Old 01-20-2013, 11:29 AM   #57
Wild-Air's Avatar
2012 25' FB Flying Cloud
Minden , Nevada
Originally Posted by CrawfordGene View Post
Underneath the black and grey tanks, just behind the valves, are access plates so you can get to the parts inside. I imagine using a hair dryer in the hole may help.
Gene
Thanks, Gene
I bought a 250w halogen work light from HD for $9.00. I laid it face up on the ground under the tank enclosure closest to where the tank cable protrudes. I let it warm up that specific area for about 2 hours and *voila * the gate valve opened.
As a solution (the concept Wally B had that Thor seems to miss), there are heat strips made specifically for gate valves in 13vdc from UltraHeat for $46.00. I'm thinking "Heated Tank Valves" could be an AS option for $300.00. I'd buy it, wouldn't you?
The idea would be to switch on the strips 15 minutes prior to dumping, shut off the switch, dump, close the valve, then go snowshoeing.
I love this forum!
Russ
Wild-Air is offline   Reply With Quote
Old 01-20-2013, 02:35 PM   #58
Wild-Air's Avatar
Minden , Nevada
Here's a picture of the halogen lamp under the tanks:
Russ
Old 01-20-2013, 04:31 PM   #59
carl2591's Avatar
2005 31' Classic
Garner, , North Carolina
Originally Posted by gsmithii View Post
Of course you could do as I did recently and wrap the light with a towel, wrap the towel with a tarp, and find a nicely charred towel in the moring. Sheesh! I amaze myself with occasional tricks that are just royally D.S. in hindsight. Sigh.
that was too fricken funny... wrap the light in a towel
maybe if you think through what you are doing before you do it then the DS part can be avoided...
its lucky the bulb was not large enough to produce enough heat over the 8 or so hrs it was there and start a FIRE.....
let be safe out there.. if it sounds stupid, it most likely IS...
still that was funny as h$ll,,,,
Carl, Raleigh NC
2-24-16 got a 2005 Classic 31D
TUG2.net check it out for good rental deals
2003 F-250 SD, CC, 7.3L PowerStroke
WBCCI#1691, Piedmont Airstream Club, Unit #161, Region #3
carl2591 is offline   Reply With Quote
Old 01-20-2013, 04:37 PM   #60
gsmithii's Avatar
2013 30' Flying Cloud
Virginia Beach , Virginia
Well - Carl - you're right on every point - although it's hard to see the dump valves with your thumb in my eye.
To paraphrase myself, learning from experience is more expensive than learning from others. I hope my post helps somebody - but if not, I'm glad you got a laugh from it.
Oh! Promise me that if you ever have a similar moment you'll share. We'll have a chuckle together.
Skip
Speed is Life . . . guidance is optional . . .
The Traveling Circus: 2013 Flying Cloud 30A; 2006 Chevy Duramax Crew/LWB
Air #42313 TAC VA-7 WBCCI #1290
gsmithii is offline   Reply With Quote
Hitch Set Screw, or is the winter just getting too long? SteveH Hitches, Couplers & Balls 42 03-01-2009 03:13 PM
**Winter Camping** Silvertwinky On The Road... 36 02-09-2005 09:38 AM
Winter Camping ajjohnsons Our Community 5 10-07-2004 07:42 PM
winter camping wheel interested Winter Living 12 11-02-2003 11:30 AM
winter camping murphy Our Community 1 10-27-2002 06:31 PM
