Go FOR IT!! We spent our first year in ours through the Kansas Winter. Yup, not as easy as the other 3 seasons, but still awesome!
We supplied the Airstream completely with a copper water supply wrapped w/ heat tape and insulation up to the inlet.... Borrowed a couple 100 pound propane tanks and extended the supply lines to reach.... Put a heat lamp bulb in the water closet access to keep the black tank flush from freezing.....Left the grey tank valve open ALL the time ( you can always run the hot water to break up any frozen blockages) One particularly cold week of below freezing temps we had the P-Trap in the shower freeze up & the black tank valve froze shut! (Both remedied with Hot water)
We used a good electric heater inside to supplement the propane in the evenings, but still went through about 100 pounds a week! It was only for a few months....
The only time we had condensation issues was when we were cooking specific things on the cook top ( most things were grilled outside anyways) and a bit of vent fan can fix that in a hurry.
The area you're in has relatively mild winter, not like MN. or Wyoming with their bitter long cold spells.
PS.... Lining the underside of the Airstream with bales of hay does wonders for keeping the tanks clear of freezing temps and can be done for a relatively small sum...
GOOD Luck!!
