Old 12-06-2010, 02:31 PM   #43
1976 31' Sovereign
Blairsville , Georgia
I moved into my stationary 31', '76 model full time about a month ago. Several nights of 25 degree temps with only an unvented propane heater inside and no problem. (Yes, I have propane, carbon monoxide and oxygen sensors) Last night it went to 20 degrees so I used the furnace which has a long duct running under the bed and bathroom closet next to the water lines. Again no problem. Tonight it's going down to the mid teens so I'll see how it does. I'm hooked up to water and not using the white water tank which is drained. An electric heat tape on the incoming line has kept that thawed so far. Inside everything is nice and comfy though I guess I'm using a lot of propane keeping it that way. I'm at 1800' elevation in the N. Ga. mountains. This is going to be home so i have to make it work! I think underpinning with styrofoam is the next step.
Chip Arnold is offline   Reply With Quote
Old 12-06-2010, 02:39 PM   #44
dznf0g's Avatar
Oswego , Illinois
I am working on an idea whereby I would run a parallel circuit to the furnace blower controlled by a rheostat or maybe an automotive multi-speed blower resistor bank. This would allow the furnace to operate full time on a low speed (and low noise!) with an electric heater nearby the cold air return which would keep the tanks thawed. Whenever the thermostat calls for furnace heat, 12V would be applied to the original leg of the parallel circuit and the blower would go to high speed. When heat is no longer called for, the thermostat will shut of the furnace and the original leg of the blower circuit and the low speed circuit will take over.
Has anyone done this?
Old 12-06-2010, 02:51 PM   #45
RivetED's Avatar
Hillsboro , Texas
One of your problems could be the space heater. If it does not allow the Airstream furnace to cycle often enough the heat to the tanks will not have much of an effect on their temperature. Your space heater needs to be as far away from the thermostat as possible. Also your configuration may only have one of the tanks receiving the heated air, need to check by looking at your heater and see where the 2nd hose goes. Mine is vented directly to the fresh water tank and indirectly to the grey & black.
A trick I use very often is to put a drop light under each tank with a 100 watt light bulb and leave them on day & night when its freezing. For extreme cold camping higher wattage bulbs or the earlier mentioned space heater might give you the edge you need.
It's not exactly the "green" way to go but you do what you need to do and pay your carbon footprint back some other way!
My actual final solution for cold weather camping was to move to Texas and stay South during the winters. ...But I do understand, hope all works out for you.
"I have a new invention, 'Instant Water'. I don't know what to add to it!"
RivetED is offline   Reply With Quote
Old 12-06-2010, 03:10 PM   #46
SRW
TEXAS66
SRW's Avatar
2008 28' International CCD
Georgetown , Texas
Originally Posted by tmarquis View Post
So I should update my profile. I am no longer in Virginia we moved to Boulder CO last year. And I believe I've learned my lesson, I just don't think I will risk trying to use the plumbing, I will winterize and just dry camp. The resort we stay at up in Breckinridge CO has public showers and all so no worries there. I did find a place called Timeless Travel Trailers that will retrofit heating pads and such to your rigs plumbing I'll check out the price. THANKS!
Thanks for posting the link to Timeless Travel Trailers. I thoroughly enjoyed looking at the work.
TEXAS66
SRW is offline   Reply With Quote
Old 12-15-2010, 06:16 PM   #47
2010 30' Flying Cloud
Central Point , Oregon
We went through the same problem and used a hair dryer and ceramic heater over several hours to thaw out the black water lines. We wrap our fresh water hose in insulation with a heat strip. Your tanks should be ok. Our gray tank and lines have never been a problem.
good luck,
Spence & Kate
Scott553 is offline   Reply With Quote
Old 12-24-2010, 01:25 AM   #48
1967 17' Caravel
1979 28' Airstream Excella 28
Wheat Ridge , Colorado
Yes, you can retrofit an Airstream for extreme winter use. Extreme skiers Zach and Reggie Crist are logging their second winter in the Eddie Bauer/First Ascent Airstream without a single problem. The vehicle has been in nearly fulltime use traveling from ski area to ski area at temperatures as low as -25F. Here is a link to a video about the build of the trailer (click on header in frame):
In the photo below the coach is being pulled up a ski trail by a snowcat at Beaver Creek, CO for the World Cup races last december:
Brett Hall
Wheat Ridge (Denver) Colorado
http://www.TimelessTravelTrailers.com
Brett - TTT is offline   Reply With Quote
Old 12-24-2010, 09:22 AM   #49
RR , British Columbia
Images: 13
Winter Class
Brett:
That is one nice unit!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Dave
Old 12-24-2010, 10:04 AM   #50
SRW
TEXAS66
SRW's Avatar
Georgetown , Texas
Thumbs down A Really bad Idea
Wow, using an unvented propane heater sounds like a really bad idea. They give off noxious byproducts of combustion, burn oxygen, and are illegal in Canada and in some US states. Do really want to bet your life that they work perfectly?
TEXAS66
Old 12-24-2010, 10:12 AM   #51
Antique Pedaler's Avatar
2010 25' FB Flying Cloud
1964 17' Bambi II
Cheyenne , Wyoming
Images: 11
[QUOTE=tmarquis;921766]So I decided to take our 23ft 2009 international to the ski resorts last weekend for some winter fun......... BUT THE TANKS FROZE anyway.
We had the same problem with our 23 Safari several times including one memorable miserable morning in Rawlins Wyoming ....what we found, though, was it was the dump valves, not the heated tanks that froze. As you were able to dump the grey tank it sounds like the same thing. We tried numerous fixes which I won't go into. The final answer was this. With the tanks empty before a winter trip we put RV antifreeze down the grey and black tanks. Then with the outer drain cap in place we pull open the dump valves to allow the antifreeze to fill the void. So the valve area doesn't freeze being full of antifreeze.
We do the same thing with our 25 Cloud. Last February during our dash south we were snowed in at Las Vegas NM for several days. Very cold but nothing froze up.
Antique Pedaler
64 Bambi II, '10 Flying Cloud FB
'05 GMC Pickup, '11 Touareg
Santana, Hobie tandem bike & kayak
WBCCI/VAC #4181[S
Antique Pedaler is offline   Reply With Quote
Hitch Set Screw, or is the winter just getting too long? SteveH Hitches, Couplers & Balls 42 03-01-2009 03:13 PM
**Winter Camping** Silvertwinky On The Road... 36 02-09-2005 09:38 AM
Winter Camping ajjohnsons Our Community 5 10-07-2004 07:42 PM
winter camping wheel interested Winter Living 12 11-02-2003 11:30 AM
winter camping murphy Our Community 1 10-27-2002 06:31 PM
