
St. Cloud
Tough one tmarquis! The blockage most probably is in the tank outlet pipe. Thawing could take more than an overnight in a heated garage. Heated to what? 50 degrees? Maybe 2 days or more to thaw. Heated garage + space heater sound like a plan. Careful for fire!
Consider that your automotive ethylene glycol is used at a 50% concentration to protect at below zero temps. One might assume RV propylene glycol has similar mandates at such cold temps. It would have been difficult to treat well enough to have used any of your tanks in such conditions. Temps like this, it'd have been better to use your coach as an aluminum tent (albeit a nicely heated one) and gotten the BVD fur-lined dropseat option to use the outhouse. Jugs of water; basins to wash & throw out the door. Just brainstorming...
I've heard of someone with a frozen drain system during a winter storm -- think they got out of it okay.
11-29-2010, 07:57 AM
Airstream - Other
Bosque Farms
, New Mexico
Ah, the RV antifreeze is different from automotive: All of the labels I've read indicate that it should be used undiluted. When diluted, it loses more and more of its effect.
Does your Airstream have enclosed, insulated and heated tanks/pipes/valves (black and gray)? Or is it one of those that is primarily intended for summer use? (It's easy to tell the difference. Just look at the plumbing. If it's visible from outside the rig, then it's a summertime rig.)
If it is a summertime rig, then there's not a lot you can do to make it winterworthy short of a bunch of heating and insulation. If it is winterworthy, then you'll need to diagnose why the heating system didn't keep the system from freezing.
Lynn
ACI Big Red Number 21043
11-29-2010, 12:57 PM
Boulder
So I should update my profile. I am no longer in Virginia we moved to Boulder CO last year. And I believe I've learned my lesson, I just don't think I will risk trying to use the plumbing, I will winterize and just dry camp. The resort we stay at up in Breckinridge CO has public showers and all so no worries there. I did find a place called Timeless Travel Trailers that will retrofit heating pads and such to your rigs plumbing I'll check out the price. THANKS!
11-29-2010, 02:04 PM
Wise Elder
2010 30' Classic
South of the river
I don't believe I've encountered any success stories of wet camping in -10 F and colder weather that didn't involve skirting the trailer.
11-29-2010, 02:12 PM
Virginia Beach
, Virginia
Please forgive me
I heard this from a MAN who does a lot of winter camping. I report this as an option that truly inclement weather may necessitate.
His solution to the 2 AM comfort stop in a winterized airstream? Heavy duty or "Heavy Doodie" plastic bag draped in the bowl of the toilet under the seat. He uses the facilities as needed, then seals the bag and drops it into a bucket to "deliver it" to the camp bathroom the next day.
His excuse is that he barely wakes up. The plastic bag keeps him from having to deal with a nasty mess, or worse yet create a flushed frozen nasty mess in the black tank. A brisk walk to the outhouse would ruin his sleep for the rest of the night. I suppose one could find a fine porcelain chamber pot with a cover and use it. This does seem to be utilitarian and practical especially if adult beverages are inbibed near bedtime.
Moi
11-29-2010, 02:21 PM
2014 25' Flying Cloud
Cuddebackville
, New York
While a strong wind might get the cold air through a crevice or two, wind chill is only significant as a perceived temperature on the human face. Wind chill does not affect inanimate objects. If the wind was gusting to 30 or 35 mph in your case (causing a -20 wind chill), the temp was about 5 above.
11-29-2010, 03:20 PM
Lin
, Ne
Moi
A 5 gal bucket half full of cat litter works too.
11-29-2010, 04:14 PM
1972 27' Overlander
Longmont
You were lucky that I-70 didn't ice up on your return trip- it would've made your frozen black tank seem like a stubbed toe. I consider my AS to be a 3-season rig only, and even the Spring and Fall in Colorado can be white-knuckle scary due to snowstorms, if you're caught driving in it. Your water lines are probably fine, as they are PEX plastic. The tank and valve, good luck with that. Hope to see you out there next summer! -tim
11-29-2010, 04:45 PM
Sioux Falls
, South Dakota
Then set the lid on pail by the side of the road with a "FREE" sign on it.
11-29-2010, 04:48 PM
1972 Argosy 26
1973 Argosy 26
Fairmont
, West Virginia
Wow I didn't know that a Airstream ever frooze with the heat on I have been in -14 last winter and we didn't freeze wow! I did leave a drawer out so the air could get around under the beds. I have frooze inlet lines before but never anything in the coach.... (Keep the furnace on while traveling)
11-29-2010, 04:57 PM
2005 22' Safari
Gresham
, Oregon
No free sign. My brother in law said he saw where a store put out some items they wanted to get rid of. Put a FREE sign out. Two days later still there, put a $10.00 sign on the stuff and it was gone the next day.
]Go figure.
11-29-2010, 05:24 PM
Lin
, Ne
A paper sack with some matches come to mind.
11-29-2010, 05:35 PM
Ready-to-Travel
2012 30' International
Walkerton
, Virginia
Yeah. $10. Honor Pay.
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
11-29-2010, 06:48 PM
Airstream - Other
Bosque Farms
, New Mexico
Yeah, I assumed -- based only on our Airstream -- that all of them were winterworthy. When we started giving discounts and got a lot more Airstreams in, that's when I discovered that that assumption was false: Some are only warm-weather rigs.
(Even so, I wouldn't trust our rig in the temps we get here in the winter.)
Lynn
11-29-2010, 08:22 PM
2017 30' Flying Cloud
2008 23' International
Keremeos
, British Columbia
I have a 2008 23ft Int. In my owners manual section titled Winter Traveling on pg C-7 states " The furnace supplies heat to the water lines and tanks on all models except the 22ft. It has 12-v heat pads for the tanks. These pads are individually switched with the switch located next to the monitor panel." Arent these pads supposed to prevent tank freeze ups (especially with RV antifreeze)? TMarquis I'm assuming your 23 ft Int is the same as my 2008. My warranty info has a the warranty card for these heat pads., but I dont have these switches. I just assumed they thermostatically turned on when needed. Any know more about these heat pads and switches?
Paul
Lisa and Paul
2017 30' FC | 2002 Chinook Destiny | 2008 23' Int. CCD (written off: hail!)
